Battery plugged in, not charging, is it broken?
trexiic
Hi, sorry for my bad english, I speak french.
My problem is:
One month ago, my battery was working good (2h+), and the day after, I decided to change room, so I unplugged the laptop (The battery was still in it) and... Everything shuts down :mad:
The laptop wasn't working anymore if it was unplugged, even if in windows, it was telling me the battery was 78% charged. The message was something like: 78% available, plugged in, not charging. After one month the message is now: 0% available, plugged in, not charging.
Even if I use linux, linux on a flash drive, windows 7, windows 8, or simply chilling in the bios, if I unplug it, it shuts down.
That might be a hardware problem, but why would my battery die "instantly", it was working really well one day ago?? I could replace it, but how can I know if the problem is the battery, or the connector that are on my laptop?
If I'm not clear, just tell me what you want to know.
Thanks!
What laptop model?
    Windows 8.1 x64
    0i812
    Intel Core i7 4770K LGA1150
    Asus Maximus VI Formula
    Corsair 32GB (4x8GB) DDR3 CMY32GX3M4A1866C9 1866MH
    2 x Crappy GeForce GT 640 2GB DDR3
    I haz lollies ..
    2 x LG / 2 x Samsung 21 Inch
    Crispy
    2 x Samsung 250GB SSD 840 EVO (OS / Other)
    1 x Kingston 120G HyperX SSD (Swap)
    3 x Seagate SATA III 2TB Barracuda (Data Drives)
    1 x Seagate SATA III 1TB Barracuda (Media to XBox)
    1 x W/Digital SATA II 300G VelociRaptor (Image)
    Silverstone 1500w
    NZXT Phantom 820 White Full Tower
    Noctua NH-D14
    Logitech G19
    Logitech G700 / Logitech T650 Touchpad Thingy
    ADSL 2+ (Australian version ... lol)
    All of them
    Nortons IS
    This one time at band camp ...
Does this help?
Samsung Battery Issues
There are a few posts on the internet regarding Win 8/8.1 and batteries not charging. Mostly about HP Laptops. Without being able to physically test your battery its not easy to say if its a false message or a literal drainage issue/dead battery.
I can only suggest, if the above link doesn't work, that you take it to a well known battery store and trust them to check the charge honestly.
Please post back with your result from the above link.
    Windows 8.1 x64
    0i812
    I haz lollies ..
    Crispy
    Silverstone 1500w
    Noctua NH-D14
    Logitech G19
    All of them
    Nortons IS
Ok donc si je comprends bien
1. Quand tu branche ton cable pour charger....
L'ordinateur dit que ca charge? Oui ou Non
Et si l'ordinateur ne dit pas qu'il est en charge, il reste allumé ou ça c'arrete après un certain temps?
    Custom
    AMD FX 6 Core 3.3Ghz
    78LMT Gigabyte
    8 GB
    GTX 650
    None
    16:9 Widescreen
    1366x768
    500GB
    1TB
    2TB
    Cooler Master Centurion 2
    Cooler Master Devestator
Il me dit que l'ordi est branché, mais ne charge pas. Au début il me disait que la batterie était rempli a 78%, mais maintenant 0% (ca fait un mois). Si je le debranche il ferme, peut importe si la batterie est dedans ou non (alors qu'elle était sensé etre a 78%...).
Si il est débranché et que la batterie est dedans, je peut pas le demarer non plus.
Ca m'a tout l'air de bris materiel, mais ce que je trouve etrange, c'est que du jour au lendemain la batterie meurt (alors que la veille elle durait encore 2h+).
J'hésite a en acheter une autre car je sais pas si le probleme vient de windows, de la batterie, ou de l'ordi.
J'ai essayer sur linux, linux sur une clé usb, windows 7 et windows 8, rien n'y fait :(
For those speaking english: I was explaining my problem... in french :)
Try to update BIOS then try again.
    Sony
    Intel Core i5-3337U
    Sony VAIO
    8GB @ 1600MHz
    Intel HD 4000
    Realtek High Definition
    Chi Mei
    Hitachi 750GB + Samsung SSD cash 32GB
    Sony 64W
    Sony VAIO
    15Mb/s
    Chrome
    Avast Free
