PLEASE HELP : DRIVER_IRQL_NOT_LESS_OR_EQUAL BSOD problems
    Microsoft Windows 8.1 64-bit 9600 Multiprocessor Free
    Hey guys
    Please i really need some help, I just got a new HP ENVY laptop with windows 8.1 on it. However whenever i connect my internet modem , the laptop automatically crashes and the blue screen appears . At first i thought the problem was from my windows 8.1 OS , However i did some crash dump analysis and found out that the problem was driver related , I also asked some questions on the windows forum
    http://answers.microsoft.com/en-us/windows/forum/windows8_1-system/please-help-very-worried-windows-... , the members over there analysized the crash dump files and also attributed the problem to the mediatek/ralink driver. I was advised to update my mediatek/ralink drivers and also my BIOS . I would like to know if this error is common with this model of HP laptops and i would also appreciate if a solution to this problem.
    I used a crash dump analysis app to find the error , I have uploaded a zip folder with my dump files and i have also included the analysis as well,. Please i would really appreciate if someone could come to my aid urgently.
    Thanks
    "CRASH DUMP ANALYSIS
    System Information (local)
    computer name: SID-PC
    windows version: Windows 8.1 , 6.2, build: 9200
    windows dir: C:\Windows
    Hardware: HP ENVY 17 Notebook PC, Hewlett-Packard, 1968
    CPU: GenuineIntel Intel(R) Core(TM) i5-4200M CPU @ 2.50GHz Intel586, level: 6
    4 logical processors, active mask: 15
    RAM: 8518651904 total
    VM: 2147352576, free: 1928118272
    Crash Dump Analysis
    Crash dump directory: C:\Windows\Minidump
    Crash dumps are enabled on your computer.
    On Mon 23/06/2014 22:25:09 GMT your computer crashed
    crash dump file: C:\Windows\Minidump\062314-24265-01.dmp
    This was probably caused by the following module: mt7118vu_x64.sys (0xFFFFF80003D98E22)
    Bugcheck code: 0xD1 (0x0, 0x2, 0x0, 0xFFFFF80003D98E22)
    Error: DRIVER_IRQL_NOT_LESS_OR_EQUAL
    file path: C:\Windows\system32\drivers\mt7118vu_x64.sys
    product: MediaTek WiMAX Network Adapter Driver
    company: MediaTek Inc.
    description: NDIS 6.0 x86 Driver
    Bug check description: This indicates that a kernel-mode driver attempted to access pageable memory at a process IRQL that was too high.
    This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
    A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: mt7118vu_x64.sys (NDIS 6.0 x86 Driver, MediaTek Inc.).
    Google query: MediaTek Inc. DRIVER_IRQL_NOT_LESS_OR_EQUAL
    crash dump file: C:\Windows\memory.dmp
    This was probably caused by the following module: mt7118vu_x64.sys (mt7118vu_x64+0x3E22)
    On Mon 23/06/2014 22:22:02 GMT your computer crashed
    crash dump file: C:\Windows\Minidump\062314-22875-01.dmp
    This was probably caused by the following module: mt7118vu_x64.sys (0xFFFFF8000523EE22)
    Bugcheck code: 0xD1 (0x0, 0x2, 0x0, 0xFFFFF8000523EE22)
    On Mon 23/06/2014 07:41:26 GMT your computer crashed
    crash dump file: C:\Windows\Minidump\062314-22265-01.dmp
    This was probably caused by the following module: mt7118vu_x64.sys (0xFFFFF80003C11E22)
    Bugcheck code: 0xD1 (0x0, 0x2, 0x0, 0xFFFFF80003C11E22)
    On Mon 23/06/2014 07:37:40 GMT your computer crashed
    crash dump file: C:\Windows\Minidump\062314-22468-01.dmp
    This was probably caused by the following module: mt7118vu_x64.sys (0xFFFFF800047AAE22)
    Bugcheck code: 0xD1 (0x0, 0x2, 0x0, 0xFFFFF800047AAE22)
    Google query: MediaTek Inc. DRIVER_IRQL_NOT_LESS_OR_EQUAL"
    HERE IS A SCREEN SHOT OF THE DRIVERS , I HAVE HIGHLIGHTED THE MEDIATEK DRIVER
    Attachment 45973
    Please i would really appreciate if someone could help me with this. Thanks in advance
    Anyone willing to have a look at this ? Its been 2 days now and no one has bothered replying . Please i would really appreciate if someone shows interest in helping out.
    8.1 enterprise
    I believe the information you received on the previous forum was accurate. This is definitely a software issue and you need to try to update your drivers. There is a driver on the HP website that specifically relates to the problem you are having.
    Download the drivers from another computer and put them on a flash drive and transfer them to your computer with the issue.
    Drivers & software - HP Support Center
    Version:5.0.45.0 (17 Apr 2014) Fixes
    - Fixes an issue which causes a blue screen event to occur.
    I already updated the driver and it still gives this problem .
    8.1 enterprise
    In looking further, it looks like the driver designed to resolve that problem is the one you are running, however it is not the one that's crashing.
    You say that you are connecting your modem, is this a USB WiMax card? Who is the manufacturer? Is it actually MediaTek branded? If this is the case, you need to find out what the proper driver for the card is. Your first stop would be their website, i cannot tell you which driver to download because I do not know what the chipset it. If you can't find it on their website, call them.
    If this is a wimax card built into the HP Envy, contact HP directly via phone.
    its a USB wimax card (Mediatek MT7118)
    I just saw a post that was made some time ago
    critical_process_died. please help T-T
    You have a MediaTek MT7118 WiMAX USB Card - Win7 didn't like these devices, so I suspect that Windows 8 won't like them either. Here's my rant about these devices:
    I do not recommend using wireless USB devices. Especially in Win7/Windows 8 systems.
    These wireless USB devices have many issues with Win7(and I suspect with Windows 8) - using Vista drivers with them is almost sure to cause a BSOD.
    Should you want to keep using these devices, be sure to have Win7/Windows 8 drivers - DO NOT use Vista drivers!!!
    An installable wireless PCI/PCIe card that's plugged into your motherboard is much more robust, reliable, and powerful.
    The worst case scenario is to uninstall it's software and physically remove the device from the system in order to test if it's causing the BSOD's.
    I'm guessing this could be the same problem i am facing. So i would like to know if it is possible to update my MediaTek MT7118 WiMAX USB Card to one that works with Windows 8 or 8.1
    Win8.1Pro - Finally!!!
    Please provide this information so we can provide a complete analysis (from the Pinned Topic at the top of the forum): Blue Screen of Death (BSOD) Posting Instructions Please use Option 1 as it provides Event Viewer logs.
    I understand that this is a very important problem for you and that you'd like it solved as soon as is possible. But there are other circumstances that you may not be aware of. Please read this pinned topic about waiting for a response: Have you been waiting for a response?
    I am familiar with SpiritX and Zigzag3143 and they do excellent BSOD work.
    All 6 memory dumps blame mt7118vu_x64.sys - a driver for your MediaTek WIMAX adapter.
    HP support lists 94 different models of the HP Envy 17 system - which one is yours?
    HP Support, Drivers, Contact and Help Forums | HP о Support
    The MediaTek website doesn't list the Mediatek MT7118 USB card
    Where did you get the driver from (please provide a link)?
    The MediaTek driver that you highlighted in your first post dates from 2010
    The one in the dump files dates from 2011
    It's possible that this device is not compatible with Win8.1
    Please note the drivers below that date from before the release of Windows 8.1 (17 Oct 2013) - check to see that each and every one is compatible w/Windows 8.1 (at the manufacturer's website). If not, you must either remove the device and it's software - or locate a Windows 8.1 compatible update on the web. Removing some drivers may make the system unstable - so if you're unable to find updates, post back for info on the one's that can/cannot be safely removed.
    Without the additional reports that I requested in the first paragraph of my post, I cannot do much more for you.
    Good luck!
    Analysis:
    **************************Sat Jun 28 17:05:35.337 2014 (UTC - 4:00)**************************
    Loading Dump File [C:\Users\John\SysnativeBSODApps\062814-28234-01.dmp]
    Windows 8 Kernel Version 9600 MP (4 procs) Free x64
    Built by: 9600.17085.amd64fre.winblue_gdr.140330-1035
    System Uptime:0 days 0:49:54.119
    *** WARNING: Unable to verify timestamp for mt7118vu_x64.sys
    *** ERROR: Module load completed but symbols could not be loaded for mt7118vu_x64.sys
    Probably caused by :mt7118vu_x64.sys ( mt7118vu_x64+3e22 )
    BugCheck D1, {0, 2, 0, fffff801f6a39e22}
    BugCheck Info: DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
    Arguments:
    Arg1: 0000000000000000, memory referenced
    Arg2: 0000000000000002, IRQL
    Arg3: 0000000000000000, value 0 = read operation, 1 = write operation
    Arg4: fffff801f6a39e22, address which referenced memory
    BUGCHECK_STR:  AV
    PROCESS_NAME:  chrome.exe
    FAILURE_BUCKET_ID: AV_mt7118vu_x64+3e22
    CPUID:        "Intel(R) Core(TM) i5-4200M CPU @ 2.50GHz"
    MaxSpeed:     2500
    CurrentSpeed: 2494
      BIOS Version                  F.36
      BIOS Release Date             10/24/2013
      Manufacturer                  Hewlett-Packard
      Product Name                  HP ENVY 17 Notebook PC
    ииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииии``
    **************************Sat Jun 28 10:23:08.815 2014 (UTC - 4:00)**************************
    Loading Dump File [C:\Users\John\SysnativeBSODApps\062814-33765-01.dmp]
    Built by: 9600.17041.amd64fre.winblue_gdr.140305-1710
    System Uptime:0 days 0:11:24.607
    BugCheck D1, {0, 2, 0, fffff80158fcee22}
    Arguments:
    Arg4: fffff80158fcee22, address which referenced memory
    BUGCHECK_STR:  AV
    MaxSpeed:     2500
    CurrentSpeed: 2494
      BIOS Version                  F.36
    **************************Mon Jun 23 18:25:09.173 2014 (UTC - 4:00)**************************
    Loading Dump File [C:\Users\John\SysnativeBSODApps\062314-24265-01.dmp]
    Built by: 9600.16404.amd64fre.winblue_gdr.130913-2141
    System Uptime:0 days 0:02:36.946
    *** ERROR: Module load completed but symbols could not be loaded for tcpip.sys
    *** ERROR: Module load completed but symbols could not be loaded for afd.sys
    BugCheck D1, {0, 2, 0, fffff80003d98e22}
    Arguments:
    Arg4: fffff80003d98e22, address which referenced memory
    BUGCHECK_STR:  AV
    PROCESS_NAME:  svchost.exe
    MaxSpeed:     2500
    CurrentSpeed: 2494
      BIOS Version                  F.36
    **************************Mon Jun 23 18:22:02.333 2014 (UTC - 4:00)**************************
    Loading Dump File [C:\Users\John\SysnativeBSODApps\062314-22875-01.dmp]
    System Uptime:0 days 12:11:17.128
    BugCheck D1, {0, 2, 0, fffff8000523ee22}
    Arguments:
    Arg4: fffff8000523ee22, address which referenced memory
    BUGCHECK_STR:  AV
    MaxSpeed:     2500
    CurrentSpeed: 2494
      BIOS Version                  F.36
    **************************Mon Jun 23 03:41:26.270 2014 (UTC - 4:00)**************************
    Loading Dump File [C:\Users\John\SysnativeBSODApps\062314-22265-01.dmp]
    System Uptime:0 days 0:03:17.054
    BugCheck D1, {0, 2, 0, fffff80003c11e22}
    Arguments:
    Arg4: fffff80003c11e22, address which referenced memory
    BUGCHECK_STR:  AV
    MaxSpeed:     2500
    CurrentSpeed: 2494
      BIOS Version                  F.36
    **************************Mon Jun 23 03:37:40.857 2014 (UTC - 4:00)**************************
    Loading Dump File [C:\Users\John\SysnativeBSODApps\062314-22468-01.dmp]
    System Uptime:0 days 0:02:45.641
    BugCheck D1, {0, 2, 0, fffff800047aae22}
    Arguments:
    Arg4: fffff800047aae22, address which referenced memory
    BUGCHECK_STR:  AV
    MaxSpeed:     2500
    CurrentSpeed: 2494
      BIOS Version                  F.36
    3rd Party Drivers:
    mtkwmptv_x64.sys             Wed Jan 13 21:02:23 2010 (4B4E7B2F)
    mt7118vu_x64.sys             Tue Mar  8 21:56:04 2011 (4D76EC44)
    CLVirtualDrive.sys           Mon Dec 26 08:26:47 2011 (4EF87617)
    clwvd.sys                    Fri Aug  3 06:49:32 2012 (501BACBC)
    WirelessButtonDriver64.sys   Wed Aug 29 23:11:29 2012 (503ED9E1)
    ISCTD64.sys                  Tue Nov 27 14:52:34 2012 (50B51A02)
    Accelerometer.sys            Tue Feb 26 15:08:10 2013 (512D162A)
    hpdskflt.sys                 Tue Feb 26 15:08:12 2013 (512D162C)
    INETMON.sys                  Wed Mar 13 17:11:58 2013 (5140EB9E)
    TeeDriverx64.sys             Tue Jul  2 14:38:08 2013 (51D31E10)
    iwdbus.sys                   Wed Jul 24 21:06:12 2013 (51F07A04)
    Rt630x64.sys                 Fri Jul 26 03:01:35 2013 (51F21ECF)
    SynTP.sys                    Thu Aug  1 20:51:42 2013 (51FB029E)
    Smb_driver_Intel.sys         Thu Aug  1 20:54:20 2013 (51FB033C)
    ikbevent.sys                 Tue Aug  6 19:41:35 2013 (520189AF)
    imsevent.sys                 Tue Aug  6 19:45:57 2013 (52018AB5)
    stwrt64.sys                  Fri Aug 16 06:26:26 2013 (520DFE52)
    cnnctfy3.sys                 Fri Aug 16 13:12:46 2013 (520E5D8E)
    iaStorA.sys                  Fri Aug 16 13:22:01 2013 (520E5FB9)
    dump_iaStorA.sys             Fri Aug 16 13:22:01 2013 (520E5FB9)
    nvlddmkm.sys                 Sun Aug 18 14:21:08 2013 (52111094)
    igdkmd64.sys                 Mon Aug 19 19:08:25 2013 (5212A569)
    RtsPer.sys                   Wed Aug 21 03:23:24 2013 (52146AEC)
    intelppm.sys                 Thu Aug 22 04:46:35 2013 (5215CFEB)
    rtbth.sys                    Thu Nov 28 22:13:06 2013 (52980642)
    mfencbdc.sys                 Tue Mar 18 10:04:48 2014 (53285280)
    mfehidk.sys                  Fri Mar 21 16:53:03 2014 (532CA6AF)
    mfewfpk.sys                  Fri Mar 21 16:53:16 2014 (532CA6BC)
    mfeapfk.sys                  Fri Mar 21 16:53:41 2014 (532CA6D5)
    mfeavfk.sys                  Fri Mar 21 16:53:56 2014 (532CA6E4)
    mfefirek.sys                 Fri Mar 21 16:55:15 2014 (532CA733)
    cfwids.sys                   Fri Mar 21 16:55:40 2014 (532CA74C)
    netr28x.sys                  Sat Mar 29 02:14:55 2014 (533664DF)
    agp440.sys                   Thu Aug 22 07:39:35 2013 (5215F877)
    nv_agp.sys                   Thu Aug 22 07:39:38 2013 (5215F87A)
    netr28x.sys                  Tue Nov 26 03:32:39 2013 (52945CA7)
    mfehidk.sys                  Thu Aug  1 19:40:33 2013 (51FAF1F1)
    mfewfpk.sys                  Thu Aug  1 19:40:45 2013 (51FAF1FD)
    mfeapfk.sys                  Thu Aug  1 19:41:10 2013 (51FAF216)
    mfeavfk.sys                  Thu Aug  1 19:41:25 2013 (51FAF225)
    mfefirek.sys                 Thu Aug  1 19:42:47 2013 (51FAF277)
    cfwids.sys                   Thu Aug  1 19:43:19 2013 (51FAF297)
    mfencbdc.sys                 Thu Oct 31 02:19:54 2013 (5271F68A)
    mtkwmptv_x64.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
    mt7118vu_x64.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
    http://www.carrona.org/drivers/driver.php?id=CLVirtualDrive.sys
    http://www.carrona.org/drivers/driver.php?id=clwvd.sys
    http://www.carrona.org/drivers/driver.php?id=WirelessButtonDriver64.sys
    http://www.carrona.org/drivers/driver.php?id=ISCTD64.sys
    http://www.carrona.org/drivers/driver.php?id=Accelerometer.sys
    http://www.carrona.org/drivers/driver.php?id=hpdskflt.sys
    INETMON.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
    http://www.carrona.org/drivers/driver.php?id=TeeDriverx64.sys
    http://www.carrona.org/drivers/driver.php?id=iwdbus.sys
    http://www.carrona.org/drivers/driver.php?id=SynTP.sys
    http://www.carrona.org/drivers/driver.php?id=Smb_driver_Intel.sys
    http://www.carrona.org/drivers/driver.php?id=ikbevent.sys
    http://www.carrona.org/drivers/driver.php?id=imsevent.sys
    http://www.carrona.org/drivers/driver.php?id=stwrt64.sys
    http://www.carrona.org/drivers/driver.php?id=cnnctfy3.sys
    http://www.carrona.org/drivers/driver.php?id=igdkmd64.sys
    http://www.carrona.org/drivers/driver.php?id=RtsPer.sys
    http://www.carrona.org/drivers/driver.php?id=rtbth.sys
    http://www.carrona.org/drivers/driver.php?id=mfencbdc.sys
    http://www.carrona.org/drivers/driver.php?id=mfehidk.sys
    http://www.carrona.org/drivers/driver.php?id=mfewfpk.sys
    http://www.carrona.org/drivers/driver.php?id=mfeapfk.sys
    http://www.carrona.org/drivers/driver.php?id=mfeavfk.sys
    http://www.carrona.org/drivers/driver.php?id=mfefirek.sys
    http://www.carrona.org/drivers/driver.php?id=cfwids.sys
    http://www.carrona.org/drivers/driver.php?id=netr28x.sys
    http://www.carrona.org/drivers/driver.php?id=agp440.sys
    http://www.carrona.org/drivers/driver.php?id=nv_agp.sys
    Hello Usama
    Thanks for replying , I didn't download the The MT7118 driver , It seemed to have been pre-installed in the modem . When i click "about" on the modem interface it shows the modem driver as "mediatek MT7118" . Here is the SF file you requested. My HP 17'' ENVY model is ENVY 17-j101sa
Page 1 of 2 12 LastLast
Solved BSOD Driver_irql_not_less_or_equal (netio.sys) in BSOD Crashes and Debugging
I have BSOD after I installed latest windows updates few day ago. I have updated all drivers I have found. Could you help me please.
At times when I play the game League of Legends, my computer crashes with the blue screen error DRIVER_IRQL_NOT_LESS_OR_EQUAL (igdkmd64.sys) My system runs on Intel(R) HD Graphics 4000 and I'm not entirely sure why this error appears from time to time. I read some forums and many problems from...
Bsod driver_irql_not_less_or_equal in BSOD Crashes and Debugging
Hi, I am running windows 8.1 and I have gotten three of these crashes in the past 8 days. My computer feels laggier after restarting and it takes a while for the login screen to show up. I am attaching the three dumps and the system info files extracted with the forum tool. The last dump has...
Hello everyone ! i started to get that BSOD after I installed windows updates few days ago. i think i have updated all drivers but no change.. uTorrent might be the problem, because whenever i start the program, BSOD occurs in a couple of minutes afterwards. i read similar threads but i...
Solved Bsod: Driver_irql_not_less_or_equal in BSOD Crashes and Debugging
Hello I was doing some video editing on Sony Vegas 12.0 when my computer crashed to this BSOD. I was too worried about losing about 5 hours worth of video editing, so I restarted and opened the auto-save that Sony Vegas had saved. My computer instantly crashed again with the same error. After...
Hopefully I'm doing this right. I attached the BSOD using the SF Diagnostic Tool here. I've been having these BSOD's randomly. I also ran WhoCrashed: This was probably caused by the following module: tcpip.sys (tcpip+0x93FA5) Bugcheck code: 0xD1 (0x3C, 0x2, 0x1, 0xFFFFF88001B2DFA5) Error:...
Driver_irql_not_less_or_equal bsod in BSOD Crashes and Debugging
Hello all, first BSOD problem with Windows 8. It happens when awaking form sleep mode, but it doesn't happen every time. BSOD Files: 16242 Thanks in advance! 16240
