System Spec - Fill In Your EightForums System Spec
    How to fill in your EightForums system specs
    Default System Spec - Fill In Your EightForums System Spec
    Published by
    JDobbsy1987's Avatar
    This tutorial will show you how to fill out your EightForums system spec which will enable other members to assist you more quickly and efficiently.
    1. Click User CP located top right.
    Click Edit System Spec on the left hand side.
    Fill out as much info as you can in the field provided.
    Tip   Tip
    Need help with this? - Use the System Spec program (Ignore Option 5 for EightForums)
    System Info - See Your System Specs - Windows 7 Help Forums
    Click Save Changes at the bottom and you are done.
    Other members will now be able to see your System Specs, like this:
  2. #1
    Was one of the first things I did on the forums, and it also helps when assisting others. Great to see a tutorial for this being submitted.
  3. #2
    Thank you Allison
Tutorial Forum
System image restore & system repair disc problems
I recently had to return my HP Pavilion g7 Windows 8 64- bit only laptop to the manufacturer for repair under warranty. Prior to this I created a system image as the Hard Disc was going to be replaced. Having now received the repaired laptop I have been trying to restore the saved image. I watched...
Performance & Maintenance
really low fps wih great spec'ed pc
hello all, im getting really low fps in all my games, and even windows 8 is self feels really slow. it all happened after a blue screen i had this morning, so im wondering if anyone who reads this and with similar setups can tell me what fps they are getting. specs: intel 3770k cpu not...
Tablet Spec
I am wanting to move away from my ipad to a windows 8 tablet so I can run my windows desktop email programme ( i am looking for the following spec; 4gb ram 128gb hhad ability to run windows programmes such as photoshop etc. 3g option (not essential as can run via USB) Looking...
Drivers & Hardware
cant fill out system specs
I go to edit system specs, and i just get a white page. Do i need to have a certain number of posts before it becomes available? Cause i have it filled out on seven forums
Chillout Room
