Control Panel and PC settings - Enable or Disable Access
How to Enable or Disable Access to Control Panel and PC settings in Windows 8 and 8.1
This tutorial will show you how to enable or disable access to the Control Panel, PC settings, and all settings in them for all or specific users in Windows 8 and Windows RT.
When disabled, this setting prevents Control.exe and SystemSettings.exe, the program files for Control Panel and PC settings, from starting. As a result, users cannot start Control Panel or PC settings, or run any of their items in them from any other location as well.
This removes Control Panel from:
The Start screen
File Explorer
This removes PC settings from:
The Start screen
Settings charm (ex: "Change PC settings" link)
Account picture
Search results
EXAMPLE: Restrictions message
NOTE: This is the Restrictions error seen if users try to open the Control Panel, PC settings, or any settings in these two.
Enable or Disable Control Panel and PC settings using a REG File
The downloadable .reg files below will add and modify the DWORD value in the registry keys below,
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer
NoControlPanel DWORD
(delete) = enable Control Panel/PC settings
1 = disable Control Panel/PC settings
2. To Enable Access to Control Panel and PC settings for All Users
Enable_PC_settings_and_Control_Panel.reg
3. To Disable Access to Control Panel and PC settings for All Users
Disable_PC_settings_and_Control_Panel.reg
5. Double click/tap on the downloaded .reg file to Merge it.​
6. If prompted, click/tap on Run, Yes (UAC), Yes, and OK to approve.​
7. Sign out and sign in, or restart the PC to apply.​
Enable or Disable Control Panel and PC settings in Group Policy
1. Open the all users, specific users or groups, or all users except administrators Local Group Policy Editor for how you want this policy applied.​
2. In the left pane, click/tap on to expand User Configuration, Administrative Templates, and Control Panel. (see screenshot below)​
3. In the right pane of Control Panel, double click/tap on Prohibit access to Control Panel and PC settings. (see screenshot above)​
5. To Enable Access to Control Panel and PC settings
A) Select (dot) Disabled or Not Configured, click/tap on OK, and go to step 7 below. (see screenshot below step 6A)​
6. To Disable Access to Control Panel and PC settings
A) Select (dot) Enabled, click/tap on OK, and go to step 7 below. (see screenshot below)​
7. You can now close the Local Group Policy Editor window if you like.​
  • Enable_PC_settings_and_Control_Panel.reg
  • Disable_PC_settings_and_Control_Panel.reg
I cant find the EXPLORER in the HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer how do I get it back
Hello maxongaming, and welcome to Eight Forums. :)
The "Explorer" key is not there by default until the policy is configured.
If you like, you can use the .reg file downloads in Option One to add and set this.
