Solved IDT Audio Pavillion DV6 Not Working
Db1991
Hi All
Just downloaded Windows 8 Professional from Dreamspark Premium. Installation has gone really well and I'm getting used to it already, but there's a slight problem - no sound
Has anyone got any instructions for sorting this out? the laptop I'm using is a HP Pavillion DV6-6b50sa which normally uses IDT Audio.
Installing audio drivers aren't my forte so if anyone could help then it'd be much appreciated :)
Thanks in advance
EDIT: Just tried unplugging the headphones - sound works fine without the headphones, but when I plug them in it goes dead again, then the whole thing just stopped - any ideas?
    Intel i3
    6GB
    Radeon
If anyone else has the same problem with IDT Audio - go to the 'SWSetup' folder (accessible from the C: drive), then 'Audio' then run IDT. It will ask you to restart - restart then when you log back on, sound will work through headphones too :)
    Intel i3
    6GB
    Radeon
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    multiple resolutions
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
    That's basically it.
