I am currently using an Asus laptop with windows 8.
The laptop only has 1 usb port and an audio combo jack.
I have bought several headsets with mics with either the combo audio cable or one with the 2 cables and used s connector to plug them in to the audio jack and the mic won't work. The headphones work fine and sound great but no matter what I do it will only pick up the mic that comes installed on the laptop.
This is not a problem if I use the usb port but that is no longer an option since the tracpad has stopped working.
I've tried several solutions I've seen posted on the forms and so far nothing has worked. Is this a lost cause for me?
