Please help wireless network problem
    Windows 8 Pro Build 9800
    Hello, I just upgraded from Win7 64x to Win 8 pro Build 9800 x64 last night and ever since I cannot connect or even see any wireless networks listed. Nor is my wireless network adapter show up anywhere including the device manager. The device manager shows two unknown devices here are the descriptions it shows: 1) Network Controller Unknown manufacturer Location PCI bus4 device 1 function 0 Status The drivers for this device are not installed.
    2) Unknown device Unknown manufacturer Location on Intel(r) 82801GB/GR (ICH7 Family) LPC Interface Controller - 27B8. I have tried downloading drivers, I have been using the ones from these links. Btw my wireless card is a TRENDnet TEW-643PI.
    TRENDnet | Downloads | Wireless | TEW-643PI
    and
    ASUS - Motherboards- ASUS P5KPL-CM
    This article might help. Searching on "wireless network adapter Windows 8 connect" might help. And, you should be able to buy a new one that is compatible with Win8 for not many dollars.
    didnt help Ive already tried that.
    Tampa Bay
    MS Windows 8.1 Pro 64-bit with WMC
    Quote Originally Posted by rogersdr01 View Post
    Your are welcome.
    abseh1 yes i have thank you though, thats the same link I have in my first post except for some reason the link title way automatically changed.
    Sydney, Nova Scotia, Canada
    Windows 10 Education 64 Bit
    It sucks but you may be better off just buying a new (Windows 8 compatible) wireless card. You could also try reseating the card in it's slot, or even moving it to a different slot on the motherboard. Windows may redetect it and actually identify it properly. If you are trying to install a Windows 7 driver try compatibility mode and running the installer as Administrator.
    Tampa Bay
    Give their support a land line call
    https://www.trendnet.com/store/customer_service/
Create second wireless network in Network & Sharing
My friend has a switch connected to his modem. There are about 6 computers on the switch, and those computers share files and printers. He also has a wireless router connected to the switch, it creates its own network that does not have access to the files that are shared on his main network, and...
This is a random issue, sometimes I can connect just fine, and usually a restart of my laptop lets me connect. However sometimes when I try to enter the password it does not work. I get the error message 'the network security key is not correct. Please try again.' I know for a fact that my...
This morning I installed an optional update from Windows Update. It was Ralink Technology WLAN 802.11 wireless LAN card. Since then, when I try to print to my wireless network printer, the network would disconnect then come back on after a while. The update shows up in Update History as...
Hello, I have a Tablet PC with Windows 8 Release Preview installed. The Tablet PC is equipped with a x86 Intel Atom Z670 processor and the Marvell 88w8787 Wifi/Bluetooth chip. (Also ref. as AZUREWAVE_AW-NM387 WiFi/Bluetooth) Previously, Windows 7 installed with wifi connection was working...
Good Morning, I am literally the new kid on the block. I just joined about five minutes ago. I have two Toshiba laptops on my wireless network. We have one set up as the master, and one is set up as the slave. I use A windows database program for inventory control. I thought we had it set...
My wireless card in my Compaq Presario works fine and Windows 8 detects it and said it was compatible. For some strange reason though it's not working in Windows 8. It hasn't detected my wireless network. Currently I am connecting using a cable. The card is Qualcomm Atheros AR5007 802.11b/g WIFI...
No wireless network in Network & Sharing
As an admin I can connect to wireless networks but guest users get the error message of no incoming connections.any ideas on how to fix this....
