Power Options Menu - Add or Remove Sleep or Hibernate in Windows 8
How to Add or Remove "Sleep" or "Hibernate" from Power Menu in Windows 8 and 8.1
This will show you how to add or remove the Sleep or Hibernate option from all Power menus for all users in Windows 8, Windows RT, Windows 8.1, and Windows RT 8.1.
You will not be able to add Sleep or Hibernate to the Power options menu if Windows 8 is running from a VHD file in a virtual machine.
EXAMPLE: Power options menus
1. Open the Control Panel (icons view), and click/tap on the Power Options icon.
2. In the left pane of Power Options, click/tap on the Choose what the power buttons do link. (see screenshot below)
3. Click/tap on the Change settings that are currently unavailable link at the top. (see screenshot below)
WARNING: If you completely disable UAC notification settings, then you might not have the Change settings that are currently unavailable link available, and the "Shutdown settings" would remain greyed out with no way of changing them until UAC is enabled to at least the default setting.
5. Under Shutdown settings, check or uncheck Sleep or Hibernate to add or remove them from the Power menu in the Settings (Windows+I) screen, then click on Save changes. (see screenshot below)
NOTE: If the Shutdown settings are not listed, then you will need to close the System Settings window, enable hibernate, then start back at step 1 again.
6. When finished, you can close the Power Options window.
    LCARS
    Monkey Trainer Extraordinaire
    My toilet habits are a private matter, thanks.
    She finds stuff to do.
    Not that I can recall.
    XXX rated
    Huh?
    Monitors are lizards.
    I haven't found one yet.
    Sure isn't easy driving.
    Again, toilet habits are a private matter.
    Pending
    2 ice cubes.
    Nar, it has other key friends.
    Cat
    Warp 9.9
Thank you Aaron. Warning added. I hope that will be addressed by the time of the RTM release.
hmm i dont have the "Show Hibernate" Option..
eE16
    Windows 7 Ultimate x32 Windows 8 CP x32
    Acer Aspire 4551
    AMD Athlon II P320 Dual Core (2.1GHz, 2MB L2 Cache)
    Acer Aspire 4551
    3 GB
    ATI Readeon HD 4250
    Realtex
    14" (HD 1366 x 768 LED)
    1366x768
    320 GB
    Logitech
    Acer Aspire 4551
    Acer Aspire 4551
    3 GB
    ATI Readeon HD 4250
    Realtex
    1366x768
    320 GB
    Logitech
MadeOke,
It looks like either your system does not support hibernation, or you do not have hibernation (S3) enabled in the "Power Management" section of your BIOS setttings.
Could you update your system specs to show what brand and model of motherboard or computer you have? This way we will be able to look up to see what it says about it, and what settings you may be able to set for it.
In the mean time, you could use the tutorial below to help see what sleep states are available for your system.
Sleep States - See Available Sleep States - Windows 7 Forums
Hi Brink,
i have updated my system specs
but on W7 hibernate works normal
    Acer Aspire 4551
    Acer Aspire 4551
    3 GB
    ATI Readeon HD 4250
    Realtex
    1366x768
    320 GB
    Logitech
MadeOke,
Do you have Windows 8 installed on the laptop itself dual booting with Windows 7, or in a virtual machine running in Windows 7?
What sleep states were reported as available while in Windows 8?
MadeOke,
Dual Booting W7 and WDP (WDP on vhd)
Dual Botting Win7 and W8DP (W8 on VHD)
[QUOTE]Microsoft Windows [Version 6.2.8102]
(c) 2011 Microsoft Corporation. All rights reserved.
C:\Users\madeoke>powercfg -a
The following sleep states are available on this system:
    Standby (S3)
The following sleep states are not available on this system:
    Standby (S1)
        The system firmware does not support this standby state.
    Standby (S2)
    Hibernate
        An internal system component has disabled hibernation.
    Standby (Connected)
    Hybrid Sleep
        Hibernation is not available.
    Hybrid Boot
    Acer Aspire 4551
    Acer Aspire 4551
    3 GB
    ATI Readeon HD 4250
    Realtex
    1366x768
    320 GB
    Logitech
MadeOke,
See if running a sfc /scannow command may help.
In addition, check at the registry (regedit) location below to see if you have a HibernateEnabled DWORD value set to 1 in the right pane of the Power key.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Power
This will not work if w8 installed on VHD :)
    Acer Aspire 4551
    Acer Aspire 4551
    3 GB
    ATI Readeon HD 4250
    Realtex
    1366x768
    320 GB
    Logitech
    Acer Aspire 4551
    Acer Aspire 4551
    3 GB
    ATI Readeon HD 4250
    Realtex
    1366x768
    320 GB
    Logitech
Yep, hibernate will not be available in a VM or VHD. Thank you for posting back. :)
This thread saved me a lot of time. I couldn't figure out how to get to the greyed out 'require a password from sleep' item. I NEVER would have thought to ENABLE UAC in order to get it to work. MS is weird.
Thanks!
Glad it could help sl2222. :)
Quick question,
If you remove 'sleep' from the menu, does this also remove the ability to sleep when the computer is idle for a time?
    Windows 8.1 Pro with Media Center x64
    Custom
    Intel Core i7-3820 CPU OC @ 3.80GHz
    Gigabyte G1.Assassin2
    Corsair Dominator 16GB Quad Channel DDR3
    Nvidia by EVGA - GeForce GTX 670 4GB
    On board Creative SB X-Fi
    acer 24" H243H
    1920 X 1080
    Main 500GB Hybrid Drive @ 7,200RPM
    Secondary OCZ SSD Vertex 3 Max IOPS
    Silent Pro 1000w gold 80+
    Azza Hurrican 2000
    Liquid CPU cooler & fans
    Microsoft Comfort Curve 2000
    Tek Republic Wired Laser Mouse
    5ms Ping 5.15Mb/s Download .64Mb/s Upload
    Internet Explorer
    Defender, Malwarebytes
Hey Dusty,
Nope. Removing "Sleep" from the menu doesn't affect the computer from being able to go to sleep when set to do so. :)
I have no "Sleep" option problem and followed the instructions but after the step 3 I got the following which is different from that shown in the instructions. What could be wrong with my W8.1?
    W10 Pro/W8.1 Pro/ W7 Ult
    Self Built
    AMD Ryzen 5 5600X Six-Core
    Gigabyte X570 AORUS Ultra 1.1/1.2 BIOS v.F32
    16GBx2 DDR4 3600 G.SKILL Ripjaws V Series
    Radeon RX 6500 XT
    Dell UP2720Q
    3840 x 2160
    1TB SATA SSD(OS) SSung 870 EVO, 1TB M.2 NVMe SSD(OS) SSung 970 EVO Plus, 4TB SATA SSD(Data)
    Corsair RM650 650W
    Fractal Design Focus G Black ATX Mid Tower Computer Case, FD-CA-FOCUS-BK-W
    Cooler Master MasterLiquid Lite 120 AIO CPU Liquid Cooler
    DURGOD TAURUS K320 Mechanical Keyboard
    Microsoft Model 1049
    600Mbps/25Mbps
    Firefox & IE
    Microsoft Defender
    ICY DOCK 4 x 2.5 SSD to 5.25 Drive Bay - ExpressCage MR324SP-B
    ICY DOCK M.2 NVMe Mobile Rack for External 3.5" Bay - MB834M2K-B
