How to Enable or Disable Users to Turn On and Off Enterprise Mode in Internet Explorer 11
Information
Enterprise Mode, a compatibility mode that runs on Internet Explorer 11 on Windows 8.1 Update and Windows 7 devices, lets websites render using a modified browser configuration that’s designed to avoid the common compatibility problems associated with web apps written and tested on older versions of Internet Explorer, like Internet Explorer 8 and older.
For more information about IE11 Enterprise Mode, see:
This tutorial will show you how to enable or disable local control of Enterprise Mode for all or specific users on the PC to be able to turn on and off using Enterprise Mode for sites without using a site list in Internet Explorer 11 in Windows 7 and Windows 8.1 Update.
- What is Enterprise Mode?
- Better App Compat with Enterprise Mode for Internet Explorer 11 | Build 2014 | Channel 9
- Stay up to date with Enterprise Mode for Internet Explorer 11 - IEBlog - Site Home - MSDN Blogs
- Turn on Enterprise Mode and use a site list
- Turn on local control and logging for Enterprise Mode
- Turn off Enterprise Mode
Note
Windows 8.1 Update released on April 8th 2014 via Windows Update.
Enterprise Mode is only available for the desktop Internet Explorer in Windows 8.1 Update. It is not available in the modern Internet Explorer.
EXAMPLE: IE11 Enterprise Mode option in Tools menu and F12 Emulation
To Enable or Disable IE11 Enterprise Mode for Users using a REG File
Note
HKEY_CURRENT_USER\Software\Policies\Microsoft\Internet Explorer\Main\EnterpriseMode
Enable String
no data value = enabled
delete string = disabled
Enable String
2. Enable Only Current User to Turn On and Off Enterprise Mode from Tools menu and F12 Emulation
Enable_IE11_Enterprise_Mode_in_Tools_and_Emulation.reg
3. Disable Only Current User to Turn On and Off Enterprise Mode from Tools menu and F12 Emulation
Disable_IE11_Enterprise_Mode_in_Tools_and_Emulation_.reg
7. Close and reopen the desktop Internet Explorer 11 to apply if open.
To Enable or Disable IE11 Enterprise Mode for Users using Group Policy
2. In the left pane, click/tap on to expand User Configuration, Administrative Templates, Windows Components, and open Internet Explorer. (see screenshot below)
3. In the right pane of Internet Explorer, double click/tap on Let users turn on and use Enterprise Mode from the Tools menu. (see screenshot above)
5. Disable User(s) to Turn On and Off Enterprise Mode from Tools menu and F12 Emulation
A) Select (dot) Disabled or Not Configured, click/tap on OK, and go to step 7 below. (see screenshot below step 6A)
6. Enable User(s) to Turn On and Off Enterprise Mode from Tools menu and F12 Emulation
A) Select (dot) Enabled, leave the Options field for a URL empty, click/tap on OK, and go to step 7 below. (see screenshot below)
7. You can now close the Local Group Policy Editor window if you like.
8. Close and reopen the desktop Internet Explorer 11 to apply if open.
