Surface Pro 3, Pro 2, and Pro Firmware and Driver Packs
    Surface Pro 3, Pro 2, and Pro Firmware and Driver Packs Download
    Tip   Tip
    All Surface firmware updates are released through Windows Update by default.
    Download Surface Pro 3, Pro 2, and Pro Firmware and Driver Packs
    Date Published: May 21st 2015
    Surface RT update history
    Surface 2 update history
    Surface 3 update history
    Surface Pro update history
    Surface Pro 2 update history
    Surface Pro 3 update history
    There are multiple files available for this download.Once you click on the "Download" button, you will be prompted to select the files you need.
    Win 8.1 pro / win 8.1
    I just downloaded the firmware, but I'm hesitant to install it, my surface pro is working without any problems, I'll wait for now.
    April 2014 updates
    No product updates were released for Surface RT, 2, Pro, and Pro 2 in April.
    Surface Pro, RT June 2014 updates
    • No product updates were released for Surface Pro in June.
    Surface Pro 2 June 2014 updates
    The following updates will be listed as “System Firmware Update – 6/10/2014” when you view your update history.
    • Surface Pro UEFI (v2.4.950.0) and Surface Pro Embedded Controller Firmware (v24.1.50.0) updates enhance system stability with microSD products, improves compatibility with Power Cover, and increases the reliability of sleep state transitions. Surface Pro UEFI update also provides support for PXE boot with the new Surface Ethernet Adapter.
    • Surface Pro System Aggregator Firmware (v2.4.350.0) update improves sleep state transitions when a Surface Cover is attached.
    • Surface Accessory Device (v2.0.287.0) update improves sleep state transitions when a Surface Cover is attached.
    • Surface Power Cover Firmware Update (v2.0.288.0) improves reliability when the Power Cover is attached to Surface and folded behind Surface.
    • HD Graphics Family (v10.18.10.3496) update improves Miracast wireless display experience and enhances display stability.
    Surface 2 June 2014 updates
    • Surface 2 UEFI (v4.21.500.0) update enhances overall system stability, including boot and reboot scenarios, compatibility with Surface Power Cover, and increased battery life when Surface 2 is not in use.
    • System Aggregator Firmware (v1.0.50500.0) update enhances the charging behavior of the Power Cover.
    • Surface Power Cover Firmware Update (v2.0.595.0) update improves battery life when using the Power Cover with Surface 2.
    • Surface Platform Power Driver (v2.0.557.0) update improves battery life when used with the Surface Power Cover.
    • Audio Driver Set (v 9.17.13.2819) and Display Driver Set (v 9.17.13.2818). This update provides enhanced support for external displays, improves the Miracast experience, and enhances the overall system stability while reducing power consumption in many scenarios.
    • Surface Accessory Device (v2.0.583.0) update enhances the experience when using a Surface Cover.
    In addition to the updates listed above, an additional update for Surface 2 4G LTE is listed below:
    • Wireless Network Controller (v14.62.28061.10179) and Bluetooth (v14.62.28061.10179) update simplifies and improves tethering for Surface 2 4G LTE.
    Surface RT July 2014 updates
    The following updates will be listed as “System Hardware Update – 7/8/2014” within the Windows Update History.
    Note
    When Surface updates are provided via the Windows Update service, they are delivered in stages to Surface customers. As a result, not every Surface will receive the update at the same time, but the update will be delivered to all devices. If you have not received the update, please manually check Windows Update later.
    • Surface Home Button Driver (v1.0.255.0) enhances system stability in both the active state and the sleep/wake transition state.
    Surface Pro July 2014 updates
    The following updates will be listed as “System Firmware Update – 7/8/2014” within the Windows Update History.
    Note
    • Surface Pro System Aggregator Firmware (v2.84.0350) improves battery management when a Surface Cover is attached.
    • Surface Pro UEFI (v1.6.350) provides support for PXE boot with the new Surface Ethernet Adapter.
    • Intel(R) HD Graphics 4000 (v10.18.10.3496) improves Miracast wireless display experience and enhances display stability.
    • Intel(R) Display Audio (v6.16.00.3135) enhances compatibility and improves the display experience for DisplayPort monitors.
    • Surface Accessory Device (v1.0.338.0) improves the experience when using Surface accessories.
    • Surface Power Cover Firmware update (v1.0.339.0) improves the experience when using Surface Power Cover.
    Surface Pro 2 July 2014 updates
    Note
    • Wireless Network Controller (v 14.69.24054.176) enables functionality on wireless networks utilizing hidden SSIDs.
    Surface Pro 3 July 2014 updates
    Note
    • Surface Pro Embedded Controller Firmware (v.38.2.50.0) reducing power consumption, and enhancing system stability.
    • Surface Pro System Aggregator Firmware (v. 3.8.250.0) enhancing battery life, and increasing efficiency and reliability in low power states.
    • Surface Type Cover Firmware Update (v. 2.0.1021.0) improving trackpad reliability and system stability.
    • Surface Accessory Device (v. 2.0.1012.0) helping the on-screen keyboard (OSK) appear and disappear at the correct times.
    • Wireless Network Controller and Bluetooth (v. 15.68.3042.79) enhancing system stability, reducing power consumption in low power states, and improving some WiFi connection scenarios. Look for another WiFi update coming soon.
    • We will also issue an update on Wednesday, July 16, to further improve Wi-Fi connection and throughput scenarios.
    Hafnarfjörður IS
    Hi Brink
    Thanks for the Surface Pro 3 update --currently my device seems to be working fine no probs with OSK for the keyboard etc so far-- I'm a bit of an old fashioned engineer in these cases --"If it ain't broke - don't fix it".
    The device performs far better than I ever expected -- Ms should have a real winner for this one even though by a lot of people's standards the device is not cheap.
    Cheers
    jimbo
    Surface Pro 3 July 16 release
    The following updates will be listed as “System Firmware Update – 7/16/2014” or “System Hardware Update – 7/16/2014” when you view your update history.
    Note
    When Surface updates are provided via the Windows Update service, they are delivered in stages to Surface customers. As a result, not every Surface will receive the update at the same time, but the update will be delivered to all devices. If you have not received the update then please manually check Windows Update later.
    • Surface Integration (v.2.0.1038.0) further enhances system stability.
    • Wireless Network Controller and Bluetooth (v. 15.68.3044.85) further improving WiFi connection and throughput scenarios.
    Surface 2 July 22 release
    The following updates will be listed as “System Firmware Update – 7/22/2014” or “System Hardware Update – 7/22/2014” when you view your update history.
    Note
    This update is only available for Surface 2 4G LTE:
    • Modem Firmware Update (v. 5.706.306.2) improves the reliability of the Surface 2 4G LTE on the AT&T 4G LTE network.
    Surface Pro August 2014 updates
    The following updates will be listed as “System Firmware Update – 8/12/2014” or “System Hardware Update – 8/12/2014” when you view your update history.
    Note
    • Wireless Network Controller and Bluetooth (v14.69.24054.176) improves network connection stability and enables functionality on WiFi networks using a hidden SSID.
    Surface RT August 2014 updates
    The following updates will be listed as “System Firmware Update – 8/12/2014” when you view your update history.
    Note
    • Surface RT UEFI (v3.31.500) enhances overall system stability.
    Surface Pro 3 August 2014 updates
    Note
    • Surface Pro UEFI (v3.9.150.0) adds features to display BIOS password state and asset tag information, as well as improving boot times in some scenarios
    • Surface Pro Embedded Controller Firmware (v38.4.50.0) improved support for Surface Power Cover.
    • Surface Pro System Aggregator Firmware (v3.9.250.0) improved support for Surface Power Cover and enhances overall system stability.
    • Microsoft LifeCam Front (v5.20.1034.0) significantly improves power consumption during video chat such as Skype, supports Flash camera streaming in Internet Explorer, and improves overall functionality and stability.
    • Surface Ethernet Adapter (v8.14.0704.2014) improved support for the gigabit Surface Ethernet Adapter.
    Surface Pro 3 September 2014 updates
    The following updates will be listed as “System Firmware Update – 9/9/2014” when you view your update history.
    Note
    • Surface Pro UEFI update (v3.10.250.0) improves system experience and enhances overall system stability, including Wi-Fi.
    • Surface Pro Embedded Controller Firmware update (v38.6.50.0) enhanced support for system performance and user experience, including thermostat icon on boot.
    • Surface Pro System Aggregator Firmware update (v3.9.350.0) increases the overall system reliability and compatibility with a Surface cover.
    • Surface Integration driver update (v2.0.1102.0) enhances user experience, including Wi-Fi stability.
    • Surface Wi-Fi and Bluetooth driver update (v15.68.3055.107) improves Wi-Fi/ Bluetooth reliability and system stability, and significantly enhances the user experience.
    Surface Pro 3 October 28th 2014 updates
    The following updates will be listed as “System Firmware Update – 10/28/2014” when you view your update history.
    Note
    •Surface Pro UEFI update (v3.11.250.0) enhances the system stability, increases the reliability of the graphics display performance, and adds a status bar to the experience when applying future System Firmware Updates.
    •Surface Pro Embedded Controller Firmware update (v38.7.50.0) increases the reliability of sleep state transitions with a Surface Pro 3 Docking Station connected.
    •Surface Integration update (v2.0.1168.0) addresses setting the Hibernate value in Windows 10.
    •Intel(R) 8 Series PCI Express Root Port #3 - 9C14 update (v2.0.1151.0) addresses cases when the Wi-Fi adapter is not available upon resuming the system from sleep.
    •Wireless Network Controller and Bluetooth driver update (v15.68.3059.117) improves Wi-Fi throughput, especially after rebooting with Bluetooth devices that are paired, enhances power consumption situations, and addresses instances of system instability.
Page 1 of 3 123 LastLast
Read more at: Surface Pro 3 buyers to get firmware update on Day 1 | ZDNet
Read more at: Microsoft rolls out multiple March firmware updates for its Surface tablets | ZDNet
Read more at: Some Microsoft Surface Pro 2 users report a firmware fix rolling out | ZDNet
Read more at: Microsoft issues fix for a Surface Pro firmware glitch | ZDNet
Read more at: Microsoft delivers August firmware, driver updates for Surface RT, Pro | ZDNet See also: Microsoft Surface RT update history | Windows Update | Surface RT updates
Deploying Drivers and Firmware to Surface Pro - The Deployment Guys - Site Home - TechNet Blogs A Guy
Read more at source: Microsoft to roll out April firmware updates for Surface RT and Pro | ZDNet
