No audio output through HDMI port to TV
zainsyed
Hi there, I'd really appreciate if this could work, the details of my system are as follows:
Dell XPS L502X
Nvidia GT 525M
I have downloaded the Realtek Drivers as mentioned here for the Windows 8 version, plug in the HDMI cable but still the output doesn't go to the TV but sound plays from the laptop speakers.
Earlier when I used this along with the Win 7 OS, it worked flawlessly. I don't know what the problem is. I've tried uninstalling the windows drivers and then installing Realtek drivers but still doesn't work.
Any help would be appreciated. I've attached the screenshots of device manager as well along with audio properties.
    Windows 8 Release Preview 8400
    XPS L502X
    i5 processor
    4 Gb
    NVidia 520M
I've also tried downloading the ATI HDMI driver, I don't know why I don't have an ATI board anyway.. but from this site obviously it says no supporting device was found on the system.
    XPS L502X
    i5 processor
    4 Gb
    NVidia 520M
Right click the sound icon in your tray, select "Playback devices", select your device (probably the name of the TV) and set it to default.
Note.
Leave it as the default as Windows will switch back to the computer speakers if the TV is off and back to the TV when you turn it on.
    Win 8 release canadate
I guess it's by design that when the audio is directed to TV, my computer loses its audio. Image someone watching a video streamed from the computer to TV, while I work on something else on the computer, is it possible to output audio to different sources simultaneously and separately?
    Windows 8 Pro
No problem with connecting PC to TV via HDMI
Hi. I have no problem connection my PC to my TV via HDMI. Good picture and sound. But if I want to play another UTube or similar, then there is a good picture, but no sound!
I then reinstall my Realtec drivers and all is good again. Until I want to use a second time.
I've tried re-booting both PC and TV, booting up PC with TV turned off and with TV turned on. To no avail.
I'm going bonkers.
I am using Windows 8.1 with Intel 2 Core E8500 CPU and 6GB memory.
Any useful suggestions will be gratefully received! :)
    Windows 8.1 Pro 64bit
    Intel Core2 Duo E8500 3016Ghz
    Gigiabyte EP45-UD#LR
    6GB
    ATI Radeon HD 4300/4500 Series
I'm going bonkers.
HDMI audio is actually a function of the graphics drivers. Sounds like the Realtek audio and HDMI audio aren't communicating properly to switch back. Do you have the latest graphic drivers installed?
    Windows 8.1 Pro 64-bit
    Acer V3 771G-6443
    i5-3230m
    Acer VA70_HC (U3E1)
    8GB DDR3 PC3-12800 (800 MHz)
    HD4000 + GeForce GT 730M
    Realtek High Definition Audio
    1600x900 pixels
    Samsung SSD 850 EVO 250 GB
    ADATA SSD SP900 128GB
    90 watt brick
    Bluetooth
    Comodo
Thanks for your response. Would "ATI Radeon HD 4300/4500 Series" be the graphic card I need to update?
    6GB
Hi popeye,
Yes, I've made sure I have the latest and correct ATI Radeon driver. Still nothing!
    6GB
Well, that is a legacy card and may have issues with 8.1. All I got left is may run this then see what Windows installs at reboot, then re-install driver manually if necessary.
Display Driver Uninstaller Download version 13.4.0.0
What driver are you using BTW? I couldn't find any official 8.1 drivers for the 4300/4500 series graphic card.
    Acer V3 771G-6443
    i5-3230m
    Acer VA70_HC (U3E1)
    1600x900 pixels
    90 watt brick
    Bluetooth
    Comodo
Thanks again popeye. I've got it all sussed now. I was installing a more recent Realtec driver but when I installed the correct one for my MB, it's all good.
Cheers.
    6GB
Cheers.
That's good to hear. :)
    Acer V3 771G-6443
    i5-3230m
    Acer VA70_HC (U3E1)
    1600x900 pixels
    90 watt brick
    Bluetooth
    Comodo
