Using 32 bit element with IE 64 bit
balubeto
Hi
I am using Internet Eplorer 11.x 64 bit on Windows 8.1 Update 64 bit.
Unfortunately, I still have some 32 bit element as Browser Helper Objects (BHOs), toolbars and ActiveX controls.
Is there a solution to make sure that all these 32 bit elements work correctly with IE 11 64 bit?
Because I'm a system administrator, I would like that this solution would apply to all existing accounts and to those that I will create.
Thanks
Bye
32 bit Browser Helper Objects (BHOs), toolbars and ActiveX controls are not compatible with 64 bit Internet Explorer. That is why 32 bit Internet Explorer is provided.
    Windows 7
