BSOD everyday, sound issues, Driver Power State Failure?
  1. #11
    India
    Windows 8.1 Industry Pro B-)
    Hi Kaboose79 ^_^,
    WHEA_UNCORRECTABLE_ERROR (124)
    A fatal hardware error has occurred. Parameter 1 identifies the type of error source that reported the error. Parameter 2 holds the address of the WHEA_ERROR_RECORD structure that describes the error condition.
    Arguments:
    Arg1: 0000000000000000, Machine Check Exception
    Arg2: ffffe00084708038, Address of the WHEA_ERROR_RECORD structure.
    Arg3: 00000000f2000040, High order 32-bits of the MCi_STATUS value.
    Arg4: 0000000000000800, Low order 32-bits of the MCi_STATUS value.
    1: kd> !errrec ffffe00084708038
    Common Platform Error Record @ ffffe00084708038
    Record Id     : 01d04af7ef5dd523
    Severity      : Fatal (1)
    Length        : 928
    Creator       : Microsoft
    Notify Type   : Machine Check Exception
    Timestamp     : 2/17/2015 22:00:27 (UTC)
    Flags         : 0x00000000
    Section 0     : Processor Generic
    Descriptor    @ ffffe000847080b8
    Section       @ ffffe00084708190
    Offset        : 344
    Length        : 192
    Flags         : 0x00000001 Primary
    Severity      : Fatal
    Proc. Type    : x86/x64
    Instr. Set    : x64
    Error Type    : BUS error
    Operation     : Generic
    Flags         : 0x00
    Level         : 0
    CPU Version   : 0x000000000001067a
    Processor ID  : 0x0000000000000001
    Section 1     : x86/x64 Processor Specific
    Descriptor    @ ffffe00084708100
    Section       @ ffffe00084708250
    Offset        : 536
    Length        : 128
    Flags         : 0x00000000
    Severity      : Fatal
    Local APIC Id : 0x0000000000000001
    CPU Id        : 7a 06 01 00 00 08 02 01 - fd e3 08 0c ff fb eb bf
                    00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00
    Proc. Info 0  @ ffffe00084708250
    Section 2     : x86/x64 MCA
    Descriptor    @ ffffe00084708148
    Section       @ ffffe000847082d0
    Offset        : 664
    Length        : 264
    Flags         : 0x00000000
    Severity      : Fatal
    Error         : BUSL0_SRC_ERR_M_NOTIMEOUT_ERR (Proc 1 Bank 0)
      Status      : 0xf200004000000800
    So, it seems that there was a problem in transferring the data/signals from the BUS to the CPU. This is generally the sign of a failing motherboard. Add to the fact that the other dump files are blaming the Bluetooth driver. Also, the issues you are facing are a sign of a failing motherboard.
    I would suggest you to send the laptop to HP and have it checked. Furthermore, the BIOS date is extremely old (2009). Did you face these problems in Windows 7 as well?
    Let us know how it goes ^_^.
    -Pranav
  2. #12
    finally found this page, my laptop is basically junk now, sometimes it works and other it wont. computer hunting time for me. thanks for your help
  3. #13
    India
    Quote Originally Posted by Kaboose79 View Post
    Did you take it to HP and see what they told?
  4. #14
    to get it to HP i will have to spend $50 - $80, to replace motherboard around $400 - $500 depending on the model.
    my income $0, my money $54.75
    i am better off buying a new one from the warehouse.
    (estimate prices from Jonko employee which is where i brought it, we dont have a HP store here)
  5. #15
    India
    Well that's surely costly. If you are satisfied with the solution, kindly mark this thread as solved
    I hope you get a new system soon because I have a fair idea how much frustration is involved with a system like this
    -Pranav
Page 2 of 2 FirstFirst 12
Solved BSOD Driver Power State Failure in BSOD Crashes and Debugging
I recently got a BSOD before this BSOD the BSOD happened yesterday was kernel_data_input_error and I think I have fixed it? but the computer is still a little slow, and I noticed my Disk usage is most of the time at 100% then the apps(Browsers,task managers etc2) doesn't respond and now This BSOD...
BSOD - Driver Power State Failure in BSOD Crashes and Debugging
Hello, Did a clean install of Windows 8.1 - I previously had Windows 7. I have already had 4 'Driver Power State Failure' BSODs. I have attached the files from the SF Diagnostic tool. Any solutions? NB: This is a custom built PC with an Asus P8H61-M LX3 Plus R2.0 mobo. Thanks in advance.
Driver power state failure (BSOD) in BSOD Crashes and Debugging
Hello, I made a thread about this already but no one would reply can someone help me please? I really want to get rid of this BSOD :cry: I want to know what the problem is, thanks http://sdrv.ms/14ltYEj edit: windows 8
Solved BSOD - Driver Power State Failure in BSOD Crashes and Debugging
Hi I getting this error when I try and shutdown my laptop, will not shutdown and after a couple of minutes it comes up with the above error. Attached is the information from the SF Diagnostic Tool. Any help would be appreciated. Thanks Jamie
BSOD Driver Power State Failure in Drivers & Hardware
I've been coming across this bsod for a few weeks now, it only happens when i put the computer into sleep/hibernate. It even happens sometimes when the computer tries to start from a cold boot. The only hardware change i've made to the computer was a new wireless adapter from netgear model no.:...
Bsod driver power state failure in BSOD Crashes and Debugging
Hello All, I have been attempting to fix a win8 64bit issue on my dell xps600 for two weeks without success. I started the install with a clean install of win8 64bit and found that the BSOD started immediately. I have discovered that restarting the machine works fine and fast without any BSOD. ...
Hi, Just got my new Samsung ATIV SMART PC, preinstalled with Windows 8. After a few days, it begins to crash a lot, with mainly driver_power_state_failure as the cause. Could you nice ladies and gentlemen help me find the solution for this problem? Attached here is my diagnostic files using SF...
