No audio output through HDMI port to TV
    Windows 8 Release Preview 8400
    Hi there, I'd really appreciate if this could work, the details of my system are as follows:
    Dell XPS L502X
    Nvidia GT 525M
    I have downloaded the Realtek Drivers as mentioned here for the Windows 8 version, plug in the HDMI cable but still the output doesn't go to the TV but sound plays from the laptop speakers.
    Earlier when I used this along with the Win 7 OS, it worked flawlessly. I don't know what the problem is. I've tried uninstalling the windows drivers and then installing Realtek drivers but still doesn't work.
    Any help would be appreciated. I've attached the screenshots of device manager as well along with audio properties.
    I've also tried downloading the ATI HDMI driver, I don't know why I don't have an ATI board anyway.. but from this site obviously it says no supporting device was found on the system.
    Win 8 release canadate
    Right click the sound icon in your tray, select "Playback devices", select your device (probably the name of the TV) and set it to default.
    Note.
    Leave it as the default as Windows will switch back to the computer speakers if the TV is off and back to the TV when you turn it on.
    Windows 8 Pro
    I guess it's by design that when the audio is directed to TV, my computer loses its audio. Image someone watching a video streamed from the computer to TV, while I work on something else on the computer, is it possible to output audio to different sources simultaneously and separately?
    Windows 8.1 Pro 64bit
    No problem with connecting PC to TV via HDMI
    Hi. I have no problem connection my PC to my TV via HDMI. Good picture and sound. But if I want to play another UTube or similar, then there is a good picture, but no sound!
    I then reinstall my Realtec drivers and all is good again. Until I want to use a second time.
    I've tried re-booting both PC and TV, booting up PC with TV turned off and with TV turned on. To no avail.
    I'm going bonkers.
    I am using Windows 8.1 with Intel 2 Core E8500 CPU and 6GB memory.
    Any useful suggestions will be gratefully received!
    United States
    Windows 8.1 Pro 64-bit
    Quote Originally Posted by obraf View Post
    I'm going bonkers.
    HDMI audio is actually a function of the graphics drivers. Sounds like the Realtek audio and HDMI audio aren't communicating properly to switch back. Do you have the latest graphic drivers installed?
    Thanks for your response. Would "ATI Radeon HD 4300/4500 Series" be the graphic card I need to update?
    Hi popeye,
    Yes, I've made sure I have the latest and correct ATI Radeon driver. Still nothing!
    United States
    Well, that is a legacy card and may have issues with 8.1. All I got left is may run this then see what Windows installs at reboot, then re-install driver manually if necessary.
    Display Driver Uninstaller Download version 13.4.0.0
    What driver are you using BTW? I couldn't find any official 8.1 drivers for the 4300/4500 series graphic card.
    Thanks again popeye. I've got it all sussed now. I was installing a more recent Realtec driver but when I installed the correct one for my MB, it's all good.
    Cheers.
Page 1 of 2 12 LastLast
AMD HDMI Output 'not plugged in', no sound
Hi all. I sucessfully got bootcamp to work on my iMac, and the only issue that I have run across is that I do not have any sound whatsoever coming out of my speakers. The sound icon just remains at the speaker with a red cross, and no matter what I do, I just can't get it to work. In...
FIX - AMD HDMI no sound output to monitor speakers
Problem: AMD HDMI output would not play sound via HDMI cable to monitor speakers. Testing the AMD HDMI sound output gave the following error message: Device in use by another application… This FIX worked for this hardware configuration. · MSI motherboard · Realtek Audio...
Realtek HD Audio only shows one audio output at a time
broke or damage my HDMI output
HI, I'm new here. I run the sfc /scannow like 5 times because when I did it, it broke or damage my HDMI output. The only problem my sfcdetails.txt file shows is that it cannot repair Amd64\CNBJ2530.DPB of the prncacla.inf file due to a hash mismatch. But you already wrote that it doesn't had to...
HDMI output not working
Hey guys, I have an ASUS s550C running windows 8 and my HDMI to my 32" RCA flatscreen doesn't work anymore. The cable works fine with the xbox, correct tv modes, but now as soon as I plug in the HDMI to the Ultrabook the Ultrabooks screen goes black and the tv screen says unsupported. What gives?...
Graphic Cards
AMD HDMI Output [Not Plugged In]
Okay so, my computer recently crashed and had to reformat it.. lost everything :( Everything was working just fine, until I had to reformat. Now, I have no sound at all coming from my headphones and it says that the AMD HDMI Output is not plugged in. I don't really know how to fix this.. ...
HDMI Sound output issues
Hi there, new to this forum but i've been searching around today trying to find an answer to this problem i'm having. I've bought an HDMI cable to connect my laptop to TV, i've gone into the control panel and checked that "show disabled devices" and "show disconnected devices" are both...
