I've had problems with freezing while using chrome - random freezes after 5-20 minutes of having chrome running (preconfigured with my google account).
Logs completely clean, so it's pretty much impossible to find out anything this way.
Disabling all hw acceleration didn't help (I am using intel's HD4000 which is known to have issues with chrome - ivy bridge cpu's) , so i swapped to firefox and everything was fine...
Until i installed adblock. From that moment system started freezing even without running chrome. (time to freeze was much longer than under chrome thou, but already it happened 5 times)
Now i came back to chrome, but with disabled add-ons (for troubleshooting, will try to re-enable some of them over the next few days) and for the last hour of heavy use of browser, no freezes at all.
In theory - there are 2 different plug-ins (adblocks for chrome and ff), from different developers, but seems like they're causing problems. so here can be the issue with windows 8. I'm goin to investigate it, but it will be great if somebody else could confirm it.
- 8 Pro + MCP
- System Manufacturer/Model
- DIY
- CPU
- core i7 3770K @ 4.8GHz
- Motherboard
- ASUS Sabertooth Z77
- Memory
- Crucial Ballistix Elite 4x4GB 1866CL9
- Graphics Card(s)
- intel HD4000/integrated
- Sound Card
- 7.1/integrated
- Monitor(s) Displays
- 23" IPS Calibrated
- Screen Resolution
- 1920x1080
- Hard Drives
- OCz Vertex3 60GB SSD
WD Scorpio Blue 500GB
WD Caviar Blue 500GB
Seagate Momentus 160GB
Hitachi TravelStar 160GB
- PSU
- OCz ModXStream
- Case
- modded CM Cosmos S
- Cooling
- DIY watercool
- Keyboard
- Roccat ISKU, Razer Nostromo
- Mouse
- Razer Orochi
- Other Info
- I build, tune, mod and overclock.
Want a really cool rig? I can do it for any budget!
