PC ran into a problem, needs to restart--repeatedly, loop
nightingale
hello,
I bought a new laptop, fujitsu brand, a few weeks ago. It has been running great until 2 days ago it started the crash/restart loop.
It only reboots for a couple of minutes before it crashes again, and I've unable to get much done but was able to get a copy of the most recent minidump file. However, I am unsure what to do with it/how to upload it here.
Any help would be appreciated. Thanks!
    Fujitsu
looks like I missed the important instructions at the top of the forum. I will go check those out. sorry!
    Fujitsu
    Win8.1Pro - Finally!!!
    Samsung/NP780
    upgraded to 12 gB from 8 gB
    800x600
    no Mouse - Trackball!!!!
My computer won't stay "on" long enough to run the SF Diagnostic tool. It restarts in the middle. I will try starting in safe mode.
    Fujitsu
Ok, iit seemed to have ran in Safe mode, but it also seemed to have a few glitches.
thanks for whatever help you can give me.
    Fujitsu
This device has issues:
Fujitsu Wireless Radio Switch Driver ROOT\SYSTEM\0003 This device cannot start.
Please download a fresh copy of the latest, Win8 compatible version of the software/drivers for this device from the Fujitsu website. Then uninstall the current version and install the freshly downloaded version.
You have both AVG and Norton installed.
1) Please do this:
Anti-Virus Removal:
Please do the following:
- download a free anti-virus for testing purposes: Free AntiVirus If using Windows 8, enable Windows Defender and the Windows Firewall instead.
- un-install the Norton from your system (you can reinstall it, if so desired, when we're done troubleshooting)
- remove any remnants of Norton using this free tool: http://us.norton.com/support/kb/web_view.jsp?wv_type=public_web&docurl=20080710133834EN
- IMMEDIATELY install and update the free anti-virus (if using Win8, enable Windows Defender), then check to ensure that the Windows Firewall is turned on.
- perform a full system scan to ensure that no malware has snuck onto your system while the anti-virus was malfunctioning.
- check to see if this fixes the BSOD's
NOTE: NEVER run more than 1 anti-virus, firewall, Internet Security/Security Center application at the same time.
2) Then please ensure that AVG is the latest. Win8 compatible version available from the AVG website
As all of the memory dumps blame networking components - I'd have to suspect that one/both of the above problems are the cause of your BSOD's. If the BSOD's continue after fixing both of them, then please post back for further tests to see if there is something else to blame.
FUJ02B1.sys Wed Nov 1 05:50:43 2006 (45486DF3)
Fujitsu FUJ02B1 device driver
http://www.carrona.org/drivers/driver.php?id=FUJ02B1.sys
Analysis:
[font=lucida console]**************************Tue Mar 19 12:55:44.235 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031913-38593-01.dmp]
Built by: [B]9200[/B].16496.amd64fre.win8_gdr.130108-1504
System Uptime:[B]0 days 0:03:43.936[/B]
*** ERROR: Module load completed but symbols could not be loaded for tcpip.sys
Probably caused by :[B]tcpip.sys ( tcpip+3cf62 )[/B]
BugCheck [B]3B, {c0000005, fffff88001ceef62, fffff8801a06eb80, 0}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x0000003B]SYSTEM_SERVICE_EXCEPTION (3b)[/url]
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff88001ceef62, Address of the instruction which caused the bugcheck
Arg3: fffff8801a06eb80, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
BUGCHECK_STR:  0x3B
PROCESS_NAME:  wmpnetwk.exe
FAILURE_BUCKET_ID: [B]0x3B_tcpip+3cf62[/B]
CPUID:        "Intel(R) Core(TM) i3-3110M CPU @ 2.40GHz"
MaxSpeed:     2400
CurrentSpeed: [B]2395[/B]
  BIOS Version                  Version 2.08
  BIOS Release Date             10/25/2012
  Manufacturer                  FUJITSU
  Product Name                  LIFEBOOK AH532
**************************Tue Mar 19 12:51:24.801 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031913-43671-01.dmp]
System Uptime:[B]0 days 0:03:47.502[/B]
BugCheck [B]3B, {c0000005, fffff88001c75f62, fffff88018eadb80, 0}[/B]
Arguments:
Arg2: fffff88001c75f62, Address of the instruction which caused the bugcheck
Arg3: fffff88018eadb80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     2400
**************************Tue Mar 19 12:47:01.487 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031913-51843-01.dmp]
System Uptime:[B]8 days 11:21:03.972[/B]
BugCheck [B]3B, {c0000005, fffff88001d23f62, fffff8801c630b80, 0}[/B]
Arguments:
Arg2: fffff88001d23f62, Address of the instruction which caused the bugcheck
Arg3: fffff8801c630b80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     2400
**************************Mon Mar 11 01:25:23.945 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-27421-01.dmp]
System Uptime:[B]0 days 0:03:22.646[/B]
BugCheck [B]3B, {c0000005, fffff88001c74f62, fffff88019bdab80, 0}[/B]
Arguments:
Arg2: fffff88001c74f62, Address of the instruction which caused the bugcheck
Arg3: fffff88019bdab80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     2400
**************************Mon Mar 11 01:21:29.617 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-27187-01.dmp]
System Uptime:[B]0 days 0:03:23.319[/B]
BugCheck [B]3B, {c0000005, fffff880020cdf62, fffff8801a1c5b80, 0}[/B]
Arguments:
Arg2: fffff880020cdf62, Address of the instruction which caused the bugcheck
Arg3: fffff8801a1c5b80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     2400
**************************Mon Mar 11 01:17:33.367 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-27656-01.dmp]
System Uptime:[B]0 days 0:03:19.068[/B]
BugCheck [B]3B, {c0000005, fffff88001e66f62, fffff8801a08ab80, 0}[/B]
Arguments:
Arg2: fffff88001e66f62, Address of the instruction which caused the bugcheck
Arg3: fffff8801a08ab80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     2400
**************************Mon Mar 11 01:13:44.209 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-28171-02.dmp]
System Uptime:[B]0 days 0:03:16.910[/B]
BugCheck [B]3B, {c0000005, fffff88001d31f62, fffff88019eadb80, 0}[/B]
Arguments:
Arg2: fffff88001d31f62, Address of the instruction which caused the bugcheck
Arg3: fffff88019eadb80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     2400
**************************Mon Mar 11 01:09:54.989 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-27531-01.dmp]
System Uptime:[B]0 days 0:03:18.690[/B]
BugCheck [B]3B, {c0000005, fffff88001cf3f62, fffff88018c59b80, 0}[/B]
Arguments:
Arg2: fffff88001cf3f62, Address of the instruction which caused the bugcheck
Arg3: fffff88018c59b80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     2400
**************************Mon Mar 11 01:06:07.358 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-27921-01.dmp]
System Uptime:[B]0 days 0:03:19.059[/B]
BugCheck [B]3B, {c0000005, fffff88001cd3f62, fffff8801af86b80, 0}[/B]
Arguments:
Arg2: fffff88001cd3f62, Address of the instruction which caused the bugcheck
Arg3: fffff8801af86b80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     2400
**************************Mon Mar 11 01:02:17.969 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-27390-01.dmp]
System Uptime:[B]0 days 0:03:20.671[/B]
BugCheck [B]3B, {c0000005, fffff88001e90f62, fffff88019d9bb80, 0}[/B]
Arguments:
Arg2: fffff88001e90f62, Address of the instruction which caused the bugcheck
Arg3: fffff88019d9bb80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     2400
**************************Mon Mar 11 00:58:27.237 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-28109-01.dmp]
System Uptime:[B]0 days 0:03:19.938[/B]
BugCheck [B]3B, {c0000005, fffff88001f0df62, fffff88019c6eb80, 0}[/B]
Arguments:
Arg2: fffff88001f0df62, Address of the instruction which caused the bugcheck
Arg3: fffff88019c6eb80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     2400
**************************Mon Mar 11 00:54:37.382 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-27890-01.dmp]
System Uptime:[B]0 days 0:03:19.083[/B]
BugCheck [B]3B, {c0000005, fffff88001cf4f62, fffff88019d0fb80, 0}[/B]
Arguments:
Arg2: fffff88001cf4f62, Address of the instruction which caused the bugcheck
Arg3: fffff88019d0fb80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     2400
**************************Mon Mar 11 00:50:47.724 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-27625-01.dmp]
System Uptime:[B]0 days 0:03:21.425[/B]
BugCheck [B]3B, {c0000005, fffff88001ca0f62, fffff8801a0f3b80, 0}[/B]
Arguments:
Arg2: fffff88001ca0f62, Address of the instruction which caused the bugcheck
Arg3: fffff8801a0f3b80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     2400
**************************Mon Mar 11 00:46:55.145 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-29953-02.dmp]
System Uptime:[B]0 days 0:03:16.846[/B]
BugCheck [B]3B, {c0000005, fffff88001c93f62, fffff8801944bb80, 0}[/B]
Arguments:
Arg2: fffff88001c93f62, Address of the instruction which caused the bugcheck
Arg3: fffff8801944bb80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     2400
**************************Mon Mar 11 00:43:09.144 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-27343-01.dmp]
System Uptime:[B]0 days 0:03:18.845[/B]
BugCheck [B]3B, {c0000005, fffff88001cf9f62, fffff8801a03db80, 0}[/B]
Arguments:
Arg2: fffff88001cf9f62, Address of the instruction which caused the bugcheck
Arg3: fffff8801a03db80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     2400
**************************Mon Mar 11 00:39:19.627 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-27781-01.dmp]
System Uptime:[B]0 days 0:03:20.328[/B]
BugCheck [B]3B, {c0000005, fffff88001c90f62, fffff8801a052b80, 0}[/B]
Arguments:
Arg2: fffff88001c90f62, Address of the instruction which caused the bugcheck
Arg3: fffff8801a052b80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     2400
**************************Mon Mar 11 00:35:28.157 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-28671-01.dmp]
System Uptime:[B]0 days 0:03:20.858[/B]
BugCheck [B]3B, {c0000005, fffff88001e72f62, fffff8801a555b80, 0}[/B]
Arguments:
Arg2: fffff88001e72f62, Address of the instruction which caused the bugcheck
Arg3: fffff8801a555b80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     2400
**************************Mon Mar 11 00:31:36.972 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-28109-02.dmp]
System Uptime:[B]0 days 0:03:18.673[/B]
BugCheck [B]3B, {c0000005, fffff88001ca6f62, fffff88019e21b80, 0}[/B]
Arguments:
Arg2: fffff88001ca6f62, Address of the instruction which caused the bugcheck
Arg3: fffff88019e21b80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     2400
**************************Mon Mar 11 00:27:48.414 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-27640-01.dmp]
System Uptime:[B]0 days 0:03:21.115[/B]
BugCheck [B]3B, {c0000005, fffff88001c97f62, fffff8801a55eb80, 0}[/B]
Arguments:
Arg2: fffff88001c97f62, Address of the instruction which caused the bugcheck
Arg3: fffff8801a55eb80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     2400
**************************Mon Mar 11 00:23:56.630 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-28031-01.dmp]
System Uptime:[B]0 days 0:03:19.331[/B]
BugCheck [B]3B, {c0000005, fffff88001e85f62, fffff88019e0cb80, 0}[/B]
Arguments:
Arg2: fffff88001e85f62, Address of the instruction which caused the bugcheck
Arg3: fffff88019e0cb80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     2400
**************************Mon Mar 11 00:20:06.734 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-28093-01.dmp]
System Uptime:[B]0 days 0:03:19.435[/B]
BugCheck [B]3B, {c0000005, fffff88001cc0f62, fffff88019ddab80, 0}[/B]
Arguments:
Arg2: fffff88001cc0f62, Address of the instruction which caused the bugcheck
Arg3: fffff88019ddab80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     2400
**************************Mon Mar 11 00:16:18.774 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-29250-01.dmp]
System Uptime:[B]0 days 0:03:20.476[/B]
BugCheck [B]3B, {c0000005, fffff88001e59f62, fffff8801a2d7b80, 0}[/B]
Arguments:
Arg2: fffff88001e59f62, Address of the instruction which caused the bugcheck
Arg3: fffff8801a2d7b80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     2400
**************************Mon Mar 11 00:12:26.092 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-28156-01.dmp]
System Uptime:[B]0 days 0:03:19.793[/B]
BugCheck [B]3B, {c0000005, fffff88001ea9f62, fffff8801a252b80, 0}[/B]
Arguments:
Arg2: fffff88001ea9f62, Address of the instruction which caused the bugcheck
Arg3: fffff8801a252b80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     2400
**************************Mon Mar 11 00:08:37.321 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-29109-01.dmp]
System Uptime:[B]0 days 0:03:24.022[/B]
BugCheck [B]3B, {c0000005, fffff88002132f62, fffff88019c3db80, 0}[/B]
Arguments:
Arg2: fffff88002132f62, Address of the instruction which caused the bugcheck
Arg3: fffff88019c3db80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     2400
**************************Mon Mar 11 00:04:43.586 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-29046-01.dmp]
System Uptime:[B]0 days 0:03:22.287[/B]
BugCheck [B]3B, {c0000005, fffff88001cc9f62, fffff8801a18db80, 0}[/B]
Arguments:
Arg2: fffff88001cc9f62, Address of the instruction which caused the bugcheck
Arg3: fffff8801a18db80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     2400
**************************Mon Mar 11 00:00:52.632 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-30656-01.dmp]
System Uptime:[B]0 days 0:03:20.333[/B]
BugCheck [B]3B, {c0000005, fffff88001c48f62, fffff8801922fb80, 0}[/B]
Arguments:
Arg2: fffff88001c48f62, Address of the instruction which caused the bugcheck
Arg3: fffff8801922fb80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     2400
**************************Sun Mar 10 23:56:59.546 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-31734-01.dmp]
System Uptime:[B]0 days 0:03:27.247[/B]
BugCheck [B]3B, {c0000005, fffff88001c41f62, fffff8801ab71b80, 0}[/B]
Arguments:
Arg2: fffff88001c41f62, Address of the instruction which caused the bugcheck
Arg3: fffff8801ab71b80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     2400
**************************Sun Mar 10 23:52:57.614 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-41296-01.dmp]
System Uptime:[B]0 days 0:03:23.316[/B]
BugCheck [B]3B, {c0000005, fffff88001e3ff62, fffff88019f9bb80, 0}[/B]
Arguments:
Arg2: fffff88001e3ff62, Address of the instruction which caused the bugcheck
Arg3: fffff88019f9bb80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     2400
**************************Sun Mar 10 23:49:01.475 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-37593-01.dmp]
System Uptime:[B]0 days 0:03:19.176[/B]
BugCheck [B]3B, {c0000005, fffff88001ca7f62, fffff88018ec9b80, 0}[/B]
Arguments:
Arg2: fffff88001ca7f62, Address of the instruction which caused the bugcheck
Arg3: fffff88018ec9b80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     2400
**************************Sun Mar 10 23:41:05.530 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-44750-01.dmp]
System Uptime:[B]0 days 0:03:34.232[/B]
BugCheck [B]3B, {c0000005, fffff88001caaf62, fffff8801b3a2b80, 0}[/B]
Arguments:
Arg2: fffff88001caaf62, Address of the instruction which caused the bugcheck
Arg3: fffff8801b3a2b80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     2400
**************************Sun Mar 10 23:17:40.125 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-29640-01.dmp]
System Uptime:[B]0 days 0:03:13.826[/B]
BugCheck [B]3B, {c0000005, fffff88001cb7f62, fffff8801a108b80, 0}[/B]
Arguments:
Arg2: fffff88001cb7f62, Address of the instruction which caused the bugcheck
Arg3: fffff8801a108b80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     2400
**************************Sun Mar 10 23:11:23.829 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-29843-01.dmp]
System Uptime:[B]0 days 0:03:25.530[/B]
BugCheck [B]3B, {c0000005, fffff88001c80f62, fffff8801c6f3b80, 0}[/B]
Arguments:
Arg2: fffff88001c80f62, Address of the instruction which caused the bugcheck
Arg3: fffff8801c6f3b80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     2400
**************************Sun Mar 10 23:07:22.618 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-30406-02.dmp]
System Uptime:[B]0 days 0:03:47.503[/B]
BugCheck [B]3B, {c0000005, fffff88001c91f62, fffff8801c6e5b80, 0}[/B]
Arguments:
Arg2: fffff88001c91f62, Address of the instruction which caused the bugcheck
Arg3: fffff8801c6e5b80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     2400
**************************Sun Mar 10 23:02:50.428 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-29437-01.dmp]
System Uptime:[B]0 days 0:03:25.129[/B]
BugCheck [B]3B, {c0000005, fffff88001ca8f62, fffff88019b9bb80, 0}[/B]
Arguments:
Arg2: fffff88001ca8f62, Address of the instruction which caused the bugcheck
Arg3: fffff88019b9bb80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     2400
**************************Sun Mar 10 22:58:46.381 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-30703-01.dmp]
System Uptime:[B]0 days 0:03:26.082[/B]
BugCheck [B]3B, {c0000005, fffff88001c75f62, fffff8801a059b80, 0}[/B]
Arguments:
Arg3: fffff8801a059b80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     2400
**************************Sun Mar 10 22:54:47.243 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-31312-01.dmp]
System Uptime:[B]0 days 0:03:50.944[/B]
BugCheck [B]3B, {c0000005, fffff88001cd5f62, fffff8801c525b80, 0}[/B]
Arguments:
Arg2: fffff88001cd5f62, Address of the instruction which caused the bugcheck
Arg3: fffff8801c525b80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     2400
**************************Sun Mar 10 22:50:21.565 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-30906-01.dmp]
System Uptime:[B]0 days 0:03:44.266[/B]
BugCheck [B]3B, {c0000005, fffff88001e81f62, fffff8801b5bfb80, 0}[/B]
Arguments:
Arg2: fffff88001e81f62, Address of the instruction which caused the bugcheck
Arg3: fffff8801b5bfb80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     2400
**************************Sun Mar 10 22:46:02.894 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-32109-01.dmp]
System Uptime:[B]0 days 0:03:35.595[/B]
BugCheck [B]3B, {c0000005, fffff88001d16f62, fffff8801bab4b80, 0}[/B]
Arguments:
Arg2: fffff88001d16f62, Address of the instruction which caused the bugcheck
Arg3: fffff8801bab4b80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     2400
**************************Sun Mar 10 22:41:54.680 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-31000-02.dmp]
System Uptime:[B]0 days 0:03:16.381[/B]
BugCheck [B]3B, {c0000005, fffff88001cf4f62, fffff88019e1ab80, 0}[/B]
Arguments:
Arg3: fffff88019e1ab80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     2400
**************************Sun Mar 10 22:23:42.437 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-29531-01.dmp]
System Uptime:[B]0 days 0:03:37.138[/B]
BugCheck [B]3B, {c0000005, fffff88001e65f62, fffff8801bb78b80, 0}[/B]
Arguments:
Arg2: fffff88001e65f62, Address of the instruction which caused the bugcheck
Arg3: fffff8801bb78b80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     2400
**************************Sun Mar 10 21:53:57.330 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-20890-01.dmp]
System Uptime:[B]0 days 0:00:31.031[/B]
*** WARNING: Unable to verify timestamp for avgwfpa.sys
*** ERROR: Module load completed but symbols could not be loaded for avgwfpa.sys
Probably caused by :[B]avgwfpa.sys ( avgwfpa+6286 )[/B]
BugCheck [B]A, {a8, 2, 1, fffff801866bc2ff}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x0000000A]IRQL_NOT_LESS_OR_EQUAL (a)[/url]
Arguments:
Arg1: 00000000000000a8, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000001, bitfield :
    bit 0 : value 0 = read operation, 1 = write operation
    bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)
Arg4: fffff801866bc2ff, address which referenced memory
BUGCHECK_STR:  AV
PROCESS_NAME:  avgnsa.exe
FAILURE_BUCKET_ID: [B]AV_avgwfpa+6286[/B]
MaxSpeed:     2400
**************************Sun Mar 10 21:48:10.776 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-28281-01.dmp]
System Uptime:[B]0 days 0:03:19.477[/B]
BugCheck [B]3B, {c0000005, fffff88001c5af62, fffff880072e1b80, 0}[/B]
Arguments:
Arg2: fffff88001c5af62, Address of the instruction which caused the bugcheck
Arg3: fffff880072e1b80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     2400
**************************Sun Mar 10 21:42:33.330 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-29953-01.dmp]
System Uptime:[B]0 days 0:04:08.031[/B]
BugCheck [B]3B, {c0000005, fffff88001e6bf62, fffff8801c2bfb80, 0}[/B]
Arguments:
Arg2: fffff88001e6bf62, Address of the instruction which caused the bugcheck
Arg3: fffff8801c2bfb80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     2400
**************************Sun Mar 10 21:37:52.079 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-26140-01.dmp]
System Uptime:[B]0 days 0:03:40.780[/B]
BugCheck [B]3B, {c0000005, fffff88001c5ef62, fffff8801b80cb80, 0}[/B]
Arguments:
Arg2: fffff88001c5ef62, Address of the instruction which caused the bugcheck
Arg3: fffff8801b80cb80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     2400
**************************Sun Mar 10 21:33:42.374 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-25218-01.dmp]
System Uptime:[B]0 days 0:03:21.075[/B]
BugCheck [B]3B, {c0000005, fffff88001cf5f62, fffff8801ac0cb80, 0}[/B]
Arguments:
Arg2: fffff88001cf5f62, Address of the instruction which caused the bugcheck
Arg3: fffff8801ac0cb80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     2400
**************************Sun Mar 10 21:29:51.167 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-26421-01.dmp]
System Uptime:[B]0 days 0:03:21.867[/B]
BugCheck [B]3B, {c0000005, fffff88001ee9f62, fffff8801a436b80, 0}[/B]
Arguments:
Arg2: fffff88001ee9f62, Address of the instruction which caused the bugcheck
Arg3: fffff8801a436b80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     2400
**************************Sun Mar 10 21:25:58.617 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-25968-01.dmp]
System Uptime:[B]0 days 0:03:20.319[/B]
BugCheck [B]3B, {c0000005, fffff88001cd4f62, fffff8801b00cb80, 0}[/B]
Arguments:
Arg2: fffff88001cd4f62, Address of the instruction which caused the bugcheck
Arg3: fffff8801b00cb80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     2400
**************************Sun Mar 10 21:22:08.311 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-25375-01.dmp]
System Uptime:[B]0 days 0:03:22.012[/B]
BugCheck [B]3B, {c0000005, fffff88001f00f62, fffff8801ae13b80, 0}[/B]
Arguments:
Arg2: fffff88001f00f62, Address of the instruction which caused the bugcheck
Arg3: fffff8801ae13b80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     2400
**************************Sun Mar 10 21:18:17.059 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-25921-01.dmp]
System Uptime:[B]0 days 0:03:19.761[/B]
BugCheck [B]3B, {c0000005, fffff88001c7ff62, fffff8801a508b80, 0}[/B]
Arguments:
Arg2: fffff88001c7ff62, Address of the instruction which caused the bugcheck
Arg3: fffff8801a508b80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     2400
**************************Sun Mar 10 21:14:27.079 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-25406-01.dmp]
System Uptime:[B]0 days 0:03:19.781[/B]
BugCheck [B]3B, {c0000005, fffff88001c7ef62, fffff880195e1b80, 0}[/B]
Arguments:
Arg2: fffff88001c7ef62, Address of the instruction which caused the bugcheck
Arg3: fffff880195e1b80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     2400
**************************Sun Mar 10 21:10:38.356 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-25203-01.dmp]
System Uptime:[B]0 days 0:03:20.057[/B]
BugCheck [B]3B, {c0000005, fffff88001c5bf62, fffff8801b03db80, 0}[/B]
Arguments:
Arg2: fffff88001c5bf62, Address of the instruction which caused the bugcheck
Arg3: fffff8801b03db80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     2400
**************************Sun Mar 10 21:06:48.068 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-25000-01.dmp]
System Uptime:[B]0 days 0:03:19.769[/B]
BugCheck [B]3B, {c0000005, fffff88001ebdf62, fffff880086feb80, 0}[/B]
Arguments:
Arg2: fffff88001ebdf62, Address of the instruction which caused the bugcheck
Arg3: fffff880086feb80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     2400
[/font]
3rd Party Drivers:
[COLOR=RED][B]FUJ02B1.sys                 Wed Nov  1 05:50:43 2006 (45486DF3)[/B][/COLOR]
btmaux.sys                  Tue Apr 24 02:34:35 2012 (4F96497B)
PxHlpa64.sys                Tue Apr 24 13:26:29 2012 (4F96E245)
SYMEVENT64x86.SYS           Wed May 23 20:52:24 2012 (4FBD8648)
Rt630x64.sys                Tue Jun 12 09:37:53 2012 (4FD74631)
FBIOSDRV.sys                Wed Jun 13 02:57:16 2012 (4FD839CC)
IntcDAud.sys                Tue Jun 19 10:40:51 2012 (4FE08F73)
FUJ02E3.sys                 Thu Jun 21 21:42:32 2012 (4FE3CD88)
HECIx64.sys                 Mon Jul  2 18:14:58 2012 (4FF21D62)
iBtFltCoex.sys              Tue Jul  3 18:22:55 2012 (4FF370BF)
RtsUStor.sys                Wed Jul  4 21:59:11 2012 (4FF4F4EF)
btmhsf.sys                  Sat Jul 14 09:31:32 2012 (500174B4)
AMPPAL.sys                  Tue Jul 17 03:35:22 2012 (500515BA)
igdkmd64.sys                Fri Jul 20 17:47:55 2012 (5009D20B)
SYMNETS.SYS                 Fri Jul 20 22:07:07 2012 (500A0ECB)
iwdbus.sys                  Mon Jul 23 16:19:17 2012 (500DB1C5)
Ironx64.SYS                 Mon Jul 23 20:34:50 2012 (500DEDAA)
Apfiltr.sys                 Tue Jul 24 04:35:53 2012 (500E5E69)
BthLEEnum.sys               Wed Jul 25 22:25:02 2012 (5010AA7E)
RTKVHD64.sys                Tue Jul 31 05:46:36 2012 (5017A97C)
dump_iaStorA.sys            Tue Jul 31 14:21:21 2012 (50182221)
EraserUtilRebootDrv.sys     Tue Jul 31 19:36:50 2012 (50186C12)
eeCtrl64.sys                Tue Jul 31 19:36:51 2012 (50186C13)
NETwew00.sys                Tue Aug  7 18:49:57 2012 (50219B95)
ccSetx64.sys                Thu Aug 16 17:18:11 2012 (502D6393)
IDSvia64.sys                Tue Aug 28 22:48:40 2012 (503D8308)
snp2uvc.sys                 Wed Sep  5 03:52:21 2012 (504704B5)
avgrkx64.sys                Thu Sep 13 20:41:40 2012 (50527D44)
avgloga.sys                 Thu Sep 20 21:23:51 2012 (505BC1A7)
avgldx64.sys                Mon Oct  1 21:05:50 2012 (506A3DEE)
avgidsha.sys                Sun Oct 14 21:22:54 2012 (507B656E)
avgidsdrivera.sys           Mon Oct 22 06:47:11 2012 (5085242F)
avgmfx64.sys                Thu Nov 15 17:03:50 2012 (50A566C6)
avgwfpa.sys                 Mon Nov 26 17:09:35 2012 (50B3E89F)
EX64.SYS                    Thu Dec 20 04:22:39 2012 (50D2D8DF)
ENG64.SYS                   Thu Dec 20 04:24:21 2012 (50D2D945)
BHDrvx64.sys                Fri Jan 11 13:50:17 2013 (50F05EE9)
SYMDS64.SYS                 Wed Jan 16 20:56:45 2013 (50F75A5D)
SYMEFA64.SYS                Fri Jan 18 19:31:37 2013 (50F9E969)
SRTSP64.SYS                 Fri Jan 25 16:26:16 2013 (5102F878)
SRTSPX64.SYS                Fri Jan 25 16:30:05 2013 (5102F95D)
[/font]
http://www.carrona.org/drivers/driver.php?id=btmaux.sys
http://www.carrona.org/drivers/driver.php?id=PxHlpa64.sys
http://www.carrona.org/drivers/driver.php?id=SYMEVENT64x86.SYS
http://www.carrona.org/drivers/driver.php?id=FBIOSDRV.sys
http://www.carrona.org/drivers/driver.php?id=IntcDAud.sys
http://www.carrona.org/drivers/driver.php?id=FUJ02E3.sys
http://www.carrona.org/drivers/driver.php?id=iBtFltCoex.sys
http://www.carrona.org/drivers/driver.php?id=RtsUStor.sys
http://www.carrona.org/drivers/driver.php?id=btmhsf.sys
http://www.carrona.org/drivers/driver.php?id=AMPPAL.sys
http://www.carrona.org/drivers/driver.php?id=igdkmd64.sys
http://www.carrona.org/drivers/driver.php?id=SYMNETS.SYS
http://www.carrona.org/drivers/driver.php?id=iwdbus.sys
http://www.carrona.org/drivers/driver.php?id=Ironx64.SYS
http://www.carrona.org/drivers/driver.php?id=Apfiltr.sys
BthLEEnum.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=EraserUtilRebootDrv.sys
http://www.carrona.org/drivers/driver.php?id=eeCtrl64.sys
NETwew00.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=ccSetx64.sys
http://www.carrona.org/drivers/driver.php?id=IDSvia64.sys
http://www.carrona.org/drivers/driver.php?id=snp2uvc.sys
http://www.carrona.org/drivers/driver.php?id=avgrkx64.sys
http://www.carrona.org/drivers/driver.php?id=avgloga.sys
http://www.carrona.org/drivers/driver.php?id=avgldx64.sys
http://www.carrona.org/drivers/driver.php?id=avgidsha.sys
http://www.carrona.org/drivers/driver.php?id=avgidsdrivera.sys
http://www.carrona.org/drivers/driver.php?id=avgmfx64.sys
http://www.carrona.org/drivers/driver.php?id=avgwfpa.sys
http://www.carrona.org/drivers/driver.php?id=EX64.SYS
http://www.carrona.org/drivers/driver.php?id=ENG64.SYS
http://www.carrona.org/drivers/driver.php?id=BHDrvx64.sys
http://www.carrona.org/drivers/driver.php?id=SYMDS64.SYS
http://www.carrona.org/drivers/driver.php?id=SYMEFA64.SYS
http://www.carrona.org/drivers/driver.php?id=SRTSP64.SYS
http://www.carrona.org/drivers/driver.php?id=SRTSPX64.SYS
    Samsung/NP780
    800x600
I Followed your advice and uninstalled the Fujitsu Wireless Radio Switch Driver, downloaded the install packet from the fujitsu website (http://support.ts.fujitsu.com/content/QuicksearchResult.asp?q=AH532&btnG.x=-1150&btnG.y=-19&btnG=Search) went half way through the install process and it said "The necessary files are missing" ? It won't let me go any further
    Fujitsu
Is the system still under warranty? If so, take it in to have it fixed (I suspect a hardware problem).
Otherwise, disable the Fujitsu Wireless Radio Switch Device in Device Manager (right click on it and select "Disable")
See if that helps.
    Samsung/NP780
    800x600
