Solved mouse double click does not work in desktop
Majed17
Hello, I tried to adjust the double click speed but it has no effect.
Any icon on desktop doesn't open until the third click. Once i am in my computer double clicking works fine, the issue only occurs on desktop.
I suspect it is related to some program but i don't know which. Other domain users on the computer do not suffer from this problem.
i tried disabling lots of things from startup like babylon, ashampoo hdd control, bwmeter, desktop 8gadgets but it didn't help.
I don't know when this problem started to occur.
Earlier i installed mcos lion transformation pack and uninstalled it. It had caused notifications not to come on office 2013. Maybe it could have some how influenced this problem. anybody has any ideas to fix this?
    win 8 64bit
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Package Socket FT1 BGA
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
    Avast Internet Security
well this is the default .. i could switch to single click but i'd rather solve the problem.
to your quote i'd reply: do not hold the word if it is of benefit.
    win 8 64bit
Try running Windows Restore to restore to a point before you installed the Transformation pack (If the restore point exists) and see if that solves your issue.
    Windows 7 Home Premium x64
    Hewlett Packard P7-1017c
    Intel Core i3-2100 @ 3.1Ghz
    Pegatron HP
    Crucial 2x4GB DDR3 1333 MHz
    Sapphire Radeon HD 7850 2GB GDDR5
    Realtek HD Onboard
    HP 2211x
    Hitachi 1TB 7200 RPM
    Corsair CX600 80+ Bronze
    Coolermaster HAF 912
    Stock Intel Fan
    HP Keyboard
    HP Mouse
    30+ Mbps Download; 2Mbps Upload
    Norton 360
    New build with custom parts later in the year
Good idea :)
however when i searched for restore points a point only 2 dats ago exists and the transformation pack was installed about 3 months ago so that won't work.
thanks for the idea anyway :)
    win 8 64bit
Your welcome, I try to help as much as I can :), see if there might be a process in task manager that could be causing the issue.
    Pegatron HP
    Realtek HD Onboard
    HP 2211x
    Stock Intel Fan
    HP Keyboard
    HP Mouse
    Norton 360
wow thanks for the tip.. all those years of computer experience and i lack imagination and troubleshooting inovation. it turns out it was the team viewer process. Once terminated icould double click again :). i put it service in manual start up so it doesn't run and it seems i should drop them an email.
I think you are getting your rewards in heaven.
    win 8 64bit
i misgudged. it was because of the punto switcher program and the problem disappears after i exit the progam, so i sent their support an email, hopefully they will answer.
    win 8 64bit
I'm glad that your problem was fixed :), good going with the email hopefully they will fix the bug.
    Pegatron HP
    Realtek HD Onboard
    HP 2211x
    Stock Intel Fan
    HP Keyboard
    HP Mouse
    Norton 360
they replied that they are aware of the issue and maybe they will solve it in the next version, meanwhile i am stuck with the alt-shift key in switching languages.
    win 8 64bit
