Need help finding parts for new PC build ($500 budget)
    Windows 7
    I figured I might as well come to the experts here at EightForums for some expert guidance and support on finding parts for my new PC build. I'm working with a budget of $500. I've looked at Newegg and Amazon, trying to find the best deals, but I'm pretty lost as to what grounds to start on. I'd like to be able to run Windows 7 64-bit and play recent games like Diablo III and DotA 2 at max or recommended settings with no issues. I am excluding monitor, sound system, keyboard, and mouse from this build because I already have each of those items.
    So, can someone help me find parts at a good price? :-) So far I only know what case I want, which is this one here:
    COUGAR Orange Challenger Black Steel ATX Computer Case with 12cm COUGAR TURBINE HYPER-SPIN Bearing Silent Fans and 20cm LED Fan - Newegg.com
    I still need: Mother board, HDD, PSU, Graphics card, Processor, RAM... Am I missing anything else? I think that's it.
    Windows 7 Ultimate 64bit
    That case would take a pretty big chunk from your budget as it's only $500 and the case is $74, mind if I change it?
    Windows 7
    Go ahead :-) What do you have in mind?
    Quote Originally Posted by intelguy77 View Post
    I'll put the best thing I can together and post the list here when i'm finished.
    So Dota 2 and Diablo lll, any other games you might play in the future?
    Windows 7
    Quote Originally Posted by StriickeN View Post
    Okay, sounds good.
    Um, another game I like to play is Path of Exile.
    Windows 10 Pro Prieview x64
    Do you have a licence for Windows 7? I paid €360 (just over USD 500) for windows 7 Ultimate. That is your whole budget right there.
    Windows 7
    Quote Originally Posted by adamf View Post
    Yep, I already got the operating system. :-) Forgot to add that to the exclusion list, sorry.
    You haven't indicated your country. If you have $500 then buy last years model on ebay or craigslist or whatever you have in your country. Then upgrade your GPU. CPU doesn't matter much (find an i5 if you can). RAM is cheap. Spending 20% of your budget on a case is madness.
    Okay, sounds good.
    Newegg.com - Once You Know, You Newegg
    I came up with that, using an APU is perfect for your budget as it has the GPU already inside it for a good price. That APU will run all three of those games on max perfectly with no lag, I assumed you had an OS already so I didn't add that and lastly I threw in an optical drive, if you don't need the optical drive you can take it out and get the case you wanted.
    If you have any questions feel free to ask me.
    Windows 7
    Okay, sounds good.
    Wow, good build. Thank you so much. This is near perfect. But I wanted to suggest something. I was looking to use a modular PSU to try and eliminate excess chords and wires. Could I swap the PSU you suggested with this one?
    CORSAIR CXM series CX430M 430W ATX12V v2.3 80 PLUS BRONZE Certified Modular Active PFC Power Supply - Newegg.com
    Also, I was looking at mother boards too while you were coming up with that build. Do you prefer the mother board you chose over this one?
    Newegg.com - ASUS A55BM-E FM2+ / FM2 AMD A55 (Hudson D2) Micro ATX AMD Motherboard
Page 1 of 2 12 LastLast
I've been planning to get low budget graphic cards and R7 260X OR GTX 750..? i ain't a big gamer... but, i still play games often. so which one should i go with ? i've got i3-1st gen(i3-540). 4 gigs ram, and would like to play nfs MW(2012),hitman absolution,gta 5( when releases).. and some similar...
So i have a FHD screen IPS :) I changed the dpi and it all looks great for web browsing etc; However file explorer looks HUGE and i cant really use it For apps i just go to compatibility and disable the dpi but how can i achieve this for windows explorer, control panel etc;
Assuming you had absolutely no budget limit for a PC build right now, what would you buy?
I am looking for the cheapest Windows 8 tablet available. I am getting one to replace my ipad and one for my uncle. The best I can find is a refurbished Dell XPS 10 with winRT for $200ish. I can also get a new Vivotab Smart with atom proc for $400. Ideally I want an atom proc, but the price...
So I am not a very good cook, I blame my laziness. Anyways it's winter season hours and pay suck. I decided to cut back on eating out for two reasons. One it's cheaper to cook at home and two it's healthier and I get to decide what goes on it. Anyways I haven't found a site that offers a big...
As title, building a new budget rig for the lounge next week, I have a few old parts laying around and will be buying some nice new shiny bits namely CPU, Mobo and memory so I thought I would check back in here and say hi to everyone.:D No doubt I will need a little help and will be searching...
