Driver State Power Failure - Noticeably when charging
Melling11
Hello,
I have noticed a post that shares an identical description to my own here, but after reading it, the solution seems to be very much down to the interpretation of a unique dump file, so I am posting hoping that someone may be able to provide a similar level of insight. In short, sorry for the same description, but I cannot think of a better way of wording it.
The problem started today and I have also noticed the problem only occurs when the power cable is plugged in and the laptop is charging.
I have looked around the internet for probable cause to this issue, most point at driver issues, but I am not exactly sure how to pin point the malfunctioning driver. I have tried unistalling Nvidia drivers with DDU in Safe Mode (recommended method for cleanly unistalling drivers) and then reinstalling them. I have also tried rolling back to previous driver versions but the problem persists.
Attached is my DM Log.View attachment 65264
Any help beyond this point would be greatly appreciated.
    PC SPECIALIST (CLEVO??)
    i7-4710MQ
    16 GB
    Nvidia GTX 970m
    Avira
Hi Melling11,
Welcome to the 8forums.
The causes of the crashes are the Nvidia Video driver and the Intel Rapid Storage Technology.
I guess you already have the IRST driver up to date with the drivers from your manufacturer.
Please try following and see if it works:
  • Press windows logo + r, type services.msc and press enter
  • Search Nvidia Streaming Kernel Service or Nvidia Streamer Service
  • Right click > properties and change the startup type to manually
  • Search the IRST service > right click > properties > change startup type to manually
Nvidia Video driver date
6: kd> lmvm nvlddmkm
fffff801`4a86c000 fffff801`4b2a4000   nvlddmkm T (no symbols)
    Loaded symbol image file: nvlddmkm.sys
    Image path: \SystemRoot\system32\DRIVERS\nvlddmkm.sys
    Image name: [U]nvlddmkm.sys[/U]
    Timestamp:        [COLOR=#ff0000][U]Wed Apr 08 22:32:37 2015[/U][/COLOR] (55259065)
    CheckSum:         009F7AE7
    ImageSize:        00A38000
    Translations:     0000.04b0 0000.04e4 0409.04b0 0409.04e4
Intel Rapid Storage Technology driver data
6: kd> lmvm iastora
fffff801`49255000 fffff801`4950b000   iaStorA  T (no symbols)
    Loaded symbol image file: iaStorA.sys
    Image path: \SystemRoot\System32\drivers\iaStorA.sys
    Image name: [U]iaStorA.sys[/U]
    Timestamp:        [COLOR=#ff0000][U]Mon Oct 28 22:15:26 2013[/U][/COLOR] (526ED3EE)
    CheckSum:         0009FA1B
    ImageSize:        002B6000
    Windows 10 Pro
    Custom build
    i5-6500 @3.20GHz
    Gigabyte B150-HD3P-CF
    16GB DDR4 2133 Crucial Ballistix Sport LT
    MSI GeForce GTX 1060 GAMING X 6G
    Built-in
    Liyama ProLite XB2483HSU-B2
    Crucial MX200 500GB & Toshiba DT01ACA300 3TB
    Corsair RM550x
    Fractal Design Define S
    Cooler Master TX3 i
    Func KB-460 (MX Red)
    Corsair Gaming M65 RGB
    Bitdefender Total Security 2017 + MBAM Pro + MBAE Pro
    Creative Sound Blaster Tactic3D Rage V2 headset
Almost forget
The Intel Wifi driver has also been flagged
Please check your manufacturer and make sure you have all the driver updates
7: kd> lmvm NETwbw02start             end                 module name
fffff800`3d00a000 fffff800`3d391000   NETwbw02   (deferred)
    Image path: \SystemRoot\system32\DRIVERS\NETwbw02.sys
    Image name: [U]NETwbw02.sys[/U]
    Timestamp:        [COLOR=#ff0000][U]Thu Sep 19 09:40:12 2013[/U][/COLOR] (523AAA5C)
    CheckSum:         0037696E
    ImageSize:        00387000
    Windows 10 Pro
    Custom build
    i5-6500 @3.20GHz
    Built-in
    Corsair RM550x
    Cooler Master TX3 i
Hello axe0,
Thank you for your prompt reply, it is greatly appreciated.
I have not updated Intel Rapid Storage drivers, I will try these immediately.
NB: Whilst writing, I downloaded the Intel Driver Utility, no mention of an IRST driver, but ones do exist for HD graphics driver, bluetooth and wireless, I have updated those.
I have looked at the services list and have set the IRST to manual start. Neither of the Nvidia ones exist; I image these are related to the Nvidia Geforce Experience, which I have chosen not to install.
Should I restart my computer?
EDIT: It may also be worth noting that my computer has incurred no BSOD whilst the not on charge.
    i7-4710MQ
    16 GB
    Nvidia GTX 970m
    Avira
A quick tip about intel driver utility and laptops.
You should not use this program to update drivers from Intel, this because there are drivers specifically for your laptop available at your manufacturers site.
Please go to your manufacturers site and install all the drivers from there only.
    Windows 10 Pro
    Custom build
    i5-6500 @3.20GHz
    Built-in
    Corsair RM550x
    Cooler Master TX3 i
Thanks for the advice, I went back and reinstalled the drivers from Clevo including a WLAN driver, however this was from Realtek; no mention of an Intel Wireless Link Driver on the Clevo site. Would you advise installing the Intel Wireless Link Driver from the Utility previously mentioned considering non are present on the Clevo site?
I tried re-installing the latest Nvidia drivers (355.82). no crashes occurred, but I did notice that my laptop charging light was not on, suggesting that the laptop battery was not charging, despite being plugged in and displaying 50% battery; strange.
I installed older drivers (353.62) to see if it made a difference. These drivers gave me no issues with the power light etc. however I have now noticed my laptop charger gets incredibly hot when gaming, so much so that you cannot hold it with your bare hands without likely burning your fingers. I also noticed the cables velcro strap has been singed badly and I do recall a funny smell the other night...
I believe the problem is partly related to the driver update and some mechanical fault with either my laptop charger, charging port or battery. As the BSOD issues have stopped, I'd imagine this post can be closed.
I intend to claim on the warranty and have the laptops power interface investigated. If it's considered useful I can update this post in the future when I learn more about the issue? I though it may be useful for future issues etc.
Anyway, thanks for the help, axe0, greatly appreciated.
    i7-4710MQ
    16 GB
    Nvidia GTX 970m
    Avira
No I would never advise to update a driver via a program, your manufacturer should provide you the correct driver.
It is their duty as manufacturer of your laptop to give you the correct drivers.
About the power charging problem I can't really help you, but it sounds like a driver conflict with nvidia,
You're welcome :)
    Windows 10 Pro
    Custom build
    i5-6500 @3.20GHz
    Built-in
    Corsair RM550x
    Cooler Master TX3 i
