PLEASE HELP : DRIVER_IRQL_NOT_LESS_OR_EQUAL BSOD problems
  1. #11
    Win8.1Pro - Finally!!!
    What's the make and model of the modem?
    I would contact the support center for the modem and see if:
    - they have any more recent drivers
    - if the device is compatible with Win8.1
    If unable to get Win8.1 compatible drivers for the device, my suggestion is to get a device that is compatible with Win8.1
    As an aside, some HP's have had BIOS/UEFI issues w/Win8.1 Please see about updating the BIOS/UEFI to the latest version (your current version is F.36 and the most current version is F.56). I believe this is the driver download link for your system: Software & driver downloads HP ENVY 17-j101sa Notebook PC | HP® Support
    Beyond that, there's not much else that we can do here. There is a small possibility that the BIOS/UEFI update may help your BSOD issues. But the incompatibility will still exist even if the device seems to be working properly (for the time being).
    Also, make sure that you keep up with the Windows Updates. This is a "double-edged sword" - it may help improve compatibility or it may cause further issues with the WiMax device. There's no telling until you try it.
    Good luck!
  2. #12
    Microsoft Windows 8.1 64-bit 9600 Multiprocessor Free
    Hi Usama , I really appreciate your interest in helping me . The make and model of the modem is greenpacket UH250.
  3. #13
    Greenpacket does not provide drivers for their products on the web.
    I'd suggest checking with the telecom provider for this device to see if they have Win8.1 compatible drivers for it.
    If not, your choices are to get a new modem or to downgrade your system to one that is compatible w/the current drivers (I'd suggest Win7).
    Good luck!
Page 2 of 2 FirstFirst 12
Solved BSOD Driver_irql_not_less_or_equal (netio.sys) in BSOD Crashes and Debugging
I have BSOD after I installed latest windows updates few day ago. I have updated all drivers I have found. Could you help me please.
At times when I play the game League of Legends, my computer crashes with the blue screen error DRIVER_IRQL_NOT_LESS_OR_EQUAL (igdkmd64.sys) My system runs on Intel(R) HD Graphics 4000 and I'm not entirely sure why this error appears from time to time. I read some forums and many problems from...
Bsod driver_irql_not_less_or_equal in BSOD Crashes and Debugging
Hi, I am running windows 8.1 and I have gotten three of these crashes in the past 8 days. My computer feels laggier after restarting and it takes a while for the login screen to show up. I am attaching the three dumps and the system info files extracted with the forum tool. The last dump has...
Hello everyone ! i started to get that BSOD after I installed windows updates few days ago. i think i have updated all drivers but no change.. uTorrent might be the problem, because whenever i start the program, BSOD occurs in a couple of minutes afterwards. i read similar threads but i...
Solved Bsod: Driver_irql_not_less_or_equal in BSOD Crashes and Debugging
Hello I was doing some video editing on Sony Vegas 12.0 when my computer crashed to this BSOD. I was too worried about losing about 5 hours worth of video editing, so I restarted and opened the auto-save that Sony Vegas had saved. My computer instantly crashed again with the same error. After...
Hopefully I'm doing this right. I attached the BSOD using the SF Diagnostic Tool here. I've been having these BSOD's randomly. I also ran WhoCrashed: This was probably caused by the following module: tcpip.sys (tcpip+0x93FA5) Bugcheck code: 0xD1 (0x3C, 0x2, 0x1, 0xFFFFF88001B2DFA5) Error:...
Driver_irql_not_less_or_equal bsod in BSOD Crashes and Debugging
Hello all, first BSOD problem with Windows 8. It happens when awaking form sleep mode, but it doesn't happen every time. BSOD Files: 16242 Thanks in advance! 16240
