Death
I installed my new Hyper 212 EVO cpu cooler yesterday. It was fine, 40C idle etc. 53C load.
Then I started getting crashes in the middle of playing games. Basically, my PC seems to stay on.. the GPU fan is still spinning. But as soon as my monitor screen turns black, my cpu fan stops spinning and the light from my top exhaust case fan stops, so I assume the case fans stop too. I recall seeing my back exhaust fan not spinning as well..
When turning on my PC, sometimes the cpu fan will still not work. I have to unplug the fan and plug it back in to fix this issue.
Windows 8 gave me a notification that told me that my drive had issues that needed to be repaired, so I went to cmd and ran chkdsk to see what's up and it told me I had corrupt 182 attributes along with an incorrect volume bitmap and a snapshot error. Defraggler tells me my drive health is GOOD, though.
After running a chkdsk /scan on boot up and all, my Windows 8 did not load after the loading screen. Just a black screen, numlock blinking, mouse cursor flashing. I tried doing a system restore, it tells me my anti virus might not be allowing it to function correctly. I tried diagnosing the problem with a recovery usb stick, it tells me it can't fix the issue.
I can get into safe mode, but the problem with it randomly not spinning still persists.
My computer was perfectly fine with the stock fan previously.. I'm worried that my motherboard is fried in some way. I'm going to try and reinstall the stock heatsink/fan but wow that's going to take a long time.
Now my rear exhaust fan AND my cpu fan just won't spin at all..
Specs under "My system specs" on bottom left
- Windows 10 Pro 64-Bit & Linux Mint 18
- Computer type
- PC/Desktop
- System Manufacturer/Model
- Custom built
- CPU
- AMD Phenom X4 975 3.6GHz 64-Bit
- Motherboard
- ASRock 970 Extreme3
- Memory
- Corsair Vengeance 4x2GB 1600 Mhz
- Graphics Card(s)
- MSI R9 380
- Sound Card
- Asus Xonar DG
- Monitor(s) Displays
- Dell S2340M 23" IPS
- Screen Resolution
- 1920x1080
- Hard Drives
- SSD: Samsung 840 EVO 120GB
HDD: 1TB Western Digital WD1002FAEX; 7200 RPM SATA3 64MB cache
SSD (2): Sandisk 120GB SSD Plus
HDD (2): WD Blue 1TB, 2017
- PSU
- Corsair CX500
- Case
- Antec 300 LED
- Cooling
- Hyper 212 EVO w/ Noctua
- Keyboard
- AZIO MGK1
- Mouse
- Logitech G700s
- Internet Speed
- 2 MB
- Browser
- Firefox & Chrome
- Antivirus
- Learned decision making skills
