Screenshot - Capture Screenshots Directly in Windows 8
How to Capture a Screenshot Directly in Windows 8 and 8.1
This will show you how to capture a screenshot of everything on your display(s) and have it instantly saved as a PNG file directly into your C:\Users\(user-name)\Pictures\Screenshots folder without having to do anything else in Windows 8, Windows RT, Windows 8.1, and Windows RT 8.1.
You could also view the saved screenshot in your Pictures library.
Tip   Tip
If you like, you are still also able to use the Ctrl+PrtScn, Alt+PrtScn, Fn+PrtScn (laptops/notebooks), or PrtScn keys to capture a screeshot into the clipboard, but you would need to use a image editor like Paint to copy the screenshot from the clipboard to edit and save the screenshot.
1. Do step 2, 3, or 4 for how you would like to capture a screenshot depending on what type of PC you have.
2. On all PCs, press the Windows + Print Screen (PrtScn) keys and release, then go to step 5 below.
NOTE: For laptops and notebooks, you may need to press either the Windows+Ctrl+PrtScn or Windows+Fn+PrtScn keys instead.
3. On a Surface tablet, press the Fn + Windows + Space Bar keys on the Type Cover and release, and go to step 5 below.
4. On tablets (ex: Surface), press and hold the capacitive Windows button on the front of the tablet, and press the volume down button on the volume rocker once, release both, then go to step 5 below. (see screenshot below)
5. You will now notice the screen quickly dim and return back to normal as a snapshot of your display(s) is captured as a screenshot. In Windows Phone 8, you will also hear a snapshot click sound.
You will only see the screen dim if you have the Animate windows when minimizing and maximizing turned on (checked) in your visual effects settings.
6. The screenshot is now saved in your C:\Users\(user-name)\Pictures\Screenshots folder named as Screenshot (#).png with # indicating the screenshot index counter. Each screenshot you take increases the counter # by one. (see screenshot below)
:thumbsup:
    LCARS
    Monkey Trainer Extraordinaire
    My toilet habits are a private matter, thanks.
    She finds stuff to do.
    Not that I can recall.
    XXX rated
    Huh?
    Monitors are lizards.
    I haven't found one yet.
    Sure isn't easy driving.
    Again, toilet habits are a private matter.
    Pending
    2 ice cubes.
    Nar, it has other key friends.
    Cat
    Warp 9.9
Great tutorial brink.
    Windows 8.1 professional x64 + WMC
    Acer Aspire 5920
    Core 2 duo T5550
    ACER CHAPALA
    4GB DDR2
    Intel GMA X3100
    1280 X 800
    160 GB HDD
Can I change where it puts the screenshots, like to C:\Temp instead?
    Windows 8 Pro ($39.99 upgrade)
    Intel I5 3570K overclocked to 4.2ghz
    Asus P8Z77-V LX
    Cosrair DDR3-1600 (4 x 4gb)
    Nvidia GeForce GT 610 2GB
    None
    AOC 27" LCD
    1920x0180
    Seagate HDD 500gb (windows)
    Seagate HDD 1.5tb (media)
    Seagate HDD 1tb (media)
    CoolMax 700watt
    Cosiar R400 Carbide series
    Cool Master H212
    Dell
    PowerUp 3 button mouse
    12mb down, 1mb up
    qty. (5) 120mm fans, four are monitored by motherboard.
    Logitech T650 Touchpad for touch screen gestures
Hello Tcman,
So far, there's not a known way to change it. :(
Great Shawn. How do you find all this stuff. I was still storing the prt scrn in Paint. I guess that is still OK if you want to make annotations.
    Vista and Win7
    5 SSDs and 12 HDs
Just from digging away, and from what others have helped spotted. :)
Will it work in Windows 7?
    Windows 8 Consumer Preview 64-bit, Windows 7 Home Premium 64-bit, Ubuntu 11.10 64-bit (Triple Boot)
    Acer Aspire 4755G
    Acer Aspire 4755G
    DDR3 2GB
    nVidia GeForce 540M (up to 2,7GB)
    Realtek High Definition Audio
    Default Monitor
    1366*768
    WDC WD6400BPVT-22HXZT1 (640GB)
    Default PSU
    Default Case
    Default Cooling
    Default Keyboard
    Optical Mouse
    ~20Kb/s download and upload (one of slowest in the world)
    This is my second laptop after my old notebook that broke because file system is corrupted and I can't recover it. And my Internet speed is super duper low in other countries. And my income is so low (US$200/month) so I don't have any electronic equipment except this laptop.
Hello Papin,
Sorry, but no. This is a new feauture included only in Windows 8. :)
I made a quick launch home-made toolbar folder and stuck a shortcut in it to C:\Windows\System32\SnippingTool.exe for my screen grabs. So now by my hidden task bar programs is my quick launch shortcuts. snipping tool, photo editor, y messenger.
    win8.1
    lenovo
I just use the windows key and the print screen key and it takes a snap shot of the entire desktop and creates a folder in the pictures folder called snapshots and stores the snaps shots there for quick access. This also worked in windows 7.
    Custom build
    AMD Phenom II X 4 965 BE
    Gigabyte GA-MA790X-DS4
    G-Skill 8 GB PC 8500
    AMD XFX HD Radeon 6790D
    Realtek HD onboard
    2l Samsung SyncMaster S20B300
    1600 X 900
    Seagate Barracuda 320 GB w/OS
    Cooler Master Hyper212 120mm
    Logitech G510
    Razor DeathAdder 3.5
Hello Jimbo,
Sorry mate, but this is not available in Windows 7 and only new to Windows 8.
It didn't work in any of my Windows 7. It would be nice though. :(
Hello Jimbo,
Well I stand corrected...just checked my 7 ultimate laptop and you're right. It didn't work. So I wonder what the hell I did do....scratching my head in wonder now! Shite...memory, that the second things that goes when you get old....don't discuss that first thing.
    Custom build
    Realtek HD onboard
    1600 X 900
    Logitech G510
LOL, I hear you.
Maybe a mislabeled VM?
hi, i do not have the snapshot folder in mypictures ,and if i add it,it doesn't put the snap shot there
    win8.1.1 enterprise
    Hinze57
    AMD FX 6100 6core 3.30gHz
    gigibyte ga-78lmy-s2p
    4gig ddr3
    Radon hd5000 Series
    onboard realtek hd
    19" viewsonic/ 22"Samsung
    1680x1050
    128gig ssd Kingston
    80gig WD 10000 rpm spinner
    micro
    microsoft curve 200
    Logitech wireless M215
    high speed 20
    ie 11
    windows defender
    updated enterprise apr 2/14
Hello Jack,
The Screenshots folder doesn't show up until after you pressed the Windows + Print Screen keys for the first time. Does it not do this for you?
Hello Jack,
no ,i tried it both ways ,,as you just said ,and making the folder myself ,just had a thought ,maybe something happed when i copied my picture folder from win7 ,from my usb backup and changed the structure of the original win8 mypicture folder , when i installed win8
    win8.1.1 enterprise
    Hinze57
    4gig ddr3
    Radon hd5000 Series
    onboard realtek hd
    1680x1050
    128gig ssd Kingston
    micro
    microsoft curve 200
    high speed 20
    ie 11
    windows defender
thanks the screenshot shortcut file fixed it thanks again
    win8.1.1 enterprise
    Hinze57
    4gig ddr3
    Radon hd5000 Series
    onboard realtek hd
    1680x1050
    128gig ssd Kingston
    micro
    microsoft curve 200
    high speed 20
    ie 11
    windows defender
Great news. You're welcome. :)
