How to get volume on screen display?
    Win8 Pro
    I just installed Win8 on my acer netbook, upgrading from Win7. On my previous os, whenever I changed the volume on the keyboard, a little image would pop up on the screen, showing a bar representing my speaker volume.
    This is not on win8. Can anyone tell me what to install to get it back?
    Windows 7/8
    You need to reinstall the drivers and other "add on" files that originally came with your laptop.
    If you are lucky, Acer will have these for download off their website for your model...
    Hi qwertymz,
    Did you mean the one in the pic or the Acer's original Volume indicator?
    As FSeal said, try Acer's Launch Manager Application, volume indicator in the pic works in Win 8RP.
Unmountable boot volume blue screen loop.
I was playing Dota 2 when blue screen showed. It says Your PC ran into a problem and needs to restart after 2 or 3 loop Automatic repair start then it will just show a black screen with a cursor. I need help guys.
BSOD Crashes and Debugging
Volume mixer becomes unresponsive when I change volume
Scanning and repairing volume (\\?\Volume...) on startup
Hello Guys, this is my first post on eightforums, i recently got a new laptop "asus vivobook" that came preloaded with windows 8. The laptop comes with a hybrid 24 GB ssd (8GB of those are for the system files,windows 8 is installed on,the remaining are in a 2nd partition for recovery) i...
Performance & Maintenance
what is this wired volume in defrag screen
Hi i have this wired volume in my defrag screen after windows 8.1 upgrade what the heck is it here is a picture. Highlighted in blue is the volume ??
disable volume/brightness onscreen display
Is there a way to disable the volume and brightness on screen displays? I rather use the ones provided from my manufacturer, rather than seeing both. thanks
Volume control on screen that won't go away
So I recently updated a Lenovo 540b all in one touch screen pc to windows eight. Everything worked perfectly. Today I played some music through the stock music app and this annoying on screen volume control popped up. Since then I have been unable to get rid of it without stopping the audio...
On-screen volume control/notification
Previously I was able to pull up the on-screen media display when I press the volume button and previous/next tracks button on my keyboard but now the on-screen notification has disappeared and the volume control is not working. I am using logitech keyboard and I want to use the metro style...
