Power Button on Start Screen - Add or Remove
How to Add or Remove Power Button on Start Screen in Windows 8.1 Update
The Windows 8.1 Update released on April 8th 2014 via Windows Update, added a Power button on the Start screen.
On some devices you may not see the Power button. On devices that are not tablets like laptops, desktop PCs and All-in-Ones, the Power button should appear on the Start screen after installing the update. On most tablets you will not see the Power button on the Start screen as they have connected standby and a physical power button that lets you quickly shut down or put the device to sleep. However, on tablets larger than 8.5-inches without connected standby, you will see the Power button on the Start screen.
This tutorial will show you how to add or remove the Power button from the top right corner of your Start screen in Windows 8.1 Update.
EXAMPLE: Power button on Start screen
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\ImmersiveShell\Launcher
Launcher_ShowPowerButtonOnStartScreen DWORD
0 = Remove
1 = Add
2. To Add Power Button on your Start Screen
A) Click/tap on the Download button below to download the .bat file below, and go to step 4 below.​
Add_Power_Button_on_Start_Screen.bat
3. To Remove Power Button from your Start Screen
Remove_Power_Button_on_Start_Screen.bat
4. Save the .bat file to your desktop, and run it.
5. If prompted, click/tap on Run.
6. You will now notice your screen flicker as explorer is restarted to apply the setting.
  • Add_Power_Button_on_Start_Screen.bat
  • Remove_Power_Button_on_Start_Screen.bat
I did this download to add the power button on my other computer. I clicked to open it and create a desktop shortcut. Suddenly I lost everything and was left with a blank screen. I switched off the computer by the power button. When I switched it on again I got the usual lock screen and was able to put in my password. Then all that happens is I am left with a blank screen again. How do I get everything back?
    Windows8.1
Hello Susie, and welcome to Eight Forums.
The .bat file also restarts explorer to apply the changes. It sounds like something interfered with explorer restarting.
You can do this below to open explorer. Afterwards, you should be good to go. :)
  • Press the CTRL+SHIFT+ESC keys to open Task Manager.
  • Click on File (menu bar) and Run new task.
  • Type explorer in the "Create new task" dialog, and click on OK.
Hello Brink
Thank you for your reply. The situation has actually resolved itself. I had to go away and do something else for a while. When I came back to look at it again, everything had come back up, complete with power button. Perhaps I was being a bit impatient and hadn't allowed enough time for it to complete the operation. Anyway, everything is good and thank you for your help
    Windows8.1
Great news. It should have only taken a second to finish. Something running had interrupted or delayed explorer restarting. :)
It's pretty poor that we have to resort to the registry for all these changes. I have a folder of these .reg files that I have to run every time I receive an update, as it tends to reset the registry changes.
    Windows 8.1 Pro 64-bit
    Custom-built
    Intel i7 950 Overclocked @ 3.5GHz
    Asus P58XD-E
    6 x 2GB Corsair XMS 3 @ 1600MHz
    Zotak Geforce GTX 590 3GB; Asus GTX 560Ti Direct CUII
    Integrated Realtek Digital Optical
    Phillips 234EL2; Dell E2209W
    1920x1080; 1050x1680
    Corsair Geforce GS 240GB SSD; Toshiba 3TB HDD
    950W OCZ Game-X-Stream
    White NZXT Phantom
    Zalman CNPS 9900 Max
    Corsair K95
    Cyborg R.A.T. 9
    10Mb/S on a good day!
    Chrome
    Windows Smart Screen Filter
    I also have a Scan 3XS LG15 notebook with 16GB RAM, 240GB SSD, 1TB HDD, 2.7GHz 3rd-gen i7, GTX 680M.
Hello Daniel,
Yeah, we've had some major updates lately that would have reset things back to default. Hopefully the next Windows 8.1 Update 2 to be released soon will be the last for a while that resets things.
I downloaded the bat file and ran it on my Acer Iconia W3, but it didn't add the shutdown button to the start page. Any additional help would be appricated as I would like to eliminate that extra step when shutting down the tablet.
    Tablet
    Acer Iconia W3-810
    Intel Atom Z2760 1.8 GHz
    2 GB
Thanks, Brink,
I do have the 8.1 update and I checked for additonal updates before I downloaded the bat file.
I just checked through the registry editor and the value is set to 1, so the power button should be there, right?
    Tablet
    Acer Iconia W3-810
    2 GB
Odd. By default, the power button shows after installing the Windows 8.1 Update.
Do you have the search button on your Start screen like in the example screenshot in the tutorial? If not, then it doesn't sound like you have Windows 8.1 Update installed.
Yes the search icon is there next to the user photo. Could this have anything to do with the tablet only having an 8.1" screen?
    Tablet
    Acer Iconia W3-810
    2 GB
Nice one. Any way to get rid of the redundant search button also?
    Windows 10 Pro Prieview x64
    MacBook Pro Core2Duo
    T7600
    ATI Radeon X1600
    Internal
    1440 x 800
    40GB
    Apple
    Apple
    Varies
    Various
    Defender
Hey Adam,
Not that I know of so far.
Strange, this tweak doesn't work on my machine any more.
My Computers
System One System Two
    Windows 7 Home Premium
    HP Pavillion
  • PC2
    Tablet - Windows 10 Home
Hey Edwin,
Odd, it's still working for me. Did you restart explorer afterwards to apply? If so, you might see if restarting the PC may work better.
Hey Edwin,
Naw, restarted explorer, signed out and in, restarted machine, shut down and powered up; nothing!
Got me baffled!
My Computers
    HP Pavillion
  • PC2
Odd. I'm not sure why it's not working for you then. Do you have a 3rd party program installed that may be overriding it?
You might also do a search for that DWORD in the registry to see if you have any other entries for it that may be affecting this.
Power button for windows 8.1 issue
Thanks for your help for downloading the power button to the start screen!!...I have been wanting it for my little Asus laptop for a long time....Great!...*john:)
    windows 8.1 PRO
    HP SF5100
