Help: Recovery Problem Error Code 0xc0000034
    Hello guys/girls
    I have a problem with my asus laptop pre installed with windows 8 and upgraded via store..my father borrow it for printing and after that in the same day i turned on my laptop and the blue screen with a message welcomed me
    "Recovery
    Your PC needs to be repaired
    The Boot Configuration Data File is missing some required information.
    File: \BCD
    Error code: 0xc0000034
    You'll need to use the recovery tools on your installation media. If you don't have any installation
    media (like a disc or usb device), contact your system administrator or pc manufacturer.
    Press ESC for UEFI Fireware settings"
    I googled about this problem and i learned that i need to have a recovery disk and i dont have that., but i managed to copy the recovery disk in my sister's windows 8 laptop(not updated to windows 8.1) and tried to put it in my laptop tried the step by step procedure that i read in the google but still it is not working..i just can only see the windows logo and after a few seconds my laptop restart and go back to the windows logo and it is just restart again many times...
    Harrisonburg, Va.
    Quote Originally Posted by David Bailey View Post
    thank you sir for the help..
    but sadly i dont have money to buy that...
    Harrisonburg, Va.
    Maybe someone here will offer better help.
    Sorry I couldn't help better. Attachment 49189
    Win8.1Pro - Finally!!!
    You can make a startup repair drive on another Win8 computer
    But you cannot reinstall Windows with this repair drive.
    To make the repair drive, go to Start and type in "recoverydrive" (without the quotes)
    Uncheck the box for copying the recovery partition as it won't be needed (it won't work)
    Then boot from the drive to perform Startup Repair/Automatic Repair.
    More details here: Recovery Drive - Create with USB Flash Drive in Windows 8
    If you need to reinstall Windows, then you'll need a copy of Windows to install.
:cry:I am desparate for help, My Lenovo Z580 Ideapad pre installed with windows 8 was working fine, I updated to windows 8.1 a few days ago and tonight my laptop shut down. When I tried to turn it back on a blue screen came up with the following on the screen. Recovery Your PC needs to be...
Hi Everyone, First post here, allow me to thank you in advance for your good help - people like me who have limited information on diagnostics and repair owe a deep debt of gratitude for your service. :) I own an Acer Aspire V5-571P-6815, which has put up the Recovery blue screen of death,...
Windows 8, "File: \BCD Error Code: 0xc0000034" Good Day Everyone, Trying to resolve this error: https://www.eightforums.com/attachments/performance-maintenance/43833d1401090904t-windows-8-missing-file-bcd-error-code-0xc0000034-20140526_015104.jpg I...
BSOD on File:\ BCD error code 0xc0000034 in BSOD Crashes and Debugging
After shutting down because of nonresponding applications, I started to the computer again to find the computer would not fail on automatic fix, after going through this several times I was presented with a BSOD on BSOD on File:\ BCD error code 0xc0000034, I do not have an installation cd, the...
FILE\BCD ERROR CODE: 0xc0000034 in BSOD Crashes and Debugging
OK, so I've been bad. I bought a new computer about 8 weeks ago and didn't get around to creating a recovery disk. Also I just moved, and didn't get around to shifting my online backup from my old computer to the new one yet. But what could go wrong, right? Error: RECOVERY YOUR PC...
Error Code: 0xc0000034 in BSOD Crashes and Debugging
Hi guys, I am receiving the following error code: "Recovery your Pc needs to be repaired The Boot Configuration Data file is missing some required information File:/BCD
Hello, I've just installed Windows 8 (from usb) on my brand new HP laptop and everything worked fine. But I didn't partition hard drive as I wanted, so I decided to install it again. During the 2nd installation, the keyboard wasn't working (don't know why). So, when I was supposed to make...
