Hi, I've just got my Windows 8 through Dreamspark Premium. I was using windows 7 and did a clean install of windows 8.
After installing windows 8, there's no sound from my speaker. Sound only works with earphones. What should I do?
My laptop:
Asus N53J
**UPDATE**
I went to the asus website and update the audio driver, it partially works now. The sound is there, but I keep getting error message about SRS audio cannot be found. I go to the add/remove program and saw two programs have been installed:
-Realtek High Definition Audio Driver
-SRS audio contro panel
I uninstall the SRS audio control panel and it seems the error message is gone. But I hope I didn't corrupt anything.
I remember I don't have this problem with Windows 8 release preview...why?
My laptop:
Asus N53J
**UPDATE**
- Windows 7
