help!!! after virus problem
    The module C:\Users\jsofe_000\AppData\Local\A\dasdfg21.dll failed to load.
    Make sure the binary is stored at the specified path or dependent.DLL files.
    After a virus attack, when you start the computer, I get this message and do not know what to do and what the consequences should be expected.Thanks in advance for any help.
    Windows 8 Pro 64-Bit
    Open Task Manager, look at Startup tab. Check for any items that don't look normal and tell us the names so that we can look more into them.
    1. You can reinstall windows this will be the best option as you can eliminate the possibility of virus, some hide and resurface again later.
    2. SFC /SCANNOW Command - Run in Windows 8 Do a system file checker and hope for the best. You can start with option 3 to get an overview and analyzes, will let you know if it will be able to do anything about it. Option 1 will go straight into the job and search, find, and repair if possible.
    3. Wait for more advice from other users.
    dasdfg21 does not seem like a familiar part of windows, very likely it was leftovers from the infection and your software failed to do a CLEAN removal of it. Which happens a lot, Do you know what virus had infected you? A name could give us better information on what it does and where it keeps all of it's parts.
    Hi Jossof,
    You need to check the following areas:
    1. Press WINDOWS + R on your keyboard.
    2. Type "msconfig" then press ENTER.
    3. Go to the Startup tab and untick any entry that matches that file. Match the file in error message and the command line column on the Startup tab.
    Check the Task Scheduler for related entry as well.
    Scan your computer using a security software such as Trend Micro Internet Security or Malwarebytes Anti-Malware.
    San Diego
    Windows 8.1 Enterprise
    I like to use Avast Anti-Virus...It gives you the option to do a boot time scan, and I have been able to get rid of a few viruses on others computers that other Virus Scanners have left behind...might be worth a try
Virus on tablet problem
Got the FBI moneypack virus on my tablet, locked me out as soon as I log in. I have read that booting into safe mode can start the resolving process, but I can't figure out how to do it on my tablet. It's one of the unbranded ones from best buy, I can press the power and both volume buttons but all...
System Security
Hi guys,gals I have been having some trouble with my windows 8.1. I have picked up a virus on my hp lap top, I have only had it 4 weeks and I installed the recommended mcafee live safe. I tried all the usual tricks to get rid of the virus but to no avail. I have done a factory re set and it still...
System Security
Microsoft called today to tell me that my computer may be infected with a really nasty bug. but I have Norton, but they said this could slip right past Norton. I let microsoft to control the computer and that they did they found there were at least over 34 thousand hits on my files from this thing....
System Security
Windows defender/firewall problem after computer virus
Greetings! I am running windows 8. Over the weekend I seemed to have contracted a computer virus. I was unable to access specific websites (google,fb etc) and I noticed the windows firewall was turned off and I was unable to turn it on again. I attempted a system restore but the system froze...
Virus infestation problem
This morning I ran Malwarebytes and SuperAntivirus as I do periodically. SuperAntivirus didn't find any major threats but Malwarebytes came up with a list of files affected by a PUP virus.My next step would normally be to press Remove then restart the computer as requested to remove all remaining...
System Security
Virus or Windows 8 Problem??
Hi all, Just joined these forums to try to get a handle on what's happening with my desktop. I installed Windows 8 a few weeks ago and it was running fine for a while. Then about a week ago I came home and my PC had restarted due to some automatic Windows updates. I've now got an almost...
virus attack problem
while browsing,i opened the site by mistakely.when i clicked on any video on this site to play it says to download adobe flash player.when i click on this,a small .exe file i install it.but this was a my lapi gets affected by this virus even...
System Security
