Please Help!BSOD Serious Problem
    Windows 8.1 Pro Build 9600
    Hello everyone,
    Hello,
    My PC is going through a hard time as I get to see these BSOD errors after starting up the PC each time. I have got no idea how this is caused. My PC Specs are:
    Processor:Intel Pentium G2020 @2.90GHz(2CPU's)
    RAM:2GB DDR3(Company:Qumem)
    Motherboard:ECS Elitegroup H61H2-M4
    Graphics:Nvidia Geforce 210(1 GB DDR3)
    Harddisk:Toshiba DT01ACA050 500gb
    I did follow the BSOD posting instructions and henced the zip.
    Please help me out!
    Thanks.
    Windows 10 Pro x64
    Please get all available Windows Updates. Update nvidia drivers (new drivers were released today), and run SFC SFC /SCANNOW Command - System File Checker - Windows 7 Help Forums
    nvhda64v.sys Tue May 10 11:41:18 2011  (4DC9083E)
    nVidia HDMI Audio Device (nForce chipset driver)
    http://www.carrona.org/drivers/driver.php?id=nvhda64v.sys
    nvlddmkm.sys  Wed Aug 3 11:08:32 2011 (4E391010)
    nVidia Video drivers
    viahduaa.sys Tue Jan 29 10:41:51  2013 (5107995F)
    VIA High Definition Audio Function Driver
    http://www.carrona.org/drivers/driver.php?id=viahduaa.sys
    L1C63x64.sys Mon Apr 1 05:15:17  2013 (5158FBC5)
    Qualcomm Atheros AR8151 PCI-E Gigabit Ethernet Controller  (NDIS 6.30)
    http://www.carrona.org/drivers/driver.php?id=L1C63x64.sys
    intelppm.sys Thu Aug 22 10:46:35  2013 (5215CFEB)
    Intel Processor driver
    Debug session time: Wed  Jan 21 16:31:27.857 2015 (UTC + 1:00)
    Loading Dump File  [C:\Users\Mihael\SysnativeBSODApps\012115-12437-01.dmp]
    Built by:  9600.16404.amd64fre.winblue_gdr.130913-2141
    System Uptime: 0 days  10:52:01.540
    Probably caused by : ntkrnlmp.exe ( nt! ??  ::FNODOBFM::`string'+4ffb )
    BugCheck 50, {fffff80157a16f70, 8,  fffff80157a16f70, 2}
    BugCheck Info: PAGE_FAULT_IN_NONPAGED_AREA  (50)
    Bugcheck code 00000050
    Arguments:
    Arg1: fffff80157a16f70,  memory referenced.
    Arg2: 0000000000000008, value 0 = read operation, 1 =  write operation.
    Arg3: fffff80157a16f70, If non-zero, the instruction  address which referenced the bad memory
    address.
    Arg4: 0000000000000002,  (reserved)
    BUGCHECK_STR: AV
    DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULT
    PROCESS_NAME: dwm.exe
    FAILURE_BUCKET_ID:  AV_BAD_IP_nt!_??_::FNODOBFM::_string_
    MaxSpeed: 2900
    CurrentSpeed: 2893
    BiosVersion = 4.6.5
    BiosReleaseDate = 05/28/2013
    SystemManufacturer  = ECS
    SystemProductName = H61H2-M4
    ииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииии``
    Debug session time: Wed Jan 21 05:05:14.762 2015 (UTC + 1:00)
    Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\012115-15515-01.dmp]
    System Uptime: 0 days  0:01:06.444
    Probably caused by : Ntfs.sys ( Ntfs!NtfsFindPrefixHashEntry+201  )
    BugCheck 24, {b500190637, ffffd0002109e908, ffffd0002109e110,  fffff8000096856b}
    BugCheck Info: NTFS_FILE_SYSTEM (24)
    Bugcheck code 00000024
    Arguments:
    Arg1: 000000b500190637
    Arg2:  ffffd0002109e908
    Arg3: ffffd0002109e110
    Arg4: fffff8000096856b
    PROCESS_NAME: WerFault.exe
    BUGCHECK_STR: 0x24
    FAILURE_BUCKET_ID: 0x24_Ntfs!NtfsFindPrefixHashEntry
    MaxSpeed: 2900
    CurrentSpeed: 2893
    BiosVersion = 4.6.5
    --- E O J --- 2015 Jan 22 18:17:20 PM _88-dbug Copyright  2012 Sysnative Forums
    Thank you...It solved my problem after I uninstalled Nvidia HD audio driver...Now no BSODs
    Thanks again
Solved Help with Bsod problem please in BSOD Crashes and Debugging
Computer 2 days takes off blue screen Windows 8.1
Solved Can someone please help with my BSOD problem in BSOD Crashes and Debugging
Seems to happen at random, It's a new machine with a new SSD.
BSOD Problem in BSOD Crashes and Debugging
Ever since I put together my PC I've been having randoom reboot/BSOD issues. At first I though it was video card related. Especially since a driver update solved my problems for a while. The last few days however it has BSODed several times again. I'm not sure what it is related to. My memory as...
Hi i have the same problem like Muddabir, i have the same picture as he, only that these 3 things are different, to me it says: C:\Windows\Minidump\111212-22588-01.dmp C:\Users\AppData\Local\Temp\WER-59763-0.sysdata.xml C:\Windows\MEMORY.dmp here is my file and i appriciated if you take...
Solved Can anyone help me with my BSoD problem in BSOD Crashes and Debugging
I says I must search "Page Fault In Non Paged Area". My computer does work, but if I leave it alone for too long, it crashes. I have searched it for a while now, I would download a program to fix it, but I do not have an uncapped data plan. I have put the .dmp file copy in the zip.
BSOD problem! in BSOD Crashes and Debugging
Hi everyone. Whenever I try to log off, shut down, restart, hibernate, sleep etc on my brand new computer, the procedure is beeing completed and right before finish, I get the Windows 8 bluescreen... When I first started using Windows 8 everything worked fine. All power-changes listed above...
