BSOD everyday, sound issues, Driver Power State Failure?
    i'm new to these forum style help so please bear with me, i'll provide what ever information your software did not get.
    i'll outline the common faults/happenings
    • BSOD code Driver Power State Failure
    • audio static and rarely high pitch squeal (i've removed the built in speaker because i couldn't tolerate it anymore, could be temporarily fixed by tapping the surface area but it can cause a freeze/BSOD or no audio output 50/50 chance whether lucky or not)
    • visual on screen fails to properly display(haven't tested if it still happens when i use the vga output yet but will next time)
    • laptop freezes (can only be fixed by holding power button to power off, then normal startup, or if lucky a light tap above the harddrive)
    • Caps lock and num lock lights flash, 5 times)
    • sound drive fails to load(i get a notification when the desktop has fully loaded icons and tiles)
    • videos will speed up, audio included
    • USB ports will not recognise devices, 10101 serial port(with 2 adpaters serial > ps/2 > USB) pushes out too much power for usb devices) My USB devices are Nokia 520 cellphone, WD external HD, USB mini camera.
    My computer habits
    • always on it everyday
    • i use Google Chrome(with extensions)
    • i use facebook a lot just to play games and watch videos
    • i also use youtube a lot as well as anime streaming sites
    • i leave the power cord in and turned on at wall, even when going to sleep
    i think that is basically it. I hope that it is something that can be fixed through software changes.
    Attachment 58025
    UPDATE: Screen now fails to respond, i suspect the display inverter as it has felt warm there and that only the display isnt working at all now, i am now using the VGA port and so far it is running ok thought it still fails to recognise USB devices.
    Please help, should i just throw this laptop off a cliff and get a new one in the distant future or can i fix this.
    India
    Windows 8.1 Industry Pro B-)
    Hi Kaboose79 & Welcome to the forums ^_^,
    I am really sorry for the delay in response. Life is very busy for everyone in the BSOD section
    The ZIP file uploaded by you is Empty. Kindly follow the instructions again and re-upload the freshly generated Diagnostic ZIP file. Also, kindly do not touch any components of the system, since it is very dangerous. Did you try removing the Graphics Card and using the inbuilt graphics processing unit?
    Let me know how it goes ^_^
    -Pranav
    i believe the graphics card is inbuilt on this laptop motherboard, i think i will stay away with the soldering iron.
    As i said the VGA port works so i believe it may be in the screen itself(well one fault is). is the anyway to test and determine where the inbuilt devices are and arent connecting right?
    here is a new file, if this doesnt work then i may need idiot instructions .-.
    Attachment 58278
    Windows 10 Pro x64
    Zip file is empty.
    Frustrating, can you tell me what it should contain. i'll get it myself and make a zip
    Windows 10 Pro x64
    It should contain dump files. Look for them in Windows/ Minidump directory and diagnoostics like your startup items, services, dxdiag report, systeminfo, startup items...
    this should do it.
    Attachment 58306
    Windows 10 Pro x64
    Update drivers in red Bluetooth drivers, and run HW Diag: HW diag: Hardware Diagnostics
    Monitor your PC for crashes. If taht doesn't help, please enable this: Driver Verifier: Driver Verifier - BSOD related - Windows 10, 8.1, 8, 7 & Vista - Sysnative Forums
    agrsm64.sys Mon Nov 10 16:01:35 2008  (49184CCF)
    Agere Systems Soft Modem
    http://www.carrona.org/drivers/driver.php?id=agrsm64.sys
    HpqKbFiltr.sys  Wed Apr 29 15:48:30 2009 (49F85AAE)
    HP Quick Launch Buttons  HpqKbFiltr Keyboard Filter driver
    http://www.carrona.org/drivers/driver.php?id=HpqKbFiltr.sys
    ADIHdAud.sys  Mon May 18 19:31:55 2009 (4A119B8B)
    SoundMAX Digital HD Audio  Driver
    http://www.carrona.org/drivers/driver.php?id=ADIHdAud.sys
    cpqbttn.sys  Tue Feb 23 21:44:48 2010 (4B843E40)
    HP Tablet PC Key Button HID  Driver - HP Quick Launch Buttons
    http://www.carrona.org/drivers/driver.php?id=cpqbttn.sys
    SynTP.sys Fri  Jun 4 03:27:13 2010 (4C085671)
    Synaptic Touch Pad Driver
    http://www.carrona.org/drivers/driver.php?id=SynTP.sys
    NETwNs64.sys Thu  Oct 6 16:45:03 2011 (4E8DBEEF)
    Intel(R) Wireless WiFi Link 5000  Series Adapter Driver for Windows 7
    http://www.carrona.org/drivers/driver.php?id=NETwNs64.sys
    igdkmd64.sys Fri Mar 23 19:13:22  2012 (4F6CBD42)
    Intel Graphics driver
    http://www.carrona.org/drivers/driver.php?id=igdkmd64.sys
    hpdskflt.sys Mon Sep 24 17:31:14  2012 (50607CC2)
    HP Mobile Data Protection System Disk Filter
    http://www.carrona.org/drivers/driver.php?id=hpdskflt.sys
    Accelerometer.sys Mon Sep 24  17:31:45 2012 (50607CE1)
    HP Mobile Data Protection System Accelerometer
    http://www.carrona.org/drivers/driver.php?id=Accelerometer.sys
    b57nd60a.sys Tue Mar 26  01:14:03 2013 (5150E84B)
    Broadcom NetXtreme Gigabit Ethernet
    http://www.carrona.org/drivers/driver.php?id=b57nd60a.sys
    intelppm.sys Thu Aug 22 10:46:35  2013 (5215CFEB)
    Intel Processor driver
    BthHfAud.sys Thu Aug 22 13:38:26  2013 (5215F832)
    Bluetooth Hands-free Audio Device Driver - uncertain if this  is a Windows driver or a 3rd party bluetooth driver. See bthav.sys for more  speculation
    http://www.carrona.org/drivers/driver.php?id=BthHfAud.sys
    BthA2DP.sys Thu Aug 22 13:38:30  2013 (5215F836)
    Bluetooth A2DP Driver - uncertain if this is a Windows  driver or a 3rd party bluetooth driver. See bthav.sys for more speculation
    http://www.carrona.org/drivers/driver.php?id=BthA2DP.sys
    dump_storahci.sys Thu Aug 22  13:40:39 2013 (5215F8B7)
    driver created to provide disk access during crash  dump file generation
    http://www.carrona.org/drivers/driver.php?id=dump_storahci.sys
    avkmgr.sys Mon Sep 16  13:14:23 2013 (5236E80F)
    Avira GmbH Manager Driver
    http://www.carrona.org/drivers/driver.php?id=avkmgr.sys
    bcbtums.sys Thu Oct 17 22:45:30  2013 (52604C6A)
    Broadcom Bluetooth Firmware Download Filter driver from  Broadcom Corporation.
    http://www.carrona.org/drivers/driver.php?id=bcbtums.sys
    avgntflt.sys Fri Jul 11 17:46:47  2014 (53C006E7)
    Avira AntiVir
    http://www.carrona.org/drivers/driver.php?id=avgntflt.sys
    avipbb.sys Wed Aug 6 09:31:29  2014 (53E1D9D1)
    Avira AntiVir
    http://www.carrona.org/drivers/driver.php?id=avipbb.sys
    Debug session time: Tue Feb  17 23:00:27.668 2015 (UTC + 1:00)
    Loading Dump File  [C:\Users\Mihael\SysnativeBSODApps\021815-22375-01.dmp]
    Built by:  9600.17630.amd64fre.winblue_r7.150109-2022
    System Uptime: 0 days 0:37:15.406
    Probably caused by : GenuineIntel
    BugCheck 124, {0, ffffe00084708038,  f2000040, 800}
    BugCheck Info: WHEA_UNCORRECTABLE_ERROR  (124)
    Bugcheck code 00000124
    Arguments:
    Arg1: 0000000000000000,  Machine Check Exception
    Arg2: ffffe00084708038, Address of the  WHEA_ERROR_RECORD structure.
    Arg3: 00000000f2000040, High order 32-bits of  the MCi_STATUS value.
    Arg4: 0000000000000800, Low order 32-bits of the  MCi_STATUS value.
    BUGCHECK_STR: 0x124_GenuineIntel
    PROCESS_NAME: System
    FAILURE_BUCKET_ID: 0x124_GenuineIntel_PROCESSOR_BUS
    MaxSpeed: 2400
    CurrentSpeed: 2394
    BiosVersion = 68PDD Ver. F.10
    BiosReleaseDate =  07/31/2009
    SystemManufacturer = Hewlett-Packard
    SystemProductName = HP  Compaq 6730b (VE702PC#ABG)
    ииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииии``
    Debug session time: Tue Feb 17 20:58:27.903 2015 (UTC + 1:00)
    Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\021815-34875-01.dmp]
    System Uptime: 0 days 0:06:10.639
    *** WARNING: Unable to verify timestamp for bcbtums.sys
    *** ERROR:  Module load completed but symbols could not be loaded for bcbtums.sys
    Probably caused by : usbhub.sys
    BugCheck 9F, {3, ffffe0008fef4060,  fffff800709dfa60, ffffe0008fec16d0}
    BugCheck Info: DRIVER_POWER_STATE_FAILURE  (9f)
    Bugcheck code 0000009F
    Arguments:
    Arg1: 0000000000000003, A  device object has been blocking an Irp for too long a time
    Arg2:  ffffe0008fef4060, Physical Device Object of the stack
    Arg3:  fffff800709dfa60, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the  Functional Device Object of the stack
    Arg4: ffffe0008fec16d0, The blocked  IRP
    BUGCHECK_STR: 0x9F
    DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULT
    FAILURE_BUCKET_ID:  0x9F_3_STUCK_UHCI_IMAGE_usbhub.sys
    MaxSpeed: 2400
    CurrentSpeed: 2394
    Debug session time: Tue Feb 17 20:29:55.642 2015 (UTC + 1:00)
    Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\021815-19406-01.dmp]
    System Uptime: 0 days 0:01:53.378
    BugCheck 124, {0, ffffe0005ac9a038,  b2000040, 800}
    Arguments:
    Arg2: ffffe0005ac9a038, Address of the  WHEA_ERROR_RECORD structure.
    Arg3: 00000000b2000040, High order 32-bits of  the MCi_STATUS value.
    MaxSpeed: 2400
    CurrentSpeed: 2394
    Debug session time: Tue Feb 17 01:56:16.960 2015 (UTC + 1:00)
    Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\021715-26234-01.dmp]
    System Uptime: 0 days 1:57:03.698
    BugCheck 9F, {3, ffffe001d174c060,  fffff803757dfa60, ffffe001d189f720}
    Arguments:
    Arg2:  ffffe001d174c060, Physical Device Object of the stack
    Arg3:  fffff803757dfa60, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the  Functional Device Object of the stack
    Arg4: ffffe001d189f720, The blocked  IRP
    BUGCHECK_STR: 0x9F
    FAILURE_BUCKET_ID:  0x9F_3_STUCK_UHCI_hidusb_IMAGE_usbhub.sys
    MaxSpeed: 2400
    CurrentSpeed:  2394
    Debug session time: Mon Feb 16 11:05:05.911 2015 (UTC + 1:00)
    Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\021615-30484-01.dmp]
    System Uptime: 0 days 0:04:12.648
    BugCheck 9F, {3, ffffe0016f38a060,  fffff80019be6cb0, ffffe001708383f0}
    Arguments:
    Arg2:  ffffe0016f38a060, Physical Device Object of the stack
    Arg3:  fffff80019be6cb0, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the  Functional Device Object of the stack
    Arg4: ffffe001708383f0, The blocked  IRP
    BUGCHECK_STR: 0x9F
    PROCESS_NAME: avguard.exe
    MaxSpeed: 2400
    CurrentSpeed: 2394
    Debug session time: Sun Feb 15 08:58:24.154 2015 (UTC + 1:00)
    Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\021515-29906-01.dmp]
    System Uptime: 0 days 0:04:07.042
    BugCheck 9F, {3, ffffe000fc1f1060,  fffff803dd3dfa60, ffffe000fd00a720}
    Arguments:
    Arg2:  ffffe000fc1f1060, Physical Device Object of the stack
    Arg3:  fffff803dd3dfa60, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the  Functional Device Object of the stack
    Arg4: ffffe000fd00a720, The blocked  IRP
    BUGCHECK_STR: 0x9F
    MaxSpeed: 2400
    CurrentSpeed: 2394
    Debug session time: Sat Feb 14 21:40:35.358 2015 (UTC + 1:00)
    Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\021515-23625-01.dmp]
    System Uptime: 0 days 0:10:37.095
    BugCheck 124, {0, ffffe001a1121038,  b2000040, 800}
    Arguments:
    Arg2: ffffe001a1121038, Address of the  WHEA_ERROR_RECORD structure.
    MaxSpeed: 2400
    CurrentSpeed: 2394
    Debug session time: Sat Feb 14 08:51:09.744 2015 (UTC + 1:00)
    Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\021415-20953-01.dmp]
    System Uptime: 0 days 1:26:56.481
    BugCheck 9F, {3, ffffe0004638d060,  fffff80203fdfa60, ffffe000464eda00}
    Arguments:
    Arg2:  ffffe0004638d060, Physical Device Object of the stack
    Arg3:  fffff80203fdfa60, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the  Functional Device Object of the stack
    Arg4: ffffe000464eda00, The blocked  IRP
    BUGCHECK_STR: 0x9F
    MaxSpeed: 2400
    CurrentSpeed:  2394
    Debug session time: Fri Feb 13 04:59:06.871 2015 (UTC + 1:00)
    Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\021315-33437-01.dmp]
    System Uptime: 0 days 0:03:52.606
    BugCheck 9F, {3, ffffe0019e142060,  fffff80385be9cb0, ffffe0019f4e9590}
    Arguments:
    Arg2:  ffffe0019e142060, Physical Device Object of the stack
    Arg3:  fffff80385be9cb0, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the  Functional Device Object of the stack
    Arg4: ffffe0019f4e9590, The blocked  IRP
    BUGCHECK_STR: 0x9F
    PROCESS_NAME: SearchFilterHo
    MaxSpeed: 2400
    CurrentSpeed: 2394
    Debug session time: Fri Feb 13 00:19:05.662 2015 (UTC + 1:00)
    Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\021315-40875-01.dmp]
    System Uptime: 0 days 0:13:29.399
    BugCheck 124, {0, ffffe000a37c6038,  f2000040, 800}
    Arguments:
    Arg2: ffffe000a37c6038, Address of the  WHEA_ERROR_RECORD structure.
    MaxSpeed: 2400
    CurrentSpeed: 2394
    Debug session time: Fri Feb 13 00:04:08.046 2015 (UTC + 1:00)
    Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\021315-31781-01.dmp]
    System Uptime: 0 days 0:26:34.783
    BugCheck 124, {0, ffffe00158491038,  f2000040, 800}
    Arguments:
    Arg2: ffffe00158491038, Address of the  WHEA_ERROR_RECORD structure.
    MaxSpeed: 2400
    CurrentSpeed: 2394
    Debug session time: Thu Feb 12 07:47:50.223 2015 (UTC + 1:00)
    Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\021215-28515-01.dmp]
    Built by:  9600.17328.amd64fre.winblue_r3.140827-1500
    System Uptime: 0 days 0:05:12.960
    BugCheck 9F, {3, ffffe0002f7a5060,  fffff802aafe4a60, ffffe00030e46bd0}
    Arguments:
    Arg2:  ffffe0002f7a5060, Physical Device Object of the stack
    Arg3:  fffff802aafe4a60, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the  Functional Device Object of the stack
    Arg4: ffffe00030e46bd0, The blocked  IRP
    BUGCHECK_STR: 0x9F
    MaxSpeed: 2400
    CurrentSpeed: 2394
    Debug session time: Wed Feb 11 22:06:51.200 2015 (UTC + 1:00)
    Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\021215-24796-01.dmp]
    System Uptime: 0 days 1:01:44.938
    BugCheck 124, {0, ffffe00005a4d038,  f2000040, 800}
    Arguments:
    Arg2: ffffe00005a4d038, Address of the  WHEA_ERROR_RECORD structure.
    MaxSpeed: 2400
    CurrentSpeed: 2394
    Debug session time: Wed Feb 11 20:52:20.079 2015 (UTC + 1:00)
    Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\021215-21546-01.dmp]
    System Uptime: 0 days 1:45:06.818
    *** WARNING: Unable to verify timestamp for igdkmd64.sys
    *** ERROR:  Module load completed but symbols could not be loaded for igdkmd64.sys
    BugCheck 124, {0, ffffe000f9fc9038,  f2000040, 800}
    Arguments:
    Arg2: ffffe000f9fc9038, Address of the  WHEA_ERROR_RECORD structure.
    PROCESS_NAME:  chrome.exe
    MaxSpeed:  2400
    CurrentSpeed: 2394
    Debug session time: Sun Feb 8 22:59:48.806 2015 (UTC + 1:00)
    Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\020915-552890-01.dmp]
    System Uptime: 0 days 1:00:58.543
    BugCheck 124, {0, ffffe00142cb1038,  f2000040, 800}
    Arguments:
    Arg2: ffffe00142cb1038, Address of the  WHEA_ERROR_RECORD structure.
    MaxSpeed: 2400
    CurrentSpeed: 2394
    Debug session time: Sun Feb 8 21:55:10.529 2015 (UTC + 1:00)
    Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\020915-24843-01.dmp]
    System Uptime: 0 days 0:59:12.266
    BugCheck 124, {0, ffffe000bf681038,  f2000040, 800}
    Arguments:
    Arg2: ffffe000bf681038, Address of the  WHEA_ERROR_RECORD structure.
    MaxSpeed: 2400
    CurrentSpeed: 2394
    Debug session time: Sun Feb 8 11:45:35.184 2015 (UTC + 1:00)
    Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\020915-19718-01.dmp]
    System Uptime: 0 days 0:00:36.920
    BugCheck 124, {0, ffffe00138f70038,  f2000040, 800}
    Arguments:
    Arg2: ffffe00138f70038, Address of the  WHEA_ERROR_RECORD structure.
    MaxSpeed: 2400
    CurrentSpeed: 2394
    Debug session time: Sun Feb 8 11:33:53.847 2015 (UTC + 1:00)
    Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\020815-23125-01.dmp]
    System Uptime: 0 days 0:54:14.159
    BugCheck 124, {0, ffffe001a0c9d038,  b2000040, 800}
    Arguments:
    Arg2: ffffe001a0c9d038, Address of the  WHEA_ERROR_RECORD structure.
    MaxSpeed: 2400
    CurrentSpeed: 2394
    Debug session time: Sun Feb 8 10:38:13.692 2015 (UTC + 1:00)
    Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\020815-479750-01.dmp]
    System Uptime: 0 days 1:37:28.434
    BugCheck 124, {0, ffffe000a65881d8,  f2000040, 800}
    Arguments:
    Arg2: ffffe000a65881d8, Address of the  WHEA_ERROR_RECORD structure.
    MaxSpeed: 2400
    CurrentSpeed: 2394
    Debug session time: Sun Feb 8 08:59:30.878 2015 (UTC + 1:00)
    Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\020815-34187-01.dmp]
    System Uptime: 0 days 1:07:19.615
    BugCheck 124, {0, ffffe001d8a4d038,  f2000040, 800}
    Arguments:
    Arg2: ffffe001d8a4d038, Address of the  WHEA_ERROR_RECORD structure.
    MaxSpeed:  2400
    CurrentSpeed: 2394
    Debug session time: Sun Feb 8 05:49:05.228 2015 (UTC + 1:00)
    Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\020815-26359-01.dmp]
    System Uptime: 0 days 3:43:04.980
    BugCheck 9F, {3, ffffe0007dccc060,  fffff80388de4a60, ffffe0007db4c010}
    Arguments:
    Arg2:  ffffe0007dccc060, Physical Device Object of the stack
    Arg3:  fffff80388de4a60, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the  Functional Device Object of the stack
    Arg4: ffffe0007db4c010, The blocked  IRP
    BUGCHECK_STR: 0x9F
    MaxSpeed: 2400
    CurrentSpeed: 2394
    Debug session time: Sat Feb 7 00:58:03.352 2015 (UTC + 1:00)
    Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\020715-22015-01.dmp]
    System Uptime: 0 days 1:42:12.091
    BugCheck 9F, {3, ffffe001f8482060,  fffff800741e4a60, ffffe001f9594bd0}
    Arguments:
    Arg2:  ffffe001f8482060, Physical Device Object of the stack
    Arg3:  fffff800741e4a60, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the  Functional Device Object of the stack
    Arg4: ffffe001f9594bd0, The blocked  IRP
    BUGCHECK_STR: 0x9F
    FAILURE_BUCKET_ID:  0x9F_3_STUCK_UHCI_POWER_DOWN_IMAGE_usbhub.sys
    MaxSpeed: 2400
    CurrentSpeed: 2394
    Debug session time: Fri Feb 6 12:38:46.755 2015 (UTC + 1:00)
    Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\020715-28312-01.dmp]
    ***  WARNING: Unable to verify timestamp for Unknown_Module_bff0e0f4`4c0289be
    ***  ERROR: Module load completed but symbols could not be loaded for  Unknown_Module_bff0e0f4`4c0289be
    System Uptime: 0 days 0:06:17.493
    Probably caused by : Unknown_Image
    BugCheck 124, {0, ffffe001562a4038, f2000040, 800}
    Arguments:
    Arg2: ffffe001562a4038, Address of the  WHEA_ERROR_RECORD structure.
    FAILURE_BUCKET_ID:  CORRUPT_MODULELIST
    Debug session time: Fri Feb 6 12:31:49.715 2015 (UTC + 1:00)
    Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\020715-20375-01.dmp]
    System Uptime: 0 days 1:20:37.452
    BugCheck 9F, {3, ffffe000dbb48060,  fffff800b53e4a60, ffffe000dd2b9790}
    Arguments:
    Arg2:  ffffe000dbb48060, Physical Device Object of the stack
    Arg3:  fffff800b53e4a60, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the  Functional Device Object of the stack
    Arg4: ffffe000dd2b9790, The blocked  IRP
    BUGCHECK_STR: 0x9F
    MaxSpeed: 2400
    CurrentSpeed: 2394
    Debug session time: Fri Feb 6 10:50:15.726 2015 (UTC + 1:00)
    Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\020615-16484-01.dmp]
    System Uptime: 0 days 0:29:20.464
    BugCheck 9F, {3, ffffe00104efd060,  fffff802819e4a60, ffffe001061f7010}
    Arguments:
    Arg2:  ffffe00104efd060, Physical Device Object of the stack
    Arg3:  fffff802819e4a60, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the  Functional Device Object of the stack
    Arg4: ffffe001061f7010, The blocked  IRP
    BUGCHECK_STR: 0x9F
    MaxSpeed: 2400
    CurrentSpeed: 2394
    Debug session time: Fri Feb 6 09:12:51.962 2015 (UTC + 1:00)
    Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\020615-27796-01.dmp]
    System Uptime: 0 days 1:29:02.701
    BugCheck 9F, {3, ffffe00111551060,  fffff800731e4a60, ffffe0010fbc8bd0}
    Arguments:
    Arg2:  ffffe00111551060, Physical Device Object of the stack
    Arg3:  fffff800731e4a60, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the  Functional Device Object of the stack
    Arg4: ffffe0010fbc8bd0, The blocked  IRP
    BUGCHECK_STR: 0x9F
    MaxSpeed: 2400
    CurrentSpeed: 2394
    Debug session time: Mon Feb 2 07:33:19.761 2015 (UTC + 1:00)
    Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\020215-27531-01.dmp]
    System Uptime: 0 days 0:07:10.497
    BugCheck 124, {0, ffffe001290a41d8,  b2000040, 800}
    Arguments:
    Arg2: ffffe001290a41d8, Address of the  WHEA_ERROR_RECORD structure.
    MaxSpeed:  2400
    CurrentSpeed: 2394
    Debug session time: Mon Feb 2 06:53:47.424 2015 (UTC + 1:00)
    Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\020215-24359-01.dmp]
    System Uptime: 0 days 5:18:29.306
    BugCheck 124, {0, ffffe000cd2fb038,  f2000040, 800}
    Arguments:
    Arg2: ffffe000cd2fb038, Address of the  WHEA_ERROR_RECORD structure.
    MaxSpeed:  2400
    CurrentSpeed: 2394
    Debug session time: Sun Feb 1 22:11:48.906 2015 (UTC + 1:00)
    Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\020215-23140-01.dmp]
    System Uptime: 0 days 2:00:53.644
    BugCheck 9F, {3, ffffe0014f97e060,  fffff8010f3e4a60, ffffe0014c7b5350}
    Arguments:
    Arg2:  ffffe0014f97e060, Physical Device Object of the stack
    Arg3:  fffff8010f3e4a60, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the  Functional Device Object of the stack
    Arg4: ffffe0014c7b5350, The blocked  IRP
    BUGCHECK_STR: 0x9F
    MaxSpeed: 2400
    CurrentSpeed: 2394
    Debug session time: Sat Jan 31 21:54:31.248 2015 (UTC + 1:00)
    Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\020115-29765-01.dmp]
    System Uptime: 0 days 0:06:48.985
    Probably caused by : usbuhci.sys ( usbuhci!UhciRHPortResetComplete+8b )
    BugCheck 133, {0, 501, 500, 0}
    BugCheck Info: DPC_WATCHDOG_VIOLATION  (133)
    Bugcheck code 00000133
    Arguments:
    Arg1: 0000000000000000,  A single DPC or ISR exceeded its time allotment. The offending
    component can  usually be identified with a stack trace.
    Arg2: 0000000000000501, The DPC  time count (in ticks).
    Arg3: 0000000000000500, The DPC time allotment (in  ticks).
    Arg4: 0000000000000000
    BUGCHECK_STR: 0x133
    FAILURE_BUCKET_ID: 0x133_DPC_usbuhci!UhciRHPortResetComplete
    MaxSpeed:  2400
    CurrentSpeed: 2394
    --- E O J --- 2015 Feb 20 23:35:21 PM _88-dbug Copyright  2012 Sysnative Forums
    everything is up to date, unable to do bootable stuff because my laptop screen doesn't work and i can work blind on something i havent seen
    Windows 10 Pro x64
    Then first fix your screen.
Page 1 of 2 12 LastLast
Solved BSOD Driver Power State Failure in BSOD Crashes and Debugging
I recently got a BSOD before this BSOD the BSOD happened yesterday was kernel_data_input_error and I think I have fixed it? but the computer is still a little slow, and I noticed my Disk usage is most of the time at 100% then the apps(Browsers,task managers etc2) doesn't respond and now This BSOD...
BSOD - Driver Power State Failure in BSOD Crashes and Debugging
Hello, Did a clean install of Windows 8.1 - I previously had Windows 7. I have already had 4 'Driver Power State Failure' BSODs. I have attached the files from the SF Diagnostic tool. Any solutions? NB: This is a custom built PC with an Asus P8H61-M LX3 Plus R2.0 mobo. Thanks in advance.
Driver power state failure (BSOD) in BSOD Crashes and Debugging
Hello, I made a thread about this already but no one would reply can someone help me please? I really want to get rid of this BSOD :cry: I want to know what the problem is, thanks http://sdrv.ms/14ltYEj edit: windows 8
Solved BSOD - Driver Power State Failure in BSOD Crashes and Debugging
Hi I getting this error when I try and shutdown my laptop, will not shutdown and after a couple of minutes it comes up with the above error. Attached is the information from the SF Diagnostic Tool. Any help would be appreciated. Thanks Jamie
BSOD Driver Power State Failure in Drivers & Hardware
I've been coming across this bsod for a few weeks now, it only happens when i put the computer into sleep/hibernate. It even happens sometimes when the computer tries to start from a cold boot. The only hardware change i've made to the computer was a new wireless adapter from netgear model no.:...
Bsod driver power state failure in BSOD Crashes and Debugging
Hello All, I have been attempting to fix a win8 64bit issue on my dell xps600 for two weeks without success. I started the install with a clean install of win8 64bit and found that the BSOD started immediately. I have discovered that restarting the machine works fine and fast without any BSOD. ...
Hi, Just got my new Samsung ATIV SMART PC, preinstalled with Windows 8. After a few days, it begins to crash a lot, with mainly driver_power_state_failure as the cause. Could you nice ladies and gentlemen help me find the solution for this problem? Attached here is my diagnostic files using SF...
