Correlation between RAM speed and CPU heat?
AlexRD
I noticed that when i manually set my memory to 2133 mhz (as instructed by gskill, since my memory is 2133 but if i don't change it there it will be 1600), my cpu temps go like 5-8 ºC higher. Is this normal? Is there a correlation between ram performance and cpu heat?
    Windows 8.1 x64
    Custom Built
    Intel i7 2600k
    Asus Maximus IV Z68 - Extreme
    4x4 Ripjaws X79 Series 2133 MHz (9-11-10-28)
    eVGA GTX 780 Ti Classified
    Default
    Full HD Philips TV 32"
    1x Crucial m4 SSD 512 GB
    Silverstone Strider Gold 850w
    Sentey - Renegade GS-6200
    Corsair H80i Liquid Cooler
    Logitech K800
    Steelseries Sensei Raw
    10 Mb
    Chrome
I have never seen this effect...
    Win 10 Pro 64bit
    Corsair M65 wired
    85MBps DSL
    Chrome and Edge
    1GBps Ethernet ports
It would help to know what the system specs are but I'm going to go out on a limb here and guess it's an i5/i7 system. With that being that the memory controller is built into the CPU it is possible that the temps will go up a little due to the increased load of the memory.
However a more plausible cause is probably due to using XMP mode to run the memory sticks at their rated speed. Usually when enabling XMP in the BIOS this can also increase other voltages as well, resulting in an increase in heat.
5-8 is kind of high, but yeah, it could be normal considering you are in effect "overclocking" the system by running the modules at their rated speed of 2133MHz.
BTW my modules are "overclocked" as well by running them at 1866, but I've never checked my temps with them running at 1600 so I can't say there's a temperature difference between 1600 and 1866.
Anyway please post your system specs, than use Core Temp to read your temps and post a screen shot of those readings here so we may see what they are.
Thanks.
    Custom built by me
    Haswell i7-4770K
    Gigabyte G1 Sniper 5 (BIOS F9)
    Corsair Dominator Platinum 32 gig (1866MHz)
    Sapphire R9-280 Vapor X
    Soundblaster ZXR
    NEC PA242W - 24 inch
    1920 x 1200
    Samsung 512gig 850 Pro SSD (OS), Samsung 256gig 840 Pro SSD (photo editing), Western Digital Caviar Black 2TB HD
    EVGA Supernova 1000 G2
    Cooler Master HAF X
    Corsair H100i Closed Loop Cooler
    Logitech Wireless Wave
    Logitech Performance MX
    High Speed
    IE11
    Norton Security
    RAM Speed: 1866MHZ @ 9-10-10-27-2T, 1.5v
That 'Core Temp' program was loaded with Add-Ons. My AV program blocked its download, till I shut down my AV program.
The program "Speed Fan" will also show core temps, and it didn't trigger a negative response from my AV program.
But if you're running your ram at a higher speed, the CPU will have to work harder to keep up. They work together.
I've adjusted the voltage to my RAM and the speed of my own CPU to reduce heating, since my house is NOT air conditioned and it can get pretty warm in here. It's 93F right now and it gets hotter.
But I'm totally controlling the CPU temp by making the adjustments I've mentioned above.
Good Luck!
TechnoMage :cool:
    Win-8.1/Pro/64
    Acer X-1200
    AMD 2 Core
    Acer
    Crucial, 4GB
    NVIDEA GeForce 9200
    On Board
    24" Acer
    Sandisk, SSD 500GB
    Acer
    SFF Slimline
    emachines 101 key
    Logitech Wireless
    5 Meg
Good Luck!
TechnoMage :cool:
you just decline them all if you don't want them, they have to get development money somewhere. that program is very solid and speed fan doesn't work on anything i own anymore.
    WIN 7 PRO x64, WIN 8.1 PRO x64
    Custom
    Intel i7 4790K
    ASUS Maximus VI Extreme
    32GB(4x8GB) DDR3 Team Xtreem 2666 @ 2400 CL10 10-12-12-31
    2x MSI GTX 780 Twin Frozr OC 3GB
    ASUS Xonar Essence STX
    ASUS PB278Q, HP 2311xi, UN46F7100AFXZA
    2560x1440p, 2x1080p
    256GB 840 PRO SSD
    10TB RAID 0 Array (Movies, Steam)
    6TB RAID 1 Array (Backups, Documents)
    3TB EXT Drive (Secure Backups)
    Corsair AX760
    NZXT White Switch 810
    Block: XSPC Raystorm, RES/Pump: XSPC Bay res W/D5 Vario, RAD: XSPC RX360, 6xNF-F12's
    Rosewill RK-9000 with MX Blue switches Logitech G15 Rev 2 (gutted for LCD)
    Logitech G400
    Chrome
    I also own a Lenovo Y510p, and Yoga 2 Pro
Welll considering most modern CPUs have the memory controller on die itself then it would seem plausible, but I used to run 2133 and didn't really notice any CPU heat more then usual
    Windows 8.1 Enterprise x64
    Custom
    AMD based
    AMD based
    16 GB DDR3
    Radeon based
    onboard
    Asus VX238
    120 GB SSD
    1TB storage
    Thermaltake Toughpower XT 775W
    Thermaltake Dokker
    Xigametek Darknight II
    Logitech gaming
    Roccat gaming
    30 mb
    IE :D
    Huh?
I actually use HW Monitor, so if core temp is really all you want here you go, i attached the pics.
Updated the system specs
    Windows 8.1 x64
    Custom Built
    Intel i7 2600k
    Default
    Logitech K800
    10 Mb
    Chrome
Good Luck!
TechnoMage :cool:
Exactly. Plus for a down & dirty, quick & easy temp program Core Temp works like a champ. And there are a myriad of temp reading programs out there, I just chose the one I thought was quick & easy.
There are no pics, they didn't load.
Anyway looking at your system specs I'll stay with my initial thoughts in post #3. But yeah, do post the temp readings :)
    Custom built by me
    Haswell i7-4770K
    Soundblaster ZXR
    1920 x 1200
    Cooler Master HAF X
    High Speed
    IE11
    Norton Security
Well that was dumb, forgot to attach the picture. Here you go
    Windows 8.1 x64
    Custom Built
    Intel i7 2600k
    Default
    Logitech K800
    10 Mb
    Chrome
Not sure what CPUTIN is, but your core temps seem to be within normal range so you should be good :)
Peace :cool:
    Custom built by me
    Haswell i7-4770K
    Soundblaster ZXR
    1920 x 1200
    Cooler Master HAF X
    High Speed
    IE11
    Norton Security
CPUTIN is what you normally might call "Die" temperature, temp at the back of processor. It's always higher than Core temps. Can go quite high, 90s or more. Some people when doing extreme OC, put a fan behind MB at the place under the socket. It would be of some help only when going to extreme.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    Asus strix 570 OC 4gb
    Samsung 960 evo 250GB
    Silicon Power V70 240GB SSD
    WD 1 TB Blue
    WD 2 TB Blue
    Bunch of backup HDDs.
    Sharkoon, Silent Storm 660W
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
Stock cooling can really get high cputin. Any decent 3rd party cooling and cputin shouldn't be going above 60s
    Custom
    AMD based
    AMD based
    16 GB DDR3
    Radeon based
    onboard
    Asus VX238
    120 GB SSD
    1TB storage
    Thermaltake Dokker
    Logitech gaming
    Roccat gaming
    30 mb
    IE :D
    Huh?
Iv seen it not read it right too like say 200c lol.
    Custom
    Intel i7 4790K
    2560x1440p, 2x1080p
    256GB 840 PRO SSD
    Corsair AX760
    Logitech G400
    Chrome
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
