Solved U.S. PC in Hong Kong, does not power
Technoir
Hong Kong
Hi,
I bought a DELL XPS Studio 9000 in the United States.
I moved it to Switzerland where I used it without an issue.
I now moved it to Hong Kong, plugged it in, but no power (monitor as well as tower). The light comes on for a second, then goes off.
Voltage can't be the issue since my pc can handle 120-240v. What could it be???
Thank you!
    Win 8
Is there a switch on the back to choose 110 or 220 ?
    Windows 8.1 Pro 64-bit
    Acer V3 771G-6443
    i5-3230m
    Acer VA70_HC (U3E1)
    8GB DDR3 PC3-12800 (800 MHz)
    HD4000 + GeForce GT 730M
    Realtek High Definition Audio
    1600x900 pixels
    Samsung SSD 850 EVO 250 GB
    ADATA SSD SP900 128GB
    90 watt brick
    Bluetooth
    Comodo
No switch.
I plugged the tower and monitor separately (I now only have 1 plug adapter). Perhaps the monitor needs to be plugged in too for the tower to start?
    Win 8
