Connecting two headphones to my laptop?
    Windows 8.1 64-bit
    Hello everyone. I use an ASUS G46W ROG edition, and I'd like to be able to connect two headphones to it so that two people can listen to audio off of my computer at the same time.
    I know those Y-cables/adaptors exist, but I'm not looking to use those, as they merely split the audio signal - I need something that'll duplicate the audio signal, then output it to two different devices.
    Instead, I'd rather use some sort of USB audio card that has atleast two 3.5mm output ports, and will output audio out of both ports.
    Does something like this exist? If so, then could you give me some recommendations?
    Florida, USA
    Windows 8.1 Pro x64 with Media Center, Windows 10 Pro x64, Windows 7 x64 Ultimate SP1
Problem connecting a phone to a laptop
I have an LG D380 and I used to connect it to a Win 7 laptop via USB, never had any problems. Now I have ASUS N751J and when I try to connect the phone to it, the phone connects (on the phone connection is set to MTP), I see the message "connected as media device" on the phone and I can see the...
Drivers & Hardware
Static sound coming from headphones on Windows 8 laptop
I just bought a Dell Inspiron 17 laptop with Windows 8.1. When I first plug my headphones into the audio jack it works and it's initially silent. However, after I finish playing any sound from any app through the headphones, a static sound constantly comes through them. It doesn't sound like...
Headphones sound rubbish in laptop today
Used my computer after work to listen to music with headphones in and it sounds rubbish, bearable but rubbish. I have Sennheiser headphones that usually sound fantastic, they still do sound fantastic on my phone listening to the same song on Spotify. Anyway, tried Spotify and YouTube and the...
Sound playing through both laptop speakers and headphones
I bought the plantronics .Audio 335 studio headphones, but when I plugged them in, it screwed up my sound. My compute'rs sound is now playing through both the headphones AND the laptop speakers. After unplugging it and trying again a couple times, I gave up and decided to just use my old...
laptop is not disabling speakers while headphones connecte
I dont get it, when i connect my headphones they work OK, but i can also hear trow my laptops speakers and they are not disabling themselves like they use to. its a huge problem and my roommate is going to kill me, i will appreciate your help ASAP
Headphones dont play sound on laptop.
Hi, I have a HCL laptop with Windows 8 Pro x86 installed. Whenever I connect my headphones I don't get any sound from it. I have gone to my "Playback Devices" and selected "Show Disabled Devices" and the headphones are not listed there. What can I do to work around this problem ? I need my...
problems connecting to the Win 8 laptop from Win 7
Have a question regarding "Local Account". I'm having problems connecting to the Win 8 laptop from Win 7 as it will not accept my sign in credentials. With that, am I to assume that this is because the credential aren't "Local", and thus this is what this is for??? 21428 It will not accept...
Network & Sharing
