Help with minidump ntoskrnl.exe problem
bogo75
Hi everyone,
Please help with one BSOD. It appeared when tried to start one game.
This is more about the problem:
Microsoft (R) Windows Debugger Version 6.3.9600.16384 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\012515-15078-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y <symbol_path> argument when starting the debugger. *
* using .sympath and .sympath+ *
Unable to load image ntoskrnl.exe, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows 8 Kernel Version 9600 MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Machine Name:
Kernel base = 0xfffff801`05e87000 PsLoadedModuleList = 0xfffff801`06160250
Debug session time: Sun Jan 25 00:05:01.353 2015 (UTC + 2:00)
System Uptime: 0 days 21:05:53.792
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
************* Symbol Loading Error Summary **************
Module name Error
ntoskrnl The system cannot find the file specified
You can troubleshoot most symbol related issues by turning on symbol loading diagnostics (!sym noisy) and repeating the command that caused symbols to be loaded.
You should also verify that your symbol search path (.sympath) is correct.
* Bugcheck Analysis *
BugCheck 3B, {c0000005, fffff80105f7aaa2, ffffd001525dbb20, 0}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** Either you specified an unqualified symbol, or your debugger ***
*** doesn't have full symbol information. Unqualified symbol ***
*** resolution is turned off by default. Please either specify a ***
*** fully qualified symbol module!symbolname, or enable resolution ***
*** of unqualified symbols by typing ".symopt- 100". Note that ***
*** enabling unqualified symbol resolution with network symbol ***
*** server shares in the symbol path may cause the debugger to ***
*** appear to hang for long periods of time when an incorrect ***
*** symbol name is typed or the network symbol server is down. ***
*** For some commands to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!_KPRCB ***
*** work. ***
*** work. ***
Probably caused by : ntoskrnl.exe ( nt+f3aa2 )
Followup: MachineOwner
0: kd> !analyze -v
SYSTEM_SERVICE_EXCEPTION (3b)
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff80105f7aaa2, Address of the instruction which caused the bugcheck
Arg3: ffffd001525dbb20, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
Debugging Details:
*** work. ***
*** work. ***
*** work. ***
ADDITIONAL_DEBUG_TEXT:
You can run '.symfix; .reload' to try to fix the symbol path and load symbols.
MODULE_NAME: nt
FAULTING_MODULE: fffff80105e87000 nt
DEBUG_FLR_IMAGE_TIMESTAMP: 545167e0
DUMP_FILE_ATTRIBUTES: 0x8
Kernel Generated Triage Dump
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
FAULTING_IP:
nt+f3aa2
fffff801`05f7aaa2 488b4928 mov rcx,qword ptr [rcx+28h]
CONTEXT: ffffd001525dbb20 -- (.cxr 0xffffd001525dbb20;r)
rax=0000000000000056 rbx=ffffe00160ddba60 rcx=43b34880d109a4e8
rdx=ffffe00160ddba60 rsi=0000000020000000 rdi=70ca87b44a755ef0
rip=fffff80105f7aaa2 rsp=ffffd001525dc550 rbp=0000000000000004
r8=fffff801061e2c40 r9=fffff8010618a180 r10=0000000000000001
r11=fffff78000000008 r12=0000000000000000 r13=0000000000000000
r14=ffffe0015e85db00 r15=ffffe0015ee4a000
iopl=0 nv up ei pl zr na po nc
cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00010246
nt+0xf3aa2:
fffff801`05f7aaa2 488b4928 mov rcx,qword ptr [rcx+28h] ds:002b:43b34880`d109a510=????????????????
Last set context:
nt+0xf3aa2:
Resetting default scope
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULT
BUGCHECK_STR: 0x3B
CURRENT_IRQL: 0
ANALYSIS_VERSION: 6.3.9600.16384 (debuggers(dbg).130821-1623) amd64fre
LAST_CONTROL_TRANSFER: from ffffe00160ddba60 to fffff80105f7aaa2
STACK_TEXT:
ffffd001`525dc550 ffffe001`60ddba60 : 00000000`00000000 00000000`00000000 ffffe001`5e7c97b0 00000000`20000000 : nt+0xf3aa2
ffffd001`525dc558 00000000`00000000 : 00000000`00000000 ffffe001`5e7c97b0 00000000`20000000 00000000`00000004 : 0xffffe001`60ddba60
FOLLOWUP_IP:
nt+f3aa2
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: nt+f3aa2
FOLLOWUP_NAME: MachineOwner
IMAGE_NAME: ntoskrnl.exe
STACK_COMMAND: .cxr 0xffffd001525dbb20 ; kb
BUCKET_ID: WRONG_SYMBOLS
FAILURE_BUCKET_ID: WRONG_SYMBOLS
ANALYSIS_SOURCE: KM
FAILURE_ID_HASH_STRING: km:wrong_symbols
FAILURE_ID_HASH: {70b057e8-2462-896f-28e7-ac72d4d365f8}
0: kd> g
^ No runnable debuggees error in 'g'
I have and another problem. If this BSOD has something common:
http://www.eightforums.com/bsod-crashes-debugging/60527-bsod-kernel_data_inpage_error-win-8-1-a.html
Thanks in advance!
    AMD FX(tm)-4300 Quad Core
    GIGABYTE 990FXA-UD3 rev.4
    8GB
    GIGABYTE NVIDIA GTX 650
Upload the minidumps.
    Windows 10 Pro x64
    INTEL Core i7-2700K 3.5GHz
    ASROCK Fatal1ty P67 Main Board
    HyperX Blu 8GB (2 x 4GB) DDR3 1600
    Gigabyte GTX 980 Ti G1 Gaming
    On-board
    Philips Brilliance BDM4065UC
    3840x2160
    SSD: Samsung EVO 250 GB
    Internal HDD: WD Black 1TB
    External: 2x2TB MyBook drives
    1x4TB MyBook
    1x1TB Seagate Freeagent drive
    Corsair GS 700W
    Silverstone Kublai KL04
    Artic Cooling Freezer Pro
    Logitech G710+
    Razer Mamba Elite 2012
    FF 39.0.3, Microsoft Edge, Chrome 44
    Avast 10.0
    8GB
There is a lot of stuff going on here. You have both Nvidia and AMD software installed. Please remove them using DDU and install the ones you currently have. Update the rest of the drivers in red.
[COLOR=red][B]usbVM31b.sys Mon Sep 19 08:57:34 2005  (432E615E)[/B][/COLOR]
[COLOR=#777777][COLOR=#4b0082]usbVM31b.sys[/COLOR] - this driver hasn't been added to the DRT as  of this run. Please search Google/Bing for the driver if additional information  is needed.[/COLOR]
usbfilter.sys Wed Aug 29 03:27:12 2012 (503D6FF0)
AMD USB Filter Driver (likely part of the chipset drivers)
[URL="http://www.carrona.org/drivers/driver.php?id=usbfilter.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]usbfilter.sys[/COLOR][/B][/URL]
[COLOR=red][B]AODDriver2.sys Wed Nov 21 08:44:04 2012 (50AC8644)[/B][/COLOR]
AMD Overdrive; also in EasyTune6 for Gigabyte motherboard [br] Known [COLOR=red]BSOD[/COLOR] issues in Win7[br][br]Part of AMD Fuel[br][br]Location:  C:\Program Files\ATI Technologies\ATI.ACE\Fuel\amd64\AODDriver2.sys
[URL="http://www.carrona.org/drivers/driver.php?id=AODDriver2.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]AODDriver2.sys[/COLOR][/B][/URL]
Rt630x64.sys Fri Jun 21  11:29:10 2013 (51C41CE6)
Realtek PCI/PCIe Adapters
[URL="http://www.carrona.org/drivers/driver.php?id=Rt630x64.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]Rt630x64.sys[/COLOR][/B][/URL]
amd_sata.sys Fri Jun 28 06:45:40  2013 (51CD14F4)
AMD SATA Controller AHCI 1.2 Device Driver
[URL="http://www.carrona.org/drivers/driver.php?id=amd_sata.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]amd_sata.sys[/COLOR][/B][/URL]
amd_xata.sys Fri Jun 28 06:45:43  2013 (51CD14F7)
AMD Stor Filter Driver
[URL="http://www.carrona.org/drivers/driver.php?id=amd_xata.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]amd_xata.sys[/COLOR][/B][/URL]
tap0901.sys Thu Aug 22 14:40:01  2013 (521606A1)
TAP-Win32 Adapter V9 or[br]OpenVPN driver or COMODO
[URL="http://www.carrona.org/drivers/driver.php?id=tap0901.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]tap0901.sys[/COLOR][/B][/URL]
RTKVHD64.sys Tue Dec 3 13:26:10  2013 (529DCDE2)
Realtek High Definition Audio Function Driver
[URL="http://www.carrona.org/drivers/driver.php?id=RTKVHD64.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]RTKVHD64.sys[/COLOR][/B][/URL]
nvhda64v.sys Thu Oct 9 19:02:27  2014 (5436BFA3)
nVidia HDMI Audio Device (nForce chipset driver)
[URL="http://www.carrona.org/drivers/driver.php?id=nvhda64v.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]nvhda64v.sys[/COLOR][/B][/URL]
nvvad64v.sys Thu Nov 20 16:33:54  2014 (546E09E2)
NVIDIA Virtual Audio Driver
[URL="http://www.carrona.org/drivers/driver.php?id=nvvad64v.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]nvvad64v.sys[/COLOR][/B][/URL]
[COLOR=red][B]NvStreamKms.sys Sat Nov 22 08:46:45 2014 (54703F65)[/B][/COLOR]
nVidia Streaming Kernel service - may cause [COLOR=red]BSOD[/COLOR] in  Win8.1 systems (found in May 2014). Date/TimeStamp: Tue Apr 29 20:59:44 2014  (53604B00) [B]MAY NOT BE A PROBLEM, this is a tenative posting - Appears that  April 29 driver is a problem, July 2014 drivers seem OK[/B]
[URL="http://www.carrona.org/drivers/driver.php?id=NvStreamKms.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]NvStreamKms.sys[/COLOR][/B][/URL]
nvlddmkm.sys Sat Dec 13  07:53:17 2014 (548BE25D)
nVidia Video drivers
[URL="http://www.carrona.org/drivers/driver.php?id=nvlddmkm.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]nvlddmkm.sys[/COLOR][/B][/URL]
nvstusb.sys Sat Dec 13 08:30:38  2014 (548BEB1E)
NVIDIA Stereoscopic 3D USB driver
[URL="http://www.carrona.org/drivers/driver.php?id=nvstusb.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]nvstusb.sys[/COLOR][/B][/URL]
Debug session time: Sat  Jan 24 23:05:01.353 2015 (UTC + 1:00)
Loading Dump File  [C:\Users\Mihael\SysnativeBSODApps\012515-15078-01.dmp]
Built by:  9600.17476.amd64fre.winblue_r5.141029-1500
*** WARNING: Unable to verify timestamp for nvstusb.sys
***  ERROR: Module load completed but symbols could not be loaded for nvstusb.sys
Probably caused by : nvstusb.sys ( nvstusb+a56c )
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#Example"]SYSTEM_SERVICE_EXCEPTION  (3b)[/URL]
Bugcheck code 0000003B
Arguments:
BUGCHECK_STR: 0x3B
PROCESS_NAME: fifa14.exe
FAILURE_BUCKET_ID:  0x3B_nvstusb+a56c
BiosVersion = F3i
BiosReleaseDate = 10/07/2014
SystemManufacturer = Gigabyte Technology Co., Ltd.
SystemProductName =  To be filled by O.E.M.
--- E O J --- 2015 Jan 25 22:41:22 PM _88-dbug Copyright  2012 Sysnative Forums
    Windows 10 Pro x64
    On-board
    3840x2160
    1x4TB MyBook
    Corsair GS 700W
    Logitech G710+
    Avast 10.0
Yes. I know, but I installed AMD after the problem. because I tried to install mobo chipset driver. They installed this software - Catalyst.
    8GB
They couldn't have because chipset drivers are something different than Catalyst (GPU drivers control center). Download 3DP Chip and let it tell you if any drivers are outdated. If there are, update them.
    Windows 10 Pro x64
    On-board
    3840x2160
    1x4TB MyBook
    Corsair GS 700W
    Logitech G710+
    Avast 10.0
Please tell me about this drivers. First two is for the AMD, isn't it? You advice me to uninstall? And the third is Nvidia driver. How to update? I am with the latest NVIDIA drivers. May there is another way?
And where is my mobo chipset drivers? I am downloaded them from the manufacturer site, but installed me this ATI Catalyst.
    8GB
I didn't saw your first reply, but please answer me for the other questions. And if you thing that is the problem from the minidump - drivers? Anything else?
    8GB
For now, focus is on the drivers. Download 3DP Chip. It will tell you which drivers need to be updated, and remove AMD drivers completely, please.
    Windows 10 Pro x64
    On-board
    3840x2160
    1x4TB MyBook
    Corsair GS 700W
    Logitech G710+
    Avast 10.0
    8GB
Compare the local and the server version. If the local one is newer date, do not update, if it isn't do update.
I checked your topic, I think that everything is related. Do a HDD scan with HD Tune and take a screenshot of Health tab and do a Error scan.
    Windows 10 Pro x64
    On-board
    3840x2160
    1x4TB MyBook
    Corsair GS 700W
    Logitech G710+
    Avast 10.0
I updated all drivers. Chipset drivers downloaded from AMD site, but they are Catalist again. But 3 DP Chip now tells me there ok and up to date.
I did not updated usbVM31b.sys , but I red that driver updates with other and it is not recommended to replace manually.
I downloaded HD tune too. Now testing with it and after I'll upload screenshots.
    8GB
I am attaching health status from HD Tune.
Have I run other tests there? I started quick error scan - no problem. But when I start File Benchmark program gives me I/O Error.
    8GB
That's not a good sign. Please test it with Crystal disk info.
    Windows 10 Pro x64
    On-board
    3840x2160
    1x4TB MyBook
    Corsair GS 700W
    Logitech G710+
    Avast 10.0
I installed standard edition of Crystal disk. Will it do needing?
By the way I do full error test with HD Tune. No errors. But transfer check, failed again - I/O error.
    8GB
Yes, it should do. That's what worries me the most.
    Windows 10 Pro x64
    On-board
    3840x2160
    1x4TB MyBook
    Corsair GS 700W
    Logitech G710+
    Avast 10.0
Oop, sorry - this is Crystal Mark.
    8GB
    Windows 10 Pro x64
    On-board
    3840x2160
    1x4TB MyBook
    Corsair GS 700W
    Logitech G710+
    Avast 10.0
Yes, but opened me download page and can't find info version.
    8GB
Found it!
    8GB
