Optimizer Pro problem
    I try so hard to avoid adware, pop ups and such, but these sites sneak them in if they can.
    I use Revounistaller to get rid of unwanted progs and I swear by it, but even after using it today, and it showed it had been removed, up to an hour ago, it was still appearing. sites if you know any
    This Optomizer Pro, if you know much about it
    Cant get rid of this blighter
    Hi Guys
    Although I uninstalled this invader with Revo-Uninstaller, it still keeps appearing, but its not in the Revo list of installed progs, any advice please
    Windows 8.1 Pro, 64 bit
    Try Crap Cleaner it may show up with this
    Have you tried running any malware removal programs, such as Malwarebytes?
    If not, please d/l it, the free version will work fine, make sure to uncheck the "start pro trial version" & do a full system scan with it. Check the box of anything it finds & let Mbam quarantine it.
    Also, see this article:
    How to Remove PC Optimizer Pro (Uninstall Guide)
    It also wouldn't hurt to d/l & run these programs:.
    AdwCleaner Download
    TDSSKiller (To rule out the possibility of a rootkit)
    TDSSKiller Download
    I'd get the latest version, install it, then uninstall it though the windows installer, restart your PC.
    Quote Originally Posted by Mr Sardonicus View Post
    latest version of what?
    Borg>>c/on those links I was warned off saying they could b harmfull
    Those links are safe. More-then-likely the malware trying to protect itself.
    PC Optimizer Pro itís technically not a virus, but it does exhibit plenty of malicious traits, such as rootkit capabilities to hook deep into the operating system, browser hijacking, and in general just interfering with the user experience.
    8.1 6.3.9600
    If PC optimizer Pro Latest Program has come bundled with an updater service or registration service.
    I believe it can be removed out of start up, or MS configuration Utility/+ Services. As well to delete the service with Auto runs.
    This could help remedy the issue of the updater service.
    Link Here:
    Autoruns for Windows
Best System Optimizer 2014
Hello, I was wondering what you guys think is the best system optimizer. Please note that if you do not use system optimizers, there is an option in the poll that says you do not use system optimizers. The poll can be found here: What do you think is the best system optimizer? | ...
Software and Apps
Context menu item problem and accessing files problem
I have 2 issues. I don't know if they are related somehow. 1. I installed PrivaZer and deleted it. It still shows up on the right click context menu. I tried to reinstall it and deleted it again. I still have that problem. I even restarted the computer. How can I get rid of the entry? 2....
Windows defragger & optimizer
I tried this and I can't tell if it works or not. When I defrag & optimize it never stops going thru passes. I stopped it at pass 15 but there was no evidence that anything was corrected. Anybody know anything about this Thanks
Performance & Maintenance
Best free optimizer for Win 8.1?
I'm cheap so I want something good and free please :P.
Optimizer please?
Help me choose my optimizer. at this moment, I only got CCleaner. Is their any more that i would need? On my old machine i used Tune up utilites 2013/2012 well, At the moment. I think i dont need it? So can you give me a hand. I would pay for it of course.
Release Preview - Nothing but problem after problem after problem.
I had no problems with Customer Preview, everything worked, but, I must say that this Release Preview is another story all together. My PC hardware configuration is unchanged since installing Windows 7 when it came on to the market. 1. Doing a clean install did not install a clean...
