ISO Images - Mount or Unmount
  1. #11
    Portsmouth Hants
    It'll only go when the basic devices don't depend on being enumerated in the registry. That's why I go on about C: drives. look how simply 'nix does it - everything's a file - not entries in a non-relational, obscurely structured database with unintelligible codes nested 20 deep.
  2. #12
    I don't have a Manage tab on File Explorer/Windows Explorer. Does this require hardware virtualization to work? I don't have it since this is a Intel P4.
  3. #13
    Hello Rich,
    Your association for .iso files may not be set to default. If you like, the .iso option in the tutorial below will restore the default associations for it, and hopefully you'll have the Manage tab when you select an .iso file afterwards.
    Default File Associations - Restore in Windows 8
  4. #14
    Thanks Shawn, that was it. The default was set to IsoBuster. Restored default and it works a treat. I like it!
  5. #15
    You're most welcome Rich. I'm glad to hear all is well again.
  6. #16
    Using the command prompt in Windows 8.1 update, how do I mount and unmount an ISO image?
    Thanks
    Bye
  7. #17
    Hello Balubeto,
    You could mount an ISO or IMG file using the command below in PowerShell.
    Mount-DiskImage -ImagePath "Full path of ISO file"
    Mount-DiskImage
    To unmount the ISO or IMG file, you could use the command below in an elevated command prompt. It would be the same as ejecting the drive.
    mountvol DriveLetter: /d
    I've updated the tutorial to add this to help.
    Hope this helps,
  8. #18
    Quote Originally Posted by Brink View Post
    Hello Balubeto,
    Mount-DiskImage
    Hope this helps,
    It is possible to do it even with a command not Powershell?
    Thanks
    Bye
  9. #19
    You could type powershell in a command prompt first, press Enter, then use the command below in the command prompt. It won't work in one line though.
Page 2 of 2 FirstFirst 12
Tutorial Forum
Mount iso missing
Hello everyone, Am having a trouble with iso files. When I select the .iso files the Manage is not activating or enabling. pls suggest me to solve this. 15169 Thanks in Advance!
How to mount ext hdd
So I am running Ubuntu on my laptop which has been my primary computer for the past two years or so. My issue is this: I bought a new computer, I was in the process of setting everything up then when I realized my HDD wasnt there, I figure I didnt plug it in all the way. No, it is in, the computer...
Drivers & Hardware
Power2go could not unmount image the file
ive never really had a problem with power2go it came with windows 8 so i was happy expect for today i can not mount a ISO file to the virtual drive you know when you select a ISO file then click okay and it says ISO successfully mounted well it doesn't say anything at all i click okay then nothing...
Software and Apps
mount .bin.cue files
hi , having trouble mounting files in w8 always used diamond tools before (in vista) without any trouble. but now its not working at all, im mounting the file and all that happens is audio file(1kb) in the viritual drive. have been sitting here for like 4h and whatever i do nothing works..
Not able to mount iso file
Hi, I didn't install any 3rd party app to mount iso. Yesterday, i tried to mount a iso file, it didn't worked. Then googled about it, tried sfc /scannow, no success. Then i checked "Default programs - associate file extension...", there is no entry for .iso. Please help. 27780 Tried Daemon...
Virtualization
Unmount an ISO Drive
Hi. I used my BD to load an ISO file and it mounted a CD Drive (F:) to accomplish that. I know to unmount the drive you need to right click and 'Eject' it. However, my 'Eject' option is greyed out and not available. Until I unmount that drive, I am not able to use my physical Blue Ray Drive. ...
VHD or VHDX File - Unmount and Detach in Windows 8
How to Unmount and Detach a VHD or VHDX File in Windows 8 This tutorial will show you how to unmount and detach a VHD (Virtual Hard Disk) or VHDX (Hyper-V Virtual Hard Disk) file that was mounted/attached as a drive in the Computer window for all users in Windows 8. You must be signed in as...
Tutorials
