Mouse Double Click Problem
    Windows 8 Pro
    When I single click it's actually doing a double click. It does this most of the time but not every click. Anyone else have this or heard of this problem? Could my mouse be going bad?
    Thanks
    Jim
    Windows 8.1 (x64)
    Windows 8 Pro
    I picked up another mouse and it's not doing it so my mouse must be bad.
    Jim
    Quite common problem with mice, there's a very small micro switch under the buttons that has a definitive life span. Some dirt collected under buttons could also interfere with operation and cleaning it may help.
This happens about once every 2 or 3 weeks. Suddenly (in this case I alt-tabbed from a game (Civ 5) to a web browser (Opera)), and found nothing I clicked would do anything. Except the desktop, that worked. It was as though there was a pane of glass between the cursor and all the programs. I...
mouse beeps when I click in General Support
This seems to happen on my desktop only sometimes after I have remoted into my desktop using remote desktop (tongue twister?). It used to be that it would beep whenever I move the mouse or click buttons. Clicks weren't registered. The only way to fix it was to logoff and log back on. I finally...
I have Windows 8.1 and on my desktop are several PNG files and shortcuts. When I double click on any of them the program that opens is Directory Opus (I use this instead of Windows Explorer). I checked the defaults and it is NOT Directory Opus. Can anyone help me or point me in the right...
Hello, I tried to adjust the double click speed but it has no effect. Any icon on desktop doesn't open until the third click. Once i am in my computer double clicking works fine, the issue only occurs on desktop. I suspect it is related to some program but i don't know which. Other domain...
Mouse click with keyboard key? in Software and Apps
Is there any program that lets me use a custom keyboard key to left mouse click? I tried a Autohotkey script, but many programs don't accept it, so it's very limited...
Hi all, Since 02.01.2013 my Windows 8 is rebooting without a warning, and this is happening evrey morning when I come to work, I've noticed that Windows will restart when I double click a song in Winamp, once it happened when I tried to open a e-mail in Outlook, bust mostly it happens with...
Hello there. The title says it all. I used to open music files on double click with the Music App installed in Windows. I liked that. But now it doesn't do that anymore, it just shows me empty crap when I'm offline and doesn't play automatically anymore. Why? They changed something after an...
