permission problem "unable to display the current owner"
aringan
I am unable to change any permission for any folder . every option that supposed to be available for setting the permission is gray out!! , for some of my files I see the owner is "unable to display the current owner".
I have attached the 3 screen shots !!
please help me
Do you have UAC toggled on?
you need to do that then take ownership of the folder(s) from the advanced properties.
    Windows 8 Pro
    6 GB
    1280 x 1024
    12 TB in 6 disks
    TX650
    G15
    Intellimouse 3.0
    100 Mbits
    Chrome
    Trend Micro
The UAC is toggled on as always. the problem is the same for every single folder and file. I checked other systems and they are working just fine ! but I am just unable to modify any permission for any folder or file !! even I tried to change the owner but it didn't worked !!
The last time I had this problem , I had to download and boot into Linux mint from a DVD I made and used
chmod -R 777 \mydirectory
and
chown -R username \mydirectory
to set read/write/execute and set owner from there , it's not ideal , but it was a workaround which let me then set permissions under Windows afterwards.
I am fairly sure you can do the same from the GUI under linux mint as well.
I keep my linux mint DVD handy at all times these days , sometimes it's the only way to fix drive/file permission problems under Windows.
    Windows 8 Pro
    6 GB
    1280 x 1024
    12 TB in 6 disks
    TX650
    G15
    Intellimouse 3.0
    100 Mbits
    Chrome
    Trend Micro
