Desktop - Boot Directy to using a Scheduled Task
How to Boot Windows 8 Directly to Desktop using a Scheduled Task
Personally I like the new Start Screen. For me it is more logical to use allowing more customization options than the Start Menu on previous Windows versions.
I like to see the Mail app live tile telling me about unread mail messages, the People app live tile notifying me when I have new messages on social media, my selected news app live tiles giving me brief summary of today's news.
However some users want to get directly to Windows desktop. This tutorial will show you how to boot Windows 8 directly to the desktop using a scheduled task to bypass the Start screen.
Tip   Tip
In Windows 8.1 and Windows RT 8.1, see OPTION TWO in the tutorial link below instead now.
How to Go to Desktop or Start when You Sign in or Close Apps in Windows 8 and 8.1
1. Press Win + Q key to open Charms App Search or Win + W to open Charms Settings Search, type Schedule and hit Enter to start Task Scheduler. Alternatively press Win + X to open Windows Tools menu bottom left and select Computer Management, select Task Scheduler in the left pane
2. Click Create Task on Actions pane:
3. Name the Task as you wish, select Configure for: Windows 8, click OK:
4. Select the Triggers tab
- Click New
- Select At log on from Begin the task drop down list​
- Select Enabled
- Click OK
5. Select the Actions tab
- Click New
- Select Start a program from the Action drop down list​
- Type C:\Windows\Explorer.exe to Program / Script text field​
- Click OK
6. Laptops / Notebooks only: Select the Conditions tab
- Unselect Power: Start the task only if the computer is on AC power
(this takes care of that the task is run also when logging in using battery power)​
That's it. Now every time you log in to Windows, it bypasses the Start Screen entering directly to Desktop, with File Explorer open showing your Libraries.
To again boot to Start Screen instead of Desktop, open the Task Scheduler as told above (step 1.), select Task Scheduler Library, right click your task and select Disable:
Kari
Kari,
Can I assume that this will work with other executables, such as iExplorer.exe, or Winword.Exe, or is it confined to actually running explorer.exe, would be useful for some to start-up in the application they use everyday.
If it's limited to running explorer I suppose a second Task, set to run after this one and set to run the app of choice would work.
Also it should be possible to add parameters to the task, maybe, have the OS boot straight into www.eightforums.com ;)
    Windows 10 Pro x64 x2 Windows 10 Enterprise x64, Ubuntu
    Real World Computing
    AMD FX8350 8 Core @4GHz
    Asus M5A78L-M USB3
    32GB [4x8GB] DDR3 1600 MHz
    Asus nVidia GTX750TI-OC-2GD5 (2GB DDR5)
    ASUS Xoner DG + SPDIF to 5.1 System + HDMI
    Acer G276HL 27", (DVi) + Samsung 39" HDTV (HDMI)
    1920 x 1080 @60Hz + 1920 x 1080 @60Hz
    Internal
    Crucial 256GB SSD,
    WDC WD30EZRX-00D8PB0 3TB,
    Toshiba HDWD130 3TB
    Seagate ST2000DM001-1CH1 2TB,
    External (USB3)
    Seagate Backup+ Hub BK SCSI Disk 8TB
    2.5/3.5 Hot Swap Cradle, USB3 + eSata (client HDDs)
    NAS
    Seagate ST4000DM000
    Aerocool Templarius Imperator 750W 80+ Silver
    AeroCool X-Warrior Devil Red Tower
    Stock CPU, Rear 120mm, Front 2x120mm, Side 2x120mm
    Logitech Wireless K710 & K270
    Logitech Wireless M710 M185 & M570 Trackball
    37Mb/s Down - 9.5Mb/s Up
    Chrome
    BitDefender Total Security 2017
    Also run...
    Desktop - 6Core 8GB - Windows 10 Enterprise x64,
    Laptop - Quad 8GB - Windows 10 Pro x64
    Netbook - Ubuntu
    2 x Nexus 7 Android tablets
    Samsung 10.2" tablet
    Sony Z3 Android Smartphone
    HTC One Android Smartphone
Kari,
I have been testing with almost every thinkable application, seems Explorer is the only one which causes Windows to enter directly to desktop. All other applications, including browsers wait until the user has clicked the Desktop tile before executing the task.
Just now I am playing with an idea to create two tasks. First to launch Explorer as told in this tutorial adding the /separate argument. As you know the command explorer.exe /separate launches a separate second Explorer instance, so we can kill this second instance without meddling with the first Explorer instance.
Now the second task would then launch command C:\Windows\System32\Taskkill.exe /IM explorer.exe, killing our second Explorer instance launched with Task Scheduler, leaving a nice and empty desktop. The issue is timing: This Taskkill task must be delayed to let the Explorer task run first. If delay is set to 2 seconds I get it working on one vm and one physical desktop PC and not working on two vms and a laptop I have tested.
On Action tab (tutorial step 5.) you can add other actions, launch for instance your browser on Eight Forums. One scheduled task can include several actions. If you add actions here it is important to set delays for each action so the resulting application windows open in correct order, the one you open last will be on top of all others. Of course you can also set these other apps to open minimized, in Taskbar (create a shortcut > Properties > Run minimized).
Kari
    HP ENVY 17-1150eg
    6 GB
    1600*900 (1), 1920*1080 (2&3)
    50 MB VDSL
    Maxthon 3.5.2., IE11
    Windows Defender 4.3.9431.0
Thanks for the insight Kari,
Will have to find some time to sit down and seriously play with eight, just don't get enough time at the moment :)
    Asus M5A78L-M USB3
    Internal
    Crucial 256GB SSD,
    Toshiba HDWD130 3TB
    External (USB3)
    NAS
    Seagate ST4000DM000
    Chrome
    Also run...
    Netbook - Ubuntu
I followed the link from one of those debate-threads.
Great work Kari! I'll give it a go on my laptop. I'm testing some speed scenarios (how fast I get to desktop/start, it's about loading)
Thanks a lot.
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    multiple resolutions
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
    That's basically it.
You are welcome, Hopachi.
I'm very keen to hear suggestions, I'm still testing how to boot to EMPTY desktop. At the moment this is the only solution I get to work on every PC, going to desktop with Libraries open.
    HP ENVY 17-1150eg
    6 GB
    50 MB VDSL
Typing "task" doesn't take me to the task scheduler, only the task manager.
    Use several different computers during a day, so specs are irrelevant.
Sorry. My bad, a typo. It should say "Type Schedule".
Tutorial edited.
Kari
    HP ENVY 17-1150eg
    6 GB
    50 MB VDSL
I don't think so. Maybe it works for your config, but for me, it will not work unless you have also enabled the Admin tools through the charms - settings.
I really do not understand what's your purpose of this?
To show you something, I just installed Windows 8 fresh on a test machine and recorded following using the Windows built-in Problem Step Recorder (Win + W, type PSR in normal Windows 8 machines, do not know what you need to type to find it).
First, here are the steps I PSR recorded. Please keep in mind this is an absolutely new, fresh install, in fact this PSR was the first app ever launched in this setup as I installed Windows 8 now only to make this recording:
Recording Session: ‎16/‎04/‎2013 14:15:55 - 14:16:22
Recorded Steps: 8, Missed Steps: 0, Other Errors: 0
Operating System: 9200.16551.x86fre.win8_gdr.130306-1502 6.2.0.0.2.49
[COLOR=#b22222][B]Step 1: User left click on "Start Screen (list item)" in "Start Screen"[/B][/COLOR]
Program: Windows Explorer, 6.2.9200.16384 (win8_rtm.120725-1247), Microsoft Corporation, EXPLORER.EXE, EXPLORER.EXE
UI Elements: Start Screen, Start Screen, ImmersiveSwitchList
[COLOR=#b22222][B]Step 2: User left click on "Settings (button)" in "Charm Bar"[/B][/COLOR]
UI Elements: Settings, TouchButton, CCharmBarElement, Charms, NativeHWNDHost
[COLOR=#b22222][B]Step 3: User left click on "Tiles (list item)" in "Settings"[/B][/COLOR]
UI Elements: Tiles, SettingsButton, ItemList, TouchScrollViewer, Settings, SettingsUI, Element, Charm window, FlyoutElement, Settings, Shell_CharmWindow
[COLOR=#b22222][B]Step 4: User left click on "Back (button)" in "Tiles"[/B][/COLOR]
UI Elements: Back, BackButton, Tiles, Element, Charm window, FlyoutElement, Tiles, Shell_CharmWindow
[COLOR=#b22222][B]Step 5: User left click on "Close (button)"[/B][/COLOR]
UI Elements: Close, Shell_LightDismissOverlay
[COLOR=#b22222][B]Step 6: User keyboard input on "Start menu (pane)" in "Start menu" [... Win-W][/B][/COLOR]
UI Elements: Start menu, CHostElement, Start menu, ImmersiveLauncher
[COLOR=#b22222][B]Step 7: User keyboard input on "Search (pane)" in "Search" [...][/B][/COLOR]
UI Elements: Search, SearchPane, Search, SearchPane
[COLOR=#b22222][B]Step 8: User left click on "Schedule tasks (edit)" in "Settings Search"[/B][/COLOR]
UI Elements: Schedule tasks, RichText, Schedule tasks, CFileSystemElement, Project to a second screen, GridGroup, GridContent, TouchScrollViewer, Grid View, GridRoot, Results List, UIExplorerBrowser, Settings Search, UIFileSearchApp, Settings Search, FileSearchAppWindowClass
And the important screenshots created by PSR:
Step 4: Clicking Tiles to show admin tools are disabled:
Step 7: Typing Schedule to Charms Settings Search clearly show Schedule Tasks as first search result > hitting Enter will open Task Scheduler:
Complete PSR recording with all screenshots: View attachment PSR.zip (You need to use IE to read the zipped .mht file)
Keenly waiting your next move!
Kari
    HP ENVY 17-1150eg
    6 GB
    50 MB VDSL
At the moment this does the job well. :thumb:
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
Sorry Hopachi. As I said, I need to enable the Admin tools in the settings, in order to get a result from search. It may be my particular configuration. It is not my intention to discredit your tutorial.- You do have to reboot after enabling or disabling, but this is what I get. As you can see, if I have the Admin tools disbled, like this:
I get this:
None.pngIf I enable the Admin tools, and reboot, I get this:
Have you tried the settings search as told in tutorial, WIN + W?
Anyway, both search terms Task and Schedule finds Task Scheduler on my systems using app search (Win > Search or Win + Q > Search), and searching Scheduler in settings search finds it, with or without admin tiles.
Task Scheduler should also be found in All Apps.
    HP ENVY 17-1150eg
    6 GB
    50 MB VDSL
Hmmm... Interesting.
Metro and the Start Screen are part of Explorer so Explorer always stared first, showing what it has to show.
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
Yes, it is interesting. I would have thought other basic native Windows tools would also take user directly to desktop if launched on logon as a scheduled task but for instance Command Prompt behaves as I described: logon stops in Start Screen and cmd.exe (as scheduled task) is only launched when user clicks Desktop tile.
Most fascinating is that my tests with two tasks, launch Explorer in a separate task first on logon, then wait a few seconds and launch Taskkill to terminate this second Explorer process resulting an empty desktop works in one of my desktops and one vm. On all other rigs, physical and vm I have tested the logon stops at Start Screen, then when desktop tile is clicked the Explorer opens and immediately closes as these two tasks are launched.
But, it's OK. I like this challenge. If you have some ideas to test, please tell.
Kari
    HP ENVY 17-1150eg
    6 GB
    50 MB VDSL
Dave, the search on the start is bumpy sometimes, can't figure out why. Some items need to be placed as shortcuts by force...
Going through the classical Control Panel (click anywhere in an open Explorer and go tho Desktop, then Control Panel) helps.
I see that those Admin tools are pinnable all at once but I didn't needed this in my config just to confirm.
My apologies if I missed some details.
If you've already fixed the issue then great job. :)
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
Kari
No ideas for the moment but what you posted here is really worth knowing. :)
Compared to Win7's Explorer, in 8 the new UI which is mostly part of Explorer, adds some new rules we can even tell just from watching boots and tests.
Cheers!
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
Tks for the response, Hopachi. As you say, the search is, sometimes, a little hit or miss. I did try several times with Admin on and off, and got the same result.
But, as you have read, there is still a couple of glitches with going straight to the desktop.
Like yourself, I find the Admin tools, on the modern screen, a waste of space, so prefer to do without. A quick visit to the CP is more practical.
For the moment, I find clicking the desktop icon is the fastest way to get to the desktop.
Keep at it!
Hi all
i use this tutorials to do a short cut of my desktop
HTML:
%windir%\explorer.exe shell:::{3080F90D-D7AD-11D9-BD98-0000947B0257}
,than in step "action" (start program) in program/script fild just paste not browse just paste location of your short cut with extinsion (.lnk) in my case Desktop.lnk
And it is work for me
sorry for my bad English
    WinPro 64
Hi all
HTML:
Great!
I tried the shell entry in the arguments path under the action but it doesn't work that way.
You get to the point where you make the path to the command/script:
Then, as extra, under arguments in the scheduler window:
Doesn't seem to work, rebooted twice...
And without that extra argument it works well.
Strange... Maybe that shell it's not meant as an normal executable argument.
Thanks for letting us know the shortcut way works. :thumb:
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
