Advanced System Properties - Add to "This PC" Context Menu
Add "Advanced System Properties" to "This PC" and "My Computer" Context Menu in Vista, Windows 7, and Windows 8
This tutorial will show you how to add or remove Advanced System Properties to the "My Computer" (Vista/Windows 7) or "This PC" (Windows 8) context menu for all users in Windows.
In Vista and Windows 7, this is for when users right click on Computer from the Start Menu, navigation pane in Windows Explorer, or desktop icon.
In Windows 8, Windows RT, Windows 8.1, and Windows RT 8.1, this is for when users right click or swipe down on This PC from the navigation pane in File Explorer, or the Computer desktop icon.
EXAMPLE: Advanced System Properties
EXAMPLE: Advanced System Properties in "My Computer" and "This PC"context menu
1. To Add "Advanced System Properties" to "This PC" Context Menu
A) Click/tap on the Download button below to download the file below, and go to step 3 below.​
Add_Advanced_System_Properties_to_This-PC_Context_Menu.reg
2. To Remove "Advanced System Properties" from "This PC" Context Menu
NOTE:
This is the default setting.
Remove_Advanced_System_Properties_from_This-PC_Context_Menu.reg
3. Save the .reg file to your desktop.
4. Double click/tap on the downloaded .reg file to merge it.
5. If prompted, click on Run, Yes (UAC-Windows 7/8) or Continue (UAC-Vista), Yes, and OK to approve the merge.
6. You can now delete the downloaded .reg file if you like.
That's it
  • Add_Advanced_System_Properties_to_This-PC_Context_Menu.reg
  • Remove_Advanced_System_Properties_from_This-PC_Context_Menu.reg
How to add ASP to Desktop or Quick Launch?
Hi Shawn
Useful thread, I would like to add ASP to my QuickLaunch toolbar, allowing launching with 2 clicks. Actually I need it there to be able to set a restore point, so I would actually prefer to add "Create a Restore Point" directly to QuickLaunch or Desktop, saving one step. Any ideas?
So far what I have done is to create a shortcut to Restore on the desktop (location control.exe sysdm.cpl,,4). If you want to place in Quick Launch, copy the shortcut and paste it into the QL folder, then deleted the desktop shortcut. This launches ASP OK with the System Protection tab active, allowing 2 click restore point creation.
Jon
