How to Create a Bootable UEFI USB Flash Drive for Installing Windows 7, Windows 8, or Windows 8.1
This tutorial will show you how to create a Windows 7 or Windows 8 or 8.1 installation bootable USB flash drive for UEFIfrom either a Windows 7 or Windows 8/8.1 installation ISO or DVD.
Requirements:
  • At least a 4GB USB flash drive
  • 64-bit Windows 7 ISO or DVD (If you want to install Windows 7)
  • 64-bit Windows 8 ISO or DVD (If you want to install Windows 8)
  • 64-bit Windows 8.1 ISO or DVD (If you want to install Windows 8.1)
  • 32-bit is not supported.
  • Set the boot mode to use UEFI and not CSM (Compatibility Support Module) in your UEFI firmware settings.
  • Temporarily disable Secure Boot in your UEFI firmware settings. Some motherboards will not boot from a USB unless you do this first. When the Windows installation is finished, you can enable secure boot if you like.
  • If you have fast boot or ultra-fast boot enabled in your UEFI firmware (if supported), then you may need to temporarily disable it until Windows has finished installing to be able to boot from a USB flash drive at boot.
EXAMPLE: UEFI Bootable USB Flash Drive
NOTE: This is it listed in the motherboard's boot menu.
To Create a Bootable UEFI USB Flash Drive using Free Program "Rufus"
This is a standalone exe file that doesn't install anything to your PC
  • Under Format Options, check Create a bootable disk using, click/tap on the browse icon icon.jpg to navigate to and select your 64-bit Windows 7 or Windows 8 or Windows 8.1 ISO file, and then make sure that Standard Windows installation is selected (dotted).
  • Under Partition scheme and target system type, select GPT partition scheme for UEFI computer.
  • Under File system, select FAT32.
7. Rufus will now start creating the bootable UEFI USB flash drive. (see screenshot below)
9. You are now ready to do a clean install of Windows 7 or Windows 8/8.1 using UEFI with your bootable UEFI USB flash drive.
To Manually Create a Bootable UEFI USB Flash Drive
1. Connect the USB flash drive.
2. Open an elevated command prompt in Windows 7 or Windows 8/8.1.
3. In the elevated command prompt, type the commands below one at a time and press Enter after each one. (see screenshot below step 5)
  • diskpart
  • list disk
4. Make note of the Disk # (ex: Disk 4) for the USB flash drive. (see screenshot below step 5)
It is critical that you use the correct disk #. If you do not, then you could delete the wrong drive below and lose everything on it
5. In the elevated command prompt, type the commands below one at a time and press Enter after each one. (see screenshot below)
NOTE: Substitute # in the first command with the actual disk # from step 4 above. For example: select disk 4
  • select disk #
  • detail disk (this is to verify that you selected the correct disk before using "clean" below)
  • clean
  • create partition primary
  • format fs=fat32 quick
  • active
  • assign
  • list volume
  • exit
6. Make note of the volume letter (ex: K) for the USB flash drive in the command prompt. (see screenshot above)
7. Do step 8, step 9, or step 10 below depending on if you are using a Windows 7/8/8.1 ISO or DVD.
It has been reported that using the downloaded Windows 8 upgrade ISO does not always give you an UEFI bootable USB option in the boot menu.
If this happens to you, then use the ESD-TO-ISO.exe program created by our member Simon (SIW2) below to create an ISO that will work with UEFI. Afterwards, start this tutorial over using this new ISO instead.
See OPTION TWO here: Windows 8 and Windows 8.1 ISO - Download or Create
8. If Using a Windows 7 or Windows 8/8.1 ISO File in Windows 8
NOTE: For a Windows 7 ISO or Windows 8/8.1 ISO file.
A) Open File Explorer, navigate to the .iso file, right click or press and hold on the .iso file, then click/tap on Mount. (see screenshot below)
B) The mounted .iso file will now automatically open. Select all files in it, right click or press and hold on the selected files, click/tap on Send to and the Removable Disk for your USB flash drive letter (ex: K) from step 6 above. (see screenshot below)
C) This could take a bit to copy the ISO contents to the USB.
D) When finished, go to step 11 below.
9. If Using a Windows 7 or Windows 8/8.1 ISO File in Windows 7
A) If you have not already, you will need to download and install the latest alpha version of the free program 7-Zip.
NOTE: You can use any program that performs the same function to extract or mount an ISO, but I just find 7-Zip easier to use.
B) Open Windows Explorer, navigate to the .iso file, right click on the .iso file, then click on 7-Zip and Extract files. (see screenshot below)
C) In the Extract dialog, click on the browse button, select the Removable Disk for your USB flash drive letter (ex: K) from step 6 above, and click on OK, and OK. (see screenshots below)
D) This could take a bit to copy the ISO contents to the USB.
E) When finished, go to step 11 below.
10. If Using a Windows 7 or Windows 8/8.1 Installation DVD
A) Insert the Windows 7 or Windows 8 installation DVD into the CD/DVD drive.
B) In the Computer window, open the DVD. (see screenshot below)
C) Select all files in it, right click or press and hold on the selected files, click/tap on Send to and the Removable Disk for your USB flash drive letter (ex: K) from step 6 above. (see screenshot below)
D) This could take a bit to copy the DVD contents to the USB.
11. If Using 64-bit Windows 7
Thanks to theog for this step
You do not need to do this step unless you are creating a 64-bit Windows 7 UEFI USB flash drive.
If you are not, then go to step 12 below instead.
A) On the USB flash drive, "copy" the efi\microsoft\boot folder up one level into the efi folder as efi\boot. (see screenshot below)
B) If you have not already, download and install the latest alpha version of the free program 7-Zip, then run 7-Zip.
C) In 7-Zip, navigate to the sources\install.wim\1\Windows\Boot\EFI\bootmgfw.efi on the USB flash drive, select the bootmgfw.efi file, copy it to your desktop, click/tap on OK, and close 7-Zip. (see screenshot below)
D) Rename the bootmgfw.efi file on your desktop to bootx64.efi.
E) Copy/Move the renamed bootx64.efi file into the efi/boot folder (step 11A) on the USB flash drive.
F) Go to step 12 below.
12. You are now ready to do a clean install of Windows 7 or Windows 8/8.1 using UEFI with your bootable UEFI USB flash drive.
  • ESD-TO-ISO.zip
Nice one, Shawn.
    ME, XP,Vista,Win7,Win8,Win8.1
    Notebooks x 3
    Desktops x 5
    Towers x 4
Thanks!!
    Win 10 Pro 64bit
    Corsair M65 wired
    85MBps DSL
    Chrome and Edge
    1GBps Ethernet ports
You're welcome Guys. Glad you like it. :)
These tutorials are very useful and I send them to friends and family who have Win8 and are unfamiliar with this stuff...
    Win 10 Pro 64bit
    Corsair M65 wired
    85MBps DSL
    Chrome and Edge
Great tutorial, hope to be using it soon.
    76~2.0
    Intel Core i5-3570K 4.6GHz
    GIGABYTE GA-Z77X UD3H f18
    Onboard VIA VT2021
    22" LCD Dell SP2208WFP
    1680x1050
    Corsair HX650W
    Cooler Master Storm Scout
    Logitech Wave
    CM Sentinel
    Abysmal
    Opera Next
    Desktop: eSATA ports,
You can use the free version of Poweriso to create efi compatible flash from the installation iso.
Fat32 is a nuisance.
You may need to split your install.wim if you have updated it.
Strange to use such an old fashioned file system.
    7/8/ubuntu/Linux Deepin
    Notebooks x 3
    Desktops x 5
    Towers x 4
In step 11A,
copy the efi\microsoft\boot folder up one level into the efi folder as efi\boot
Do I do a copy or a cut?
    Windows 7 Home Premium 64-bit
    HP p6204y
    2.7 GHz
    IPIBL-LB (Benicia)
    8 GB
    Integrated
Hello Layback Bear,
You would copy it. :)
Hi, Brink. Thanks very much. I successfully created a Windows 7 64-bit UEFI bootable flash drive, and I'll try it in a few days. This is yet another great source of info, just as SevenForums is. I love it here. :thumb:
    HP p6204y
    2.7 GHz
    IPIBL-LB (Benicia)
    8 GB
    Integrated
You're most welcome. Great news. :)
B) Having the free program 7-Zip installed, right click on the sources\install.wim file on the USB, and click/tap on 7-Zip and Open archive. (see screenshot below)​
C) In 7-Zip, navigate to and "Copy" the sources\install.wim\1\Windows\Boot\EFI\bootmgfw.egifile to your desktop, and close 7-Zip. (see screenshot below)​
D) Rename the bootmgfw.egi file on your desktop to bootx64.efi.
E) Copy/Move the renamed bootx64.efi file into the efi/boot folder (step 11A) on the USB.​
For my iso, I was unable to open '/sources/install.wim', but I found bootmgfw.efi at '/sources/boot.wim'.
    Linux Mint 12 and Windows 8 x64
Hello Enkouyami, and welcome to Eight Forums.
Were you using the 7-Zip program to open '/sources/install.wim'?
What happened when you tried?
It said "Can't open install.wim as archive"
*Edit*
If I have to use install.wim instead of boot.wim, can someone please upload their bootmgfw.efi file?
Sorry, but posting the file is not allowed as it will violate Microsoft's distribution of copyrighted material policy.
Are you able to use "Extract Files" to extract the install.wim to a new folder on your desktop instead at step 11B, then proceed from there to get the bootmgfw.egi file?
It'll take a while to finish extracting though.
Thanks, worked flawlessly for both 7&8.
My new Samsumg 840Pro is setup with GPT and dual booting.
    76~2.0
    Onboard VIA VT2021
    1680x1050
    Corsair HX650W
    Logitech Wave
    CM Sentinel
    Abysmal
    Opera Next
Great news Dave. Thank you for posting your results. :)
I'm really pissed off. I took over 2 houres just to figure something out. I've done EVERYTHING step by step in order to boot through a UEFI USB to install Windows 8 but it doesn't work at all. I started by creating correctly the UEFI USB in the dos prompt on a different computer using Win 7 64bit then copyed all files from the Win 8 DVD to my USB. Since it's to install it as a 64bit, I did the last step that required to put the folder 1 step above and open the Install.wim for 1 file.. then I plug in my usb key, press F11 and see my Corsair USB as standard but also as in UEFI. In standard it works but won't install on a GPT partition. All this massive trouble is just to install Win 8 on GPT for my Samsung 840 250Gb SSD so I choose UEFI USB in the F11 boot menu but then...
It just shows the same crap as if I would boot directly into the UEFI Rom and it stays there. It DOESN'T load the Win8 that is on the USB, wtf?! Do I need to input any command in the UEFI prompt so it can launch the damn setup.exe ?? :confused:
Great tutorial Shawn!
I'll give it a try soon, for the sake of the only UEFI machine I got here. :)
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    multiple resolutions
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
    That's basically it.
