need help to identify problem
    hi guys, could you please help me to identify what's wrong with my computer, got this BSOD an hour ago
    update with good format files
    oops, forgot to include whole drive list
    Win8.1Pro - Finally!!!
    Only 47 Windows Updates installed. Most systems have 66 or more. Please visit Windows Update and get ALL available updates (it may take several trips to get them all). secdrv.sys dates from 2006 - my Win8 system has it being from July 2012.
    Your USB modem's drivers date from 2010 and 2011 - please uninstall them and install the latest, Win8 compatible drivers for your system.
    Have seen a couple of issues with EagleX64.sys recently - try uninstalling Hack Shield anti-cheat gaming driver
    Out of 5 memory dumps there were 3 different BSOD error codes. The differing error codes are usually symptomatic of a lower level problem within the system. They are usually caused by one of these things:
    - borked (broken) hardware (several different procedures used to isolate the problem device)
    - BIOS issues (check for updates at the motherboard manufacturer's website)
    - overclocking - You'll know if you're overclocking or not. If uncertain we can suggest things to check.
    - compatibility issues (3rd party hardware/drivers)
    - low-level driver problems
    - or even malware (scanned for when we ask for hardware diagnostics from Initial Hardware Diagnostics or Hardware Diagnostics ).
    You can get a head start on the hardware diagnostics if you'd like - they are located here: Hardware Diagnostics
    Also, run Driver Verifier according to these directions (if the BSOD's continue): Driver Verifier Settings
    hi,
    I just did clean install, and update the modem's to the new that i got, but not sure it's the latest or not
    but, I still got new bsod, could you please help me again to analyze what's problem?
    thanks
    Have you run the hardware diagnostics that I suggested? If not, here's the link again: Hardware Diagnostics
    Quote Originally Posted by usasma View Post
    which one? the malware one or whole? k, i'll try
    forgot to say that, i had a driver verifier and got bsod says driver_verifier_detected violation
    I attach my minidump
    Run all of them, start with the video tests as the Driver Verifier memory dump blames video.
    just did memtest, 100% and says none error found
    gotta check video test
Here is my problem When i write my DVD-R with Nero/Imgburn/Burnaware it says burnt successful but it fails to verify and even dvd is blank when i reinsert in laptop and my friends computer. I have tried to burnt at slower speeds but still same problem.:rolleyes: My dvd drive reads other DVDs...
Identify Processes Running Upon Login? in Performance & Maintenance
Lately, and I'm not sure if I'm noticing it for the first time, after I login and access my desktop from the touch screen, I can't access any programs until after a few seconds (maybe 10-15). Is it possible there are background programs running that are interfering here? If so is there a way to...
I have 2 issues. I don't know if they are related somehow. 1. I installed PrivaZer and deleted it. It still shows up on the right click context menu. I tried to reinstall it and deleted it again. I still have that problem. I even restarted the computer. How can I get rid of the entry? 2....
I have a folder in Windows 8 (C) now which I believe pertains to Windows 8.1 Update 1. Can someone explain to me what it is - and if it is a necessary file which I should leave as is. Screenshot of the contents is attached. Appreciate any help on this. Thanks.
Every morning at 5am, I recieve the Open With dialog, and it doesn't tell me a) what process is trying to open, b) what type of file it's trying to open. No matter what I try with, I receive an error saying "Cannot find C:\Program" and sometimes has an extension if the app auto-applies (such as...
I had no problems with Customer Preview, everything worked, but, I must say that this Release Preview is another story all together. My PC hardware configuration is unchanged since installing Windows 7 when it came on to the market. 1. Doing a clean install did not install a clean...
