How to Add or Remove "Allow Away Mode Policy" in Power Options in Windows
Information
Away Mode in Windows is similar to Sleep and Hibernate Mode, it turns off the power of most equipment to save energy and can be fast woken up. Away Mode is designed to enable media PC scenarios that include background media sharing and recording. When the computer is in Away Mode, the system appears off to the user—the display is off and audio is muted. However, the PC remains in the on state and otherwise fully operational, allowing background tasks to continue.
Away Mode is designed specifically for scenarios where the user is done interacting with the computer, but the system must remain powered on to record a TV broadcast or share media files with other systems and devices. For example, the system might be providing access to Windows Media Center Extender or other consumer electronics devices and therefore must remain available even though the user is not interacting with the system at the local console. Away Mode enables a living room media PC to respond to a user’s power on-off requests in the same manner as a television or set-top box that might appear off, but actually continues working.
This tutorial will show you how to add or remove the "Allow Away Mode Policy" setting under Sleep in Power Options for all users in Vista, Windows 7, and Windows 8.
Note
The Allow Away Mode Policy setting will enable or disable Away Mode for users using the same power plan scheme this was set in.
An example of an Away Mode setting, is the Allow the computer to enter Away Mode for When sharing media in your power plan scheme "Power Options".
EXAMPLE: "Allow Away Mode Policy" in Power Options
Note
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Power\PowerSettings\238C9FA8-0AAD-41ED-83F4-97BE242C8F20\25DFA149-5DD1-4736-B5AB-E8A37B5B8187
Attributes DWORD
1 = Remove
2 = Add
Attributes DWORD
1 = Remove
2 = Add
2. To Remove "Allow Away Mode Policy" from Power Options
Remove_Allow_Away_Mode_Policy.reg
3. To Add "Allow Away Mode Policy" to Power Options
Add_Allow_Away_Mode_Policy.reg
8. Boot to and check your BIOS settings to see if it may have an Away Mode setting that needs to be enabled or disabled as well, then exit BIOS with saving the changes. (see screenshot below)
Note
Please read your computer's or motherboard's manual for this step.
This step will vary per computer/motherboard on how to boot to BIOS (setup), and if and where the Away Mode setting is.
- How to View and Override Power Availability Requests in Windows
- How to Change Power Plan Settings in Windows 8 and 8.1
- How to Change Power Plan Settings in Windows 7
- How to Add or Remove "Allow sleep with Remote Opens" in Power Options in Windows 7 and 8
- How to Add or Remove "Allow wake timers" in Power Options in Windows
- How to Add or Remove "Console lock display off timeout" in Power Options in Windows 8 and 8.1
- How to Add or Remove Desktop Background "Slide Show" in Power Options in Windows
- How to Add or Remove "Dim display after" in Power Options in Windows
- How to Add or Remove "Enable forced button/lid shutdown" in Power Options
- How to Add or Remove "Hard disk burst ignore time" in Power Options
- How to Add or Remove "Hibernate after" in Power Options in Windows
- How to Add or Remove PCIe "Link State Power Management" in Power Options in Windows
- How to Add or Remove "Minimum processor state" and "Maximum processor state" in Power Options in Windows
- How to Add or Remove "System cooling policy" in Power Options in Windows
- How to Add or Remove "System unattended sleep timeout" in Power Options
- How to Add or Remove "Turn off hard disk after" in Power Options in Windows
- How to Add or Remove "USB 3 Link Power Mangement" in Power Options in Windows 8
- How to Add or Remove "USB selective suspend setting" in Power Options in Windows
- How to Add or Remove "When sharing media" in Power Options in Windows
- How to Add or Remove Wireless Adapter Settings "Power Saving Mode" in Windows
