Two finger tap activates both right and left click.
    ​I have a Dell Inspiron 15z Ultrabook which has a Synaptics Touchpad, and after Windows 8.1 Upgrade, I lost the two finger tap right click feature, which worked fine previously. There is no option for it in the Dell Touchpad Settings, and after a Registry edit (Synaptics Clickpad - Right Click not working after windows 8... - HP Support Forum - 3053281) and Synaptics driver update, I got the feature back, except this time, when I tap with two fingers, it clicks both left and right, instead of only right (all other touchpad gestures work perfectly). I also tried the Two Fingers Scroll app, but did not like it. It may not be the right category to post this into, but please help. Thanking in anticipation...
    Southern California
    Windows 8.1 Pro with Media Center x64
    Out of curiosity, why would you prefer to have both buttons do the same function as a single button (ie right click)? It's like having 2 Shift keys, or 2 Control keys...
    The way I have mine set up is:
    1. Left-click = left-click
    2. Right-click = right-click
    3. Right-click+left-click = middle-click
    4. Touch-to-click = [disabled]
    What I mean by left and right click together...
    No, what I mean is that when I tap with two fingers on the trackpad, it acts as if both the right click and the left click have been pressed one after another. For example if I'm using Google Chrome and do the 'Two-Finger-Tap' gesture on a hyperlink, it shows me the right-click options menu just as I want, but the webpage start opening the new link too. It starts loading as if I had left-clicked it. And that is what the problem is... Thanks for your time, and apologies for my delayed reply... Please Help!
    Southern California
    So you are attempting to have both buttons set as a middle-click, or something similar? You just have to go to your mouse control panel for it. Your computer should have such a driver installed, and hopefully if gives the option to change buttons, and also to change gestures.
    *edit - opps, I get it now. Tapping on the pad, no actual clicking.
    Yes 'Two-Finger-TAP'
    What I'm trying to do is to set it such that when I TAP on the trackpad, it shows me the right-click option menu. And, no, there is no option in the Touchpad settings. I mean there are options for other gestures like 'Two-Finger-Scroll' or 'Pinch-To-Zoom' but no option for 'Two-Finger-Tap'. And although there was NO option for it before the Windows 8.1 Upgrade, on Windows 8, it worked just fine. After that, I tweaked the registry (tweak mentioned in the original question), and now this problem has occurred...
    Southern California
    I do not recall reading about you tweaking the registry?
    The only place I can think of with such options are located in that same section of mouse properties.
    Make sure that you have the latest windows 8.1 drivers for your computer. I would link you to the proper site, but you haven't yet filled out your system 'specs' (bottom of your last post, click My System Specs, and select Update your System Spec).
    Dell Official Site - The Power To Do More | Dell
    If the computer website doesn't list a windows 8.1 driver, your manufacturer may not have released one for your particular computer model.
    Try once more to look through that mouse trackpad section and see if you may have overlooked anything. I recommend against registry 'tweaks'. Check windows update to make sure you have the latest updates.
    *Edit - sorry mate, I'm not paying very much attention, I'll have to work on this tomorrow when I've got some sleep
    Southern California
    Sorry mate, but the only place I know of that has those settings is in the trackpad section of the mouse. Should be the first section of mouse properties, and you should be able to click the pad to get into it. If it absolutely doesn't work, double check that you have the right driver from Dell. Someone else my have to pop in to help, since I have reached the end of my knowledge on this subject.
    Southern California
    Just to be clear, you can change many different things by clicking the 4 icons, and it looks like this:
    Apologies for the delayed reply...
    Actually my Touchpad Properties Dialog Box looks like thisClick image for larger version
    And as you can see there is no Two-Finger-Tap option here...
    Thanks for your time and effort.
Hi, I want to know how I can assign left clicking the start button in Windows 8.1 to open the search bar instead of the start screen. I know that the search bar can be opened with Win+S or right click->search but I like just left clicking with my mouse once to get to search. I was thinking that...
Has anybody ever had this problem... my mouse cursor will only move when i hold either left or right click. Otherwise it doesnt move. Don't know if I'm being really thick here but I can't seem to solve this issue. If anybody can help me fix this it would be appreciated.
Not sure how else I can title this post! I have a new Dell Inspiron 15r as of this Christmas, running Windows 8. I ran the upgrade to 8.1 but I still have a problem with my cursor wanting to "hover click" on links or browser tabs, as well as being stuck in the down position, when I'm not even...
For some reason the mousepad's two finger scrolling and two finger tap for right click doesn't work for my HP laptop in the signature. At least the scrolling didn't work just earlier today but I see the two finger tap for right click is still not working
Yes, I am using a laptop, I've made sure the drivers are up to date, and no, I can still move the cursor after pressing a key, ONLY the left click is temp. disabled.
Hello, today I've noticed that I can't left click on my mousepad (but USB mice work) while pressing any key on the keyboard. This applies everywhere, desktop, apps, games, whatever. Any help? Thanks.
no mouse left-click after sleep in Drivers & Hardware
running windows8 NT, usually no problems, but sometimes after waking up from sleep, the left-click on the mouse doesn't work. (most of the time, it works after sleep.) right-click always works, even after sleep. I am using a USB microsoft wheel mouse, optical, 1.1A, kind of old, but usually works...
