Surface Pro 3, Pro 2, and Pro Firmware and Driver Packs
  1. #11
    Surface Pro 3 November 18th 2014 updates
    The following updates will be listed as “System Firmware Update – 11/18/2014” within the Windows Update History
    Note
    When Surface updates are provided via the Windows Update service, they are delivered in stages to Surface customers. As a result, not every Surface will receive the update at the same time, but the update will be delivered to all devices. If you have not received the update then please manually check Windows Update later.
    • Surface Pro UEFI update (v3.11.350.0) enhances the system stability, optimizes the boot time with fast boot enabled, and resolves date and time accuracy when the battery level falls below 3%. Also addresses compatibility with McAfee Defense Encryption 7.1.1.
    • Surface Home Button driver update (v2.0.1174.0) enables future functionality for the Surface Hub app.
    • Surface Pen Settings driver update (v2.5.14.0) enables future functionality for the Surface Hub app.
    • Wireless Network Controller and Bluetooth driver update (v15.68.3066.135) enhances Wi-Fi throughput, especially after waking up from Connected Standby, reduces instances of system instability, increases the connectivity performance and also addresses connectivity while using 5ghz DFS channel.
  2. #12
    Surface Pro January 2015 updates
    Note
    • Surface Pro UEFI update (v1.7.50) further enhances the system security.
    Surface Pro 2 January 2015 updates
    Note
    When Surface updates are provided via the Windows Update service, they are delivered in stages to Surface customers. As a result, not every Surface will receive the update at the same time, but the update will be delivered to all devices. If you have not received the update, please manually check Windows Update later.
    • Wireless Network Controller (v14.69.24054.176) enables functionality on wireless networks utilizing hidden SSIDs.
    Surface Pro 3 January 2015 updates
    Note
    • Surface Pro UEFI update (v3.11.450.0) adds support for updated HD Graphics Family driver.
    • HD Graphics Family driver update (v10.18.14.4029) enhances display stability and performance, improves user experience when using Miracast adapters. Improves compatibility with DisplayPort monitors and daisy chaining.
    • Wireless Network Controller and Bluetooth driver update (v15.68.3073.151) addresses connectivity issues while Hyper-V is enabled. Adds an advanced feature to control the 2.4Ghz and 5Ghz band preference.
    • Surface Home Button driver update (v2.0.1179.0) ensures compatibility with the Surface Hub app.
    • Microsoft Docking Station Audio Device driver update (v1.31.35.7) improves the user experience while using the Surface Pro 3 Docking Station so that sound is available when a speaker is not connected to the docking station.
  3. #13
    Surface Pro 3 March 26th 2015 updates
    The following updates will be listed as “System Firmware Update – 3/26/2015” when you view your update history.
    Note
    • Surface Pro UEFI (v3.11.760.0) adds support for enterprise disk encryption, enhances the advanced configuration settings for device security, and adds configurable support from the Windows OS for provisioning scenarios.
    Surface Pro 3 March 10th 2015 updates
    The following updates will be listed as “System Firmware Update – 3/10/2015” or “System Hardware Update – 3/10/2015” when you view your update history.
    Note
    • Surface Pen Settings driver update (v3.0.64.0) enables new functionality and features for the Surface app found in the Windows Store.
  4. #14
    I am Woman! Hear Me Roar!
    NJ
    4 Windows 7 Pro Sp1- 4 Win 8 Pro, 1- xp pro sp3
    I just got a firmware update for my surface pro 3, wonder if it is in for preperstion for 10
  5. #15
    Hey Robin,
    Hopefully Microsoft will update the history page soon for the new firmware.
    Microsoft Surface Pro 3 update history | Surface firmware updates
  6. #16
    Surface Pro 3 April 30th 2015 updates
    Note
    • Surface Type Cover Filter Device update (v2.0.1193.0) enables full support for Japanese Surface Pro Type Covers.
    • Surface Pen Settings driver update (v4.0.112.1) enables new functionality with the Surface app, available for free in the Windows Store.
  7. #17
    Surface Pro 2 May 2015 updates
    The following updates will be listed as “System Firmware Update – 5/19/2015” within the Windows Update History
    Note
    • Surface Pro UEFI update (v2.5.250.0) includes changes needed for compatibility with the updated graphics driver.
    • HD Graphics Family driver update (v10.18.14.4170) improves graphic performance and includes better Miracast (wireless display) support.
    • Display Audio driver update (v6.16.00.3172) improves audio experience and supports compatibility with the updated graphics driver.
    Surface Pro 3 May 2015 updates
    Note
    • •Surface Pro 3 UEFI update (v3.11.850.0) includes changes needed for compatibility with the updated graphics driver.
    • •HD Graphics Family driver update (v10.18.14.4170) improves graphics performance and includes better Miracast (wireless display) support.
    • •Display Audio driver update (v6.16.00.3172) improves audio experience and supports compatibility with the updated graphics driver.
  8. #18
    Surface 3 June 23rd 2015 updates
    The following updates will be listed as “System Firmware Update – 6/23/2015” when you view your update history.
    Note
    • Surface System Aggregator Firmware update (v1.0.49500.0) improves the experience while using the Surface Cover.
    • Audio Device driver update (v603.9600.2563.61816) enhances audio performance and improves the audio experience on Surface 3.
    • Camera driver update (v20.9600.3444.120) enhances the image and video quality while using camera.
    • HD Graphics driver update (v10.18.14.4175) improves the display stability and graphics performance.
    • Wireless Network Controller and Bluetooth driver update (v15.68.3091.193) improves the system stability and the Wi-Fi connectivity experience, also increases the network download performance.
    Surface Pro 3 June 23rd 2015 updates
    Note
    • Surface Pro UEFI update (v3.11.950.0) adds support for new features in Windows 10.
    • SATA AHCI Controller driver update (v9.4.0.1028) stabilizes deployment methodology on Surface Pro 3.
  9. #19
  10. #20
    The following updates will be listed as “System Firmware Update – 7/23/2015” when you view your update history.
    Note
    This update is available only for Surface 3 (4G LTE):
    • Surface UEFI update (v1.50410.218.0) improves mobile broadband network connectivity.
    • USB 3.0 Host Controller Adaptation driver update (v603.9600.2588.2097) improves mobile broadband network connectivity.
    • USB Composite Device driver update (v2.0.268.0) improves mobile broadband network connectivity.
    • Surface_IA7260.inf update driver for delivering future updates and refreshing production software signing.
    • Surface CoSAR driver update (v2.0.270.0) improves mobile broadband network connectivity.
    Surface Pro 3 July 23rd 2015 updates
    Note
    No product updates were released for Surface Pro 3 running Windows 8.1 in July.
    Windows 10
    • HD Graphics Family driver update (v10.18.15.4248) improves graphics performance and stability on Windows 10.
    • Audio driver update (v6.0.1.7543) improves the Cortana experience on Windows 10.
    • USB driver update (v10.0.10125.31214) improves system power usage.
Read more at: Surface Pro 3 buyers to get firmware update on Day 1 | ZDNet
Read more at: Microsoft rolls out multiple March firmware updates for its Surface tablets | ZDNet
Read more at: Some Microsoft Surface Pro 2 users report a firmware fix rolling out | ZDNet
Read more at: Microsoft issues fix for a Surface Pro firmware glitch | ZDNet
Read more at: Microsoft delivers August firmware, driver updates for Surface RT, Pro | ZDNet See also: Microsoft Surface RT update history | Windows Update | Surface RT updates
Deploying Drivers and Firmware to Surface Pro - The Deployment Guys - Site Home - TechNet Blogs A Guy
Read more at source: Microsoft to roll out April firmware updates for Surface RT and Pro | ZDNet
