Please help wireless network problem
rogersdr01
Hello, I just upgraded from Win7 64x to Win 8 pro Build 9800 x64 last night and ever since I cannot connect or even see any wireless networks listed. Nor is my wireless network adapter show up anywhere including the device manager. The device manager shows two unknown devices here are the descriptions it shows: 1) Network Controller Unknown manufacturer Location PCI bus4 device 1 function 0 Status The drivers for this device are not installed.
2) Unknown device Unknown manufacturer Location on Intel(r) 82801GB/GR (ICH7 Family) LPC Interface Controller - 27B8. I have tried downloading drivers, I have been using the ones from these links. Btw my wireless card is a TRENDnet TEW-643PI.
TRENDnet | Downloads | Wireless | TEW-643PI
and
ASUS - Motherboards- ASUS P5KPL-CM
    Windows 8 Pro Build 9800
    Custom Build
    Intel(R) Core(TM) 2 Duo CPU E8500 @ 3.16GHZ
    ASUS P5KPL-CM Intel G31 Chipset
    4GB DDR2
    ATI Radeon HD 5800
This article might help. Searching on "wireless network adapter Windows 8 connect" might help. And, you should be able to buy a new one that is compatible with Win8 for not many dollars.
    ASUS P8P67 Deluxe Rev B3
    16 GB Corsair Vengeance
    EVGA 570 SC
    Gateway
    Dual Boot:
    Cooler Master 932 HAF
    Zalman CNPS9900MAX-B CPU Fan
didnt help Ive already tried that.
    Custom Build
    4GB DDR2
    ATI Radeon HD 5800
    MS Windows 8.1 Pro 64-bit with WMC
    Custom
    Intel Core i5 650 @ 3.20GHz X4
    H57M01
    8.00 GB Dual-Channel DDR3 @ 665MHz
    Nvidia GeForce GTX 550TI Superclocked
    2 ...1T each
    750 Corsair
    wireless
    wireless
    60Mbps tested @ 68.92Mbps/5.87Mbpsbps
    EVGA 570 SC
    Gateway
    Dual Boot:
abseh1 yes i have thank you though, thats the same link I have in my first post except for some reason the link title way automatically changed.
    Custom Build
    4GB DDR2
    ATI Radeon HD 5800
It sucks but you may be better off just buying a new (Windows 8 compatible) wireless card. You could also try reseating the card in it's slot, or even moving it to a different slot on the motherboard. Windows may redetect it and actually identify it properly. If you are trying to install a Windows 7 driver try compatibility mode and running the installer as Administrator.
    Windows 10 Education 64 Bit
    Asus
    Thermaltake TR 620
    Stock heatsink fan
    Logitech Wireless K350 Wave
    80 Mbps Down 30 Mbps Up
    Custom
    H57M01
    2 ...1T each
    750 Corsair
    wireless
    wireless
