System Type - 32-bit (x86) or 64-bit (x64) Windows 8
How to Tell if You Have a 32-bit (x86) or 64-bit (x64) Windows 8 and 8.1
This tutorial will show you how to tell if you have a 32-bit (x86) or 64-bit (x64) version of Windows 8 and 8.1 installed on your PC.
1. Do step 2, 3, or 4 below for how you would like to open the System window.
2. Press the :winkey: + Pause/Break keys, and go to step 5 or 6 below.
3. Open the Control Panel (icons view), click/tap on System, and go to step 5 or 6 below.
4. Open the Power User Tasks Menu, click/tap on System, and go to step 5 or 6 below. (see screenshot below)
5. If you have a 32-bit (x86) Windows 8 installed, you will see 32-bit to the right of System type. (see screenshot below)
6. If you have a 64-bit (x64) Windows 8 installed, you will see 64-bit to the right of System type. (see screenshot below)
Method for geeks:
Open Run by pressing :winkey:+R, type msinfo32, then click OK.
Look on the System Type, if it was 32-bit it will show x86-based PC, if it was 64-bit it will show x64-based PC.
    Windows 10 Pro x64
    Lenovo Y520
    Intel Core i5 7300HQ
    OEM Lenovo
    4GB DDR4-2400
    NVIDIA GeForce GTX 1050
    Realtek HD
    Seagate 1TB 5400 RPM
    OEM Lenovo
    Logitech G502 Proteus Core
    100 Mbps
    PC:
    AMD Athlon X4 760K
    8GB DDR3-1866
    AMD Radeon RX 460
    Seagate 500 GB 7200 RPM
:thumbsup:
