IDT Audio Pavillion DV6 Not Working
    Windows 8 Professional
    Hi All
    Just downloaded Windows 8 Professional from Dreamspark Premium. Installation has gone really well and I'm getting used to it already, but there's a slight problem - no sound
    Has anyone got any instructions for sorting this out? the laptop I'm using is a HP Pavillion DV6-6b50sa which normally uses IDT Audio.
    Installing audio drivers aren't my forte so if anyone could help then it'd be much appreciated
    Thanks in advance
    EDIT: Just tried unplugging the headphones - sound works fine without the headphones, but when I plug them in it goes dead again, then the whole thing just stopped - any ideas?
    If anyone else has the same problem with IDT Audio - go to the 'SWSetup' folder (accessible from the C: drive), then 'Audio' then run IDT. It will ask you to restart - restart then when you log back on, sound will work through headphones too
    Orbiting the Moon
    Windows 10 x64
    Yes indeed.
    But that folder isn't always there, on clean installs for example.
    So you need to get the driver from the MS Update Catalog if you need the latest Win8 driver.
    Microsoft Update Catalog
    This fixed it for me here:
Realtek audio not working after win 8.1 pro
i've recently installed win 8.1 pro N x64 and this has stopped my onboard sound card from working. my mobo is the MSI big bang xpower ii, it was working fine under win 7 home edition x64 but now refuses to do anything. when i try to test the playback device the green bar moves sporadically up and...
HD Audio Device not working
Hi All, I searched the threads but could not find a solution. My High Definition audio device is not working. This is the error message, This device cannot start. (Code 10) {Operation Failed} The requested operation was unsuccessful.
audio not working
i am using lenovo g500s notebook. i have a problem with sound. sometime no audio comes from speaker but its comes automatically after restart the laptop... i have up to date drivers....:rolleyes:.plz help me out
IDT hd audio not working
Just a question: Has anyone found decent drivers compatible with Win8, that work, for the IDT high definition audio on HP pavilion DV7 laptops? Thanks Hopachi
Drivers & Hardware
Crashing on a HP Pavillion g6
Hello, my neighbour has a HP Pavillion g6 running Windows 8 and lately these days the computer has been crashing/rebooting and there appears some message with links to dump files. I have saved the .dmp file to a flash drive and attached it here. I'm sorry but I cannot use the SF Diagnostic Tool...
BSOD Crashes and Debugging
Windows 8 Pro RTM audio not working!
I was just using my earplugs on my Windows PC and I when I disconnected them, my audio stopped working. I have a quad-boot of Windows 8 Pro, Windows 8 Release Preview, Windows Developer Preview, and Windows 7. Sound doesn't work on any OS but Windows 7. When I play music on the Music app in...
