Solved Audio channels reversed using USB
highstream
Not sure if this is a hardware or Win 8 problem. I've now run four dacs off two USB 2.0 ports and each has had the channels reversed, per the Windows 8 Sound test among others. There is no problem with the Dacs - I've checked elsewhere - and the interconnects from the Dacs have run to the proper speakers. One of the USB ports I've used belongs to the mobo and the other to a USB add-in card. So, where is the likely fault, on the mobo or within Windows? It's not the biggest deal - no problem switching channels - but I'd like to figure out what's behind it. Thanks,
Update: From some further exchanges, it seems some or all dac makers set up speaker interconnect ports looking from the back rather than the front. Screwy, since that means crossing wires if the unit is facing forward.
    Win 8.1 Pro x64
    DIY
    i5 4690K
    Gigabyte GA-Z97X-UD5H-BK3 (rev. 1.2) UEFI Bios
    16 GB (4x4)
    Sapphire Ultimate HD7750
    JCAT USB
    Dell U2412M
    1920x1200
    Samsung 850 Pro 256 GB SSD
    Seagate 3TB, 2TB & 1TB HDDs
    Seasonic x650 PSU
    Cooler Master Elite 335
    Prolimatech Megahalems Rev. C cooler, 3 Nexus Silent Fans
    IBM Model M
    Bornd Wireless Mouse
    60+ mbps claimed
    Comodo CIS, MBAM Pro
    PS Audio Directstream dac, Quad 12L powered speakers, Core Audio Tech Kora LPS, JCAT USB card, Uptone Regen USB
