where are the sound settings/audio options???
    Just installed Windows 8 and cannot find the sound settings/audio options ANYWHERE. Please help!
    Right click on the speaker in the task tray next to the clock on the desktop.
    Or go into control panel (charms bar->settings->Control Panel, or winkey-x->control panel) And then click on Hardware and Sound.
    Sounds - Change - Windows 7 Forums
    Windows 7 Home Premuim x64 & Windows 8 Enterprise RTM x64
    Same as all the other Windows versions.
Options Missing from Power Options Advanced Settings
I went into my power options to change some of the advanced settings and most of them are missing? I am on windows 8.1 with a week old Surface Pro 3. I want to say I read somewhere that hyper-v can cause options to be missing, but I honestly don't even know what that is and I don't have it...
Confusion about Sleep Settings and Power Saver Options
Hi, The way I know my desktop PC has gone to sleep is that the blue light around the power button flashes (instead of being on all the time). I'm playing around with some settings right now to find out exactly what is pulling it out of its sleep. I realized that if I go to Power Options and...
Power Options - Add or Remove Wireless Adapter Settings
How to Add or Remove Wireless Adapter Settings "Power Saving Mode" in Windows The "Power Saving Mode" option under the Wireless Adapter Settings section is used to configure how much power you want to save when using your wireless network card. There are four types of power saving modes...
windows 8 audio settings help
I have a toshiba satellite p75-a7200 with windows 8. When I hook up my logitech z 2300 speakers it sounds like crap. Logitech z 2300 speakers are very good speakers so this should not be happening. When I hook up my logitech z 2300 speakers to my iphone or my old dell laptop it sounds good like...
Any hope for 8.1 Power Management Settings/options???
I note a zillion angry threads to MS re: the Power Mgmt issues in 8's. anyone know workarounds? I've been working with 8.1 on a notebook, where all devices luckily are installed right and functioning right, until I go trying to make it play nice as a HTPC system... USB-attached...
Audio sound loss
I have been playing music and watching movies on my Hp pavillion g6 intel core i3 laptop player without any hitch for the past 3month,its pre-installed,the problem now is that,it is playing without audio sound,i navigate to setting,and click on volume icon,it read "DISABLED",and again"No audio...
Windows 8 Consumer Preview: PC Settings, Personalization Options
more plus several screens
Windows 8 News
