Need help finding parts for new PC build ($500 budget)
  1. #11
    Windows 7 Ultimate 64bit
    Quote Originally Posted by intelguy77 View Post
    Wow, good build. Thank you so much. This is near perfect. But I wanted to suggest something. I was looking to use a modular PSU to try and eliminate excess chords and wires. Could I swap the PSU you suggested with this one?
    CORSAIR CXM series CX430M 430W ATX12V v2.3 80 PLUS BRONZE Certified Modular Active PFC Power Supply - Newegg.com
    Also, I was looking at mother boards too while you were coming up with that build. Do you prefer the mother board you chose over this one?
    Newegg.com - ASUS A55BM-E FM2+ / FM2 AMD A55 (Hudson D2) Micro ATX AMD Motherboard
    If you can afford that PSU, yes I would suggest getting it. The motherboard I added is a bit more advanced for only a few dollars more so I would get mine if I were you. Good luck with your new PC build, you wont be disappointed.
  2. #12
    Windows 7
    Quote Originally Posted by StriickeN View Post
    Does the PSU I showed you have enough ports? It's got 4 ports.
    And, thanks again.
  3. #13
    And, thanks again.
    Good thing you mentioned that, they gave you all the cables for the ports and you wont need the PCI cables unless you add a GPU on to your build, so you'll actually have 1 or 2 extras. However I did notice that the 8 Pin connected to the PSU cannot be split into double 4 pin connectors and the motherboard takes a 4 pin You might have to get the regular CX430 but that case should allow you to stuff all the unused cables behind the motherboard plate.
    And no problem, I like helping people.
Page 2 of 2 FirstFirst 12
I've been planning to get low budget graphic cards and R7 260X OR GTX 750..? i ain't a big gamer... but, i still play games often. so which one should i go with ? i've got i3-1st gen(i3-540). 4 gigs ram, and would like to play nfs MW(2012),hitman absolution,gta 5( when releases).. and some similar...
So i have a FHD screen IPS :) I changed the dpi and it all looks great for web browsing etc; However file explorer looks HUGE and i cant really use it For apps i just go to compatibility and disable the dpi but how can i achieve this for windows explorer, control panel etc;
Assuming you had absolutely no budget limit for a PC build right now, what would you buy?
I am looking for the cheapest Windows 8 tablet available. I am getting one to replace my ipad and one for my uncle. The best I can find is a refurbished Dell XPS 10 with winRT for $200ish. I can also get a new Vivotab Smart with atom proc for $400. Ideally I want an atom proc, but the price...
So I am not a very good cook, I blame my laziness. Anyways it's winter season hours and pay suck. I decided to cut back on eating out for two reasons. One it's cheaper to cook at home and two it's healthier and I get to decide what goes on it. Anyways I haven't found a site that offers a big...
As title, building a new budget rig for the lounge next week, I have a few old parts laying around and will be buying some nice new shiny bits namely CPU, Mobo and memory so I thought I would check back in here and say hi to everyone.:D No doubt I will need a little help and will be searching...
